Sharp Aquos lc-40le600e stuck in standby - no lights flashing
  • Tim5000
    • Apr 2018
    • 15
    • England
    I've got a Sharp Aquos that is my friends and I said I'd have a quick look at it for him.
    He's owned it from new for about 8-9 years.
    It recently developed a fault where it will not turn on anymore - the red standby light comes on but that's it...no flashing codes here unfortunately.
    There is also no sign of the backlight flashing, or anything on the panel when viewed with a torch.
    I've done some very basic checks on the power board and main board.
    • Power board is marked RUNTKA609WJQZ.
    • Main board is DUNTKF111
    If I power the unit on and probe the power board I can see that:
    1. CN7501 - BUS5V goes to 5V
    2. CN7501 - PS_ON goes to 2.57V
    3. CN7501 - AC DET goes to 3.3V
    4. CN7501 - PNL_POW stays 0V
    5. CN7501 - UR_13V goes briefly high then immediately decays to 0V
    6. CN7505 - PNL_12V stays 0V
    I've checked the big electrolytic C7144 and there is 400V DC across it.
    If I leave all plugs in but remove the backlight, the voltage at UR_13V still collapses.
    If I unplug all the boards and backlight, and jumper PS_ON to BUS5V I get UR_13V to go to 13V. PNL_12V stays at 0V.
    Any help gratefully received!
    Re: Sharp Aquos lc-40le600e stuck in standby - no lights flashing
    "If I unplug all the boards and backlight, and jumper PS_ON to BUS5V I get UR_13V to go to 13V. PNL_12V stays at 0V."
    You will need to also jump PNL_POW with resistor (470 ~ 1000 Ohms) to BUS5V to force on the PNL12V (no cable from PNL12V to T-CON).
    • Tim5000
      • Apr 2018
      • 15
      • England
      Hi budm, and thanks!
      From your info I've jumpered PNL_POW via a 470ohm from BUS_5V and the PNL_12V successfully comes up now.
      Again, this is with all other boards disconnected.
      I've managed to find the schematic of the power board but I presume we are looking more toward the main board based on this outcome?
      • Tim5000
        • Apr 2018
        • 15
        • England
        I've since connected all the boards back up (with the exception of CN7501 between the PSU and main board). This includes the backlight.
        Fitted the jumpers for PNL_POW and PS_ON and the supplies all come up and look stable on the PSU board.
        However nothing different happens with the TV - no backlight comes up and the status is stuck red (presumably because the main board hasn't commanded it to do anthing)?
          If you remove the force on jumpers and try using the remote control combination to force the TV on to see what happen, I do not remember the key combinations.
          • Tim5000
            • Apr 2018
            • 15
            • England
            I've plugged everything back in and tried tonight to get the tv to turn on but I can't make it come on.
            I've tried the sequence in the service manual
            Code:
            2. Entering and exiting the adjustment process mode
            1. Press the “MAIN POWER” key on the set of running TV set to force power off.
            (Or, unplug the AC power cord of running TV set to force power off.)
            2. While holding down the “
            (-)” and “INPUT” keys on the set at once, press the “MAIN POWER” key on the set to turn on the power.
            The letter “K” appears on the screen.
            3. Next, hold down the “
            (-)” and “P (-)” keys on the set at once.
            Multiple lines of orange characters appearing on the screen indicate that the set is now in the adjustment process mode.
            If you fail to enter the adjustment process mode (the display is the same as normal start up), retry the procedure.
            I've also tried what I've found for other Sharp sets (Vol Down and Channel Up).
            Both no dice unfortuantely after several attempts at each.
            • Tim5000
              • Apr 2018
              • 15
              • England
              So a bit of progress.
              Despite many more attempts with all leads plugged in I couldn't get into the service menu.
              So a little inspiration and I disconnected the two large backlight connectors CN7606 and CN7607 from the power board.
              Once they were unplugged the set would go from red light to no light when toggling the set on and off (not flashing, but just on and off instead of on and green). So this tells me the main board was actually a little more alive than previously thought.
              From here (again with the backlight connectors removed) I managed to get into the service menu (checked with a torch). I reset the error codes and plugged it all back in.
              Resetting the error codes made no difference.
              So it's now in a state that:
              * With the backlight plugged in the set hardly won't turn on (no error codes flashing).
