Can wrong polarity in MM destroy components?
  • Sraros
    • Jan 2017
    • 223
    • Greece
    On a TV that got stuck at the logo, I opened to check the voltages from the PSU to the main.
    Instead of putting the black probe to the ground I put the red one and just didn't bother to get negative voltages. At some point as I was checking through the pins the backlights went off for a sec and then on again. I screwed the TV back together to check it thoroughly another time, plugged it in one more time and the picture was gone.. only backlights.
    Can it be that using the probes inverted when measuing voltages with the MM can damage the panel or in general el.components?
    I didn't short any pins with the black probe checking the pins for sure.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Can wrong polarity in MM destroy components?
    Reversing the meter probes when measuring voltage results in reverse polarity of the reading displayed on the multimeter. That is for example, 5.0V becomes -5.0V and does not cause a problem.
    The possibility that a probe may have shorted two pins together (slipped) when taking a measurement could result in damage.
    • petehall347
      • Jan 2015
      • 4450
      only way damage might be caused by the meter is by having meter leads set to amps . i have blown a few meters doing this as it happens .
      • Sraros
        • Jan 2017
        • 223
        • Greece
        Hm what about continuity mode? I am trying to remember if I have left the MM by accident in continuity when I measured it in off state and then powered the tv but forgot to change to voltage setting. For sure I didn't put in anytime the MM in resistance setting.
          It will depend on what the break down Voltage in the meter mode is. What section of the TV and the connector were you probing?
          It can also be co-incident too.
          • Sraros
            • Jan 2017
            • 223
            • Greece
            I was checking the voltages from the PSU to the main and it damaged the panel board. The TV doesn't have a T-con, it goes directly from main to the control board. The input voltage of the panel is 12V
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8711
              Most modern DMMs limit current to milliamps when in resistance/diode check mode, and usually are not enough to damage circuitry even if the meter was set to these modes. This is not the case for old analog multimeters where in Rx1 mode it would happily send 100+ milliamps which can destroy semiconductors.
              However this is assuming you're probing when off. When probing when on, you have a different problem: if you probe a high impedance circuit with resistance/continuity/diode check, you can trigger that circuit to turn on when it wasn't supposed to, and damage it that way. And of course having the meter in current mode when you're really checking for voltage causes dead shorts, also potentially causing damage to the device under test.
              That being said, the usual method for destroying something with multimeters is shorting adjacent pins with a slipped probe, regardless if it's a digital or analog or VTVM.
              • Sraros
                • Jan 2017
                • 223
                • Greece
                A little late but thanks for the analytical reply.
                For sure since then I am much more careful when checking voltages and diode mode when devices are off. I am inclining that the damage back then was done when I measured in diode mode while the tv was still on…
                • angelos
                  • Dec 2012
                  • 573
                  • South Africa
                  Ox gamoto
                  • ohren
                    Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                    by ohren
                    Hello!
                    I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                    Measured voltages with no load:
                    After rectifier diodes
                    12V: 6.17 V
                    5V: 5.67 V
                    Secondary transformer pins AC measurement (really don't know if this says anything)
                    12V: 2-2.5 V
                    5V: 1.04 V
                    I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                    03-18-2023, 10:33 AM
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • triplefour
                    by triplefour
                    09-13-2023, 10:43 PM
                  • corrize
                    Where to find a very small fpc connector 0.3mm between 2 pins ?
                    by corrize
                    Hello, I search this connector (oxydated).
                    It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                    I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                    I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                    Do you know how to find this connector please ? What is the exact name for find it ?
                    08-06-2024, 05:25 PM
                  • JimBanville
                    MOSFET mystery
                    by JimBanville
                    N channel mosfets testing as P type?
                    Working on a smps.
                    Using Fluke 115. Red probe in red socket. Black probe in black/common socket. Meter set to diode mode.
                    Removed a pair of mosfets marked 1L02AB FDP
                    26N40 from the circuit.
                    The pair of Mosfets are still screwed to the single heatsink. Mosfet printing facing me.
                    I did the test where I short the left and center pins. I put black probe on right pin and red probe on center pin. I get OL. While keeping black probe on right pin, I put red probe on left pin and get OL. After a few seconds I move red...
                    09-14-2023, 04:22 PM
