LED Backlight Mod
  • london-freddie
    • May 2015
    • 472
    LED Backlight Mod
    Hi guys asking for help advice, I have got a family members LG tv coming to me in the next few days with failed backlight led or leds, I know it will be a failed led as I have now fixed this tv three times with failed leds, fix one led another fails after a time scenario, asked them to reduce backlight in settings
    My question is it possible to install a resistor in the feed to the backlights to reduce the voltage going to the led strips, in theory maybe they will last a bit longer. Or am I wrong and it will make no difference or leds will not work.
    Any ideas please
    Re: LED Backlight Mod
    You can try looking for the LED driver IC spec, it may have control pin that will set the LED current, if not then you can increase the resistance of the Current sensing resistors.
    https://www.badcaps.net/forum/showth...ED+CURRENT+MOD
    • london-freddie
      • May 2015
      • 472
      thanks for that budm, do you think it is a worthwhile idea to try and lower the current going to the led strips in order to try and make these failing leds last a bit longer.
      I was rather hoping that I could just put a resistor in the feed wire/s from the board to the backlights, is that not possible ?
        The LEDs are driven by constant current circuit, simply putting the resistor in series with the LED string is not practical since the power supply will try to maintain the current flowing through string, so modifying the feedback circuit is easier or modify the IC current setting, if it has one, will be better.
        Some TV you will have to make sure that the backlights level are set for each input source.
        • london-freddie
          • May 2015
          • 472
          Thanks budm, not as easy as I was thinking this one, may have to just keep replacing the leds as they fail,
          • mu2
            • Oct 2009
            • 217
            I've modified a couple of LG 50LN5400 sets for myself that use the BD9483F chip.
            The spec sheet is here:
            https://www.rohm.com/datasheet/BD9483F/bd9483xx-e
            If you read the specs you will find a formula to determine the current allowed to flow through the leds. Raising the resistors will lower the current.
            The boards that I modified had an array of surface mount resistors near the chip on the bottom. I'd suggest measuring those resistors and see what those values yield in the current formula.
            Your board may not use this same chip.
            I don't have enough experience to say that it extends the led life. I can say that I did not notice any significant decrease in brightness after the mod.
            Mike
            • Agent24
              I see dead caps
              • Oct 2007
              • 5035
              • New Zealand
              Best option maybe to change the LEDs for higher power ones, that can handle the current better?
              -David VanHorn
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                I have found that if I have to replace LEDs on a strip or strips more than once, it would be better to replace ALL the strips with new ones. Just turn the backlights down to 60 for all inputs. The LGs have different backlight levels for each input, so ALL inputs MUST be re-adjusted to the lower level and that will save your backlights in the future.
                • alltvrepairs
                  Jvc Lt-65VU3000 reduce backlight from service menu
                  by alltvrepairs
                  I have just replaced led set of this vestel tv due to age.
                  I would like to reduce backlight from service mode. I have tried menu 4725 but in the menu i can't change anything.
                  Any help pls? I don't want to change from electronics inverter feedback resistor ideally.
                  Thanks again....
                  09-20-2025, 05:03 AM
                • triplefour
                  by triplefour
                  09-13-2023, 10:43 PM
                • hollox123
                  ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                  by hollox123
                  Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                  1. Laptop keyboard doesn't work
                  2. The backlight on the laptop keyboard doesn't work
                  3. The x2 side LEDs (red) on the laptop don't work
                  The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                  I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                  But I am strongly aiming that it is somehow a BIOS-related problem,...
                  05-11-2025, 08:05 AM
                • signal.quest
                  Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                  by signal.quest
                  I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                  03-17-2024, 10:14 AM
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