              * With the backlight unplugged the set won't turn on but the power led goes red and off.
              * With the backlight unplugged and FORCING on with (Input/Vol down) the set powers up and appears to operate. D3322 is flashing on the main board.
              • Tim5000
                • Apr 2018
                • 15
                • England
                A little bit more progress/update.
                If I plug in the black backlight connector (CN7607) but leave the white backlight connector off (CN7606), the tv still behaves as per my previous post.
                However in this state the backlight comes up. I can see that all the elements look OK.
                I can also see that after my playing about there are some elements in the error codes.
                These MAY be because I've been running with cables unplugged? Or they may be why the tv hasn't powered up:
                Code:
                STANDBY CAUSE: 1B 1B 1B 00 00
                1) 17683H 00M
                2) 17683H 00M
                3) 17683H 00M
                4) 00H 00M
                5) 00H 00M
                • Tim5000
                  • Apr 2018
                  • 15
                  • England
                  I've managed to get a little time to investigate this further.
                  If I remove some pins from CN7606 I can get the unit to go into the service menu with the backlight on.
                  The pins relate to backlight rows 2 and 3.
                  With those pins connected the tv will not turn on or enter the service menu.
                  If i swap the pins such that the backlight pins go to different driver pins on the psu board the fault seems to follow the backlight. So it sounds like the 2 backlight rows are faulty.
                  However if I remove the pins for backlight 2 & 3 and enter the service menu, I can plug the pins back in while the set is on (carefully of course) and they all light up. So there are no dead LEDs on the set.
                  Any thoughts please? It sounds like the tv is maybe just too tight with it's tolerances in the fault detection circuit on an old tv?
                    • 12332
                    • U.S.
                    Can/did you do a factory reset from the service menu?
                    • Tim5000
                      • Apr 2018
                      • 15
                      • England
                      I had done that earlier but it didn't help.
                      But in fact I've just fixed it!
                      So...interestingly (but maybe not surprisingly for some of the experts) the problem was down to a dead gnat/midge in the LED2 connector - at the backlight end, not the PSU end.
                      Once I'd removed that I could power up in the service menu and again reset the status.
                      After that the TV now powers on properly.
                      And fortunately for my friend no new boards required.
                      Thanks for the input.
                        • 12332
                        • U.S.
                        Well done
                        • zwarder
                          • Oct 2013
                          • 46
                          • United Kingdom
                          Very similar symptoms here but unfortunately dead & flickering leds were the cause
                          • sefoster
                            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                            by sefoster
                            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                            11-20-2022, 09:29 AM
                          • scubacamper
                            Sharp Aquos LC-70C6400U Half Screen Dark
                            by scubacamper
                            I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                            Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                            when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                            05-03-2025, 12:19 PM
                          • dmcabs
                            SHARP LC-60LE640X display flashing white noise patches and totally dropping out randomly
                            by dmcabs
                            Hey guys,
                            I have a SHARP LC-60LE640X TV that has suddenly developed an intermittent fault of flashing white noise patches (appears like an Analog tuner off signal) and then totally dropping out.
                            This model I believe is also known as LC-60LE600U or LC-60LE640U in other regions.
                            FYI, a long time ago I was a component level repair tech for all consumer electronics and IT equipment.
                            I'm a bit rusty but still have ability to dig right down.
                            I measured all power supply lines and checked them for AC ripple voltage. Noting any lines that exceeded about...
                            09-21-2024, 11:09 AM
                          • JunkmanJimbo
                            sharp lc-65ub30u plays but screen is flashing on and off
                            by JunkmanJimbo
                            Hey guys! It has been awhile since I've been on here. I hope everyone is doing well. I just picked up this Sharp lc-65ub30u. It plays but the screen is flashing on and off. Other than that i seems to be a great tv. Any ideas what the problem might be? I haven't pulled the back off yet. I thought I would get some opinions first. Thanks in advance for any help you can offer.
                            09-07-2024, 09:45 AM
                          • jonah1024
                            Sharp Aquos LC-40UG7252E LCD TV burn in?
                            by jonah1024
                            Hello!
                            I'm a few days old into this TV screens repair universe so please bear with me.
                            Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                            - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                            - I did a factory reset as well...
                            07-16-2024, 04:23 AM
