Samsung UN60FH6003 yellow tint 3 days after replacing backlights
  • x_orange90_x
    • May 2015
    • 750
    I replaced all of the backlights in my Samsung UN60FH6003FXZA over the weekend. I bought them from ShopJimmy. For the first couple days everything was great, the picture was crisp and bright. Last night I sat down to watch TV and noticed the entire screen now has a dull yellowish tint to it, but a little more so to the left. At first I thought it was the settings, but everything looks correct and no matter what I change its a dull yellow color. When I go through the Video Modes (Dynamic, Standard, etc) I can see them change, but there's a flash of bright vivid color that looks correct, but only for a fraction of a second and then it's a dull yellow color again. It's hard to explain but it looks like each time I change the mode, it brightens up to how it should look but then immediately dims down again. The color settings are set to Cool also, so I know that isn't it.
    After spending 2 1/2 hours replacing the backlights, I'm very disappointed to be having color issues now after only a few hours use. Are the backlights I installed defective? Or is it something like weak caps on the power supply? It was a PITA getting this thing up on the wall, so that's mainly why I'm bummed by the thought of having to open it up again 😒
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Samsung UN60FH6003 yellow tint 3 days after replacing backlights
    Were they new or used ?
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Yes, it could be that the backlight you installed are defective, now. They probably were in good order when you received/installed them but you did not turn the Backlight control down after installation and they were working at full intensity/current and so got damaged. This is just my theory, though. I could be totally wrong.
      • x_orange90_x
        • May 2015
        • 750
        The backlights were from ShopJimmy, and while they can't claim their parts are new, they aren't used either, they're from TV's damaged during shipping. However, I believe they manufacture these strips new because they had over 130 in stock before i bought them, and now they are "On Order" and out of stock.
        As for the backlight level, I did in fact immediately turn it down after the repair. I've been using it at 12 out of 20 (Max). Even if I had been using it at 20 surely they should last longer than 2 days (roughly 8hrs total use since repair).
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          It may be worth checking your led and dim voltages just in case you're unfortunate and something else has happened.
          • JohnCT
            Lurker
            • Apr 2018
            • 32
            • US
            We've had lots of defective parts from SJ. While some of their parts could be from new stock damaged in shipping, it's my opinion that most of their parts are those culled from TVs being recycled, either from a broken screen incident or electrical failure.
            One shop I know bought three Vizio mains for a certain repair job from SJ and they were all bad, mostly because certain Vizio mains are good for maybe 2000 hours before they die and is the primary reason they are scrapped out. The fourth one SJ sent was good.
            The good thing about SJ is that they make good on parts without question, but my experience is only from a professional repair shop standpoint. They may not be quite as generous with consumers repairing their own TVs.
            Here's where it gets sticky. If one were to buy an LED strip from any source (I don't want to pick on SJ particularly because they're an excellent supplier) and it had but 50 hours left before an LED was due to die, then the strip would fail shortly after installation. The fact that it was good when installed doesn't mean it's not at the end of it's life. We can see a car tire with 50K miles on it having little tread left, but there's no way to predict how many hours are left in any part regardless of where we buy it, unless we can source it from the manufacturer as new.
            BTW, Vizio mostly supplies used parts from TVs they recycle from warranty exchanges. The difference is that Vizio actually tests every part before shipping, but Vizio AFAIK doesn't sell LED strips for their TVs.
            John
            • x_orange90_x
              • May 2015
              • 750
              John
              Thanks for your reply. I understand what you mean. In case I wasn't clear, my TV is a Samsung, not Vizio. I'm not sure if you were just using them for reference or not.
              SJs FAQ state that they do manufacture some of their own parts, and I believe LED strips may be one. I say this because, my TV is 5 years old now, and surely Samsung hasn't used the same strips for that many years, so it's unlikely that they're able to stock 130+ sets of strips from salvage, AND have more sets On Order. I could be wrong though.
              I surely hope it's not the LEDs, again!
              • JohnCT
                Lurker
                • Apr 2018
                • 32
                • US
                Yes, because I was relaying the story of the Vizio model known to be a main board killer and three replacements were all bad. The point was that you can buy replacement parts and still be bad, and that I don't think (pure opinion) that SJ tests parts. Exception to that is the LED strips, which are quite easily and quickly tested. They will however replace any part immediately and with no trouble. Still, if an LED strip had few hours left before the screen was damaged or the TV suffered some other failure, the life expectancy would remain the same.
                Link?
                I did a quick check, and the strips in your model fit many other models of Samsungs. SJ is out of stock right now on your version. No, Samsung rarely uses the same part from year to year, but there are many thousands of these being scrapped every week. Perhaps SJ has truckloads of TVs not yet evaluated and stripped, and they expect to cull some good ones from TVs yet to be recycled. This is pure speculation on my part as I have no direct knowledge.
                Strips are available from China, but from what I've gathered, most complete assys coming out of China (like strips) are salvaged as well.
                John
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  If everything is OK and you suspect the LEDs again. You could do as I do and get a NEW set of universal LED strips from China and they seem to work well. You would have to determine if each LED is the 3V or 6V. Most likely the common one that is 3V. Give it a try.
                  • x_orange90_x
                    • May 2015
                    • 750
                    Link?
                    John
                    Here is the link, it's under Where do you get your parts? and Are your parts new or used?
                    http://www.shopjimmy.com/faq/
                    Also, I emailed them about my issue and this is their reply:
                    "We do have these manufactured for us actually so they're brand new, bit of an odd issue though which I can only assume it might be a manufacturing defect on those but it's super odd you didn't see this immediately though. Honestly the only report we've had of this issue so we're a bit stumped ourselves! You'll spot a prepaid USPS shipping label attached, please use this to send the first set of strips back to us.
                    At the moment we're out of stock on these but will have another batch in about the 8th of May. If you're okay with waiting I'll have a replacement order shipped out as soon as we get them in. Otherwise is no issue at all to refund these once they get back to us.
                    Regards,
                    Austin Manning
                    Customer Service
                    Austin@shopjimmy.com"
                    • JohnCT
                      Lurker
                      • Apr 2018
                      • 32
                      • US
                      Regards,
                      Austin Manning
                      Customer Service
                      Thanks. If they say it, I believe it. I'm just not convinced that all of their LED strip offerings are "made for them", but I am that your version is new stock.
                      Can you post a picture of what you're experiencing? From your description it might be a erratic LVDS harness or associated connectors between the main and tcon.
                      John
                      • nomoresonys
                        • 12307
                        • U.S.
                        Probably got a bad set.
                          Did you do factory reset by getting into the reset mode with remote key combinations?
                          I cannot see how the LEDs will be putting out yellowish color, it has to be extreme color shifting for the LEDs to be doing that.
                          • x_orange90_x
                            • May 2015
                            • 750
                            No I have not been into the service mode at all yet. Now that you've posted I see you have the link to the codes in your signature. I'll try this first when I get home. Thanks
                            • arenat
                              • Nov 2015
                              • 22
                              • Argentina
                              I've had a similar issue a couple of times , clean with alcohol and reassemble the panel wires .
                              I'm having a great trouble trying to find the correct English words .
                              Usually the culprit is mainboard to t-con
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4516
                                • Italy - Milan
                                Hey how many words on bad LEDs! Them cannot be, when them fails the prot. circ. kicks in.. them doesn't fail yellow and there isn't a menu setting that renews them for any time, the problem is most probably lvds ribbons maldisplaced.
                                • x_orange90_x
                                  • May 2015
                                  • 750
                                  😂😂 I love the translation!
                                  I got into the service menu and did factory reset. I suppose it helped a little bit, but only when the backlight is turned up (default). What is an appropriate backlight level? I originally set it at 10, but that was too dark, and turning up brightness makes the yellow come out, so now I have it at 13. I just don't want to burn out my new leds, but I also want to enjoy the picture on this 60" led 😁
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8340
                                    Yeah, LED backlights giving an intermittent yellow color is rubbish. My LED TVs are all set anywhere from 50% to 75% backlight level and have been there since ever I bought them. So far I have 0 LED's fail.
                                    • x_orange90_x
                                      • May 2015
                                      • 750
                                      So I'm good up to about 16 then?
                                      • nomoresonys
                                        • 12307
                                        • U.S.
                                        Yellowing of the LED's could be evidence of failure from heat, check if they are running hotter than your white leds or are they all yellow?
                                        • x_orange90_x
                                          Replacing backlights in Vizio V755-J04
                                          by x_orange90_x
                                          I've had this monster for several months as I've hesitated to order backlights for it. Finally did order them and they are due to arrive tomorrow. Besides having ample space to work, are there any recommendations for working on such a massive screen? Should I remove the panel by myself or would 2 people be a better choice? I bought the double-cup suction cups from Harbor Freight and have been using them for the last few repairs on smaller screens. They are far superior to the single cup orange ones I used previously that would often let go without warning 😱.
                                          I have not replaced...
                                          12-03-2024, 07:03 AM
                                        • Storyteller12
                                          Replacing Backlights on 85” Samsung
                                          by Storyteller12
                                          This Samsung tv I'm trying to replace backlights on has COF tabs on the top and bottom of the panel.
                                          I don't have room to lay the screen flat down. Usually I stand the screen up against the wall. I'm afraid to do that with this one and damage one of the tabs.
                                          Anyone done this before?...
                                          08-22-2022, 11:15 AM
                                        • IT&TVHobbies
                                          LG 50Lf6090 only backlights after replacing LED strips
                                          by IT&TVHobbies
                                          I have an LG 50LF6090-UB that had a picture but started flashing on and off. Tested the LED strips and it had several bad LED's. Replaced the LED strips and turned the TV on and it only had the backlights on. Researched the issue and purchased a TCON board online. This did not fix the issue. Researched again and purchased a Main board on line. This didn't fix the issue either. The only thing now is that the backlights turn on as soon as I plug in the tv without touching the power button. Any help to identify the problem would be appreciated.
                                          Thank you
                                          11-13-2021, 11:26 PM
                                        • max789
                                          Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                          by max789
                                          Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                          I made the following tests:
                                          1. Disconnected the main board from Power Board = backlight works.
                                          2. Connected the main board and disconnected the T-Con = backlights does not work.
                                          So I ordered a main board from Ebay also BN41-02156A but from...
                                          01-18-2024, 06:56 AM
                                        • bpcannan
                                          VIZIO M557-G0: Backlights or ???
                                          by bpcannan
                                          'Morning,
                                          I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
                                          Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
                                          I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
                                          I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
                                          10-29-2023, 06:36 AM
