PHILIPS 32PF5420710 not power on
  • Nawual
    • Jul 2016
    • 65
    • Spain
    This TV does not turn on even in stand bye.Does nothing.It is the Philips model 32pf5420 / 10 chassis with lc4.3e aa.As a power supply brings the model PLCD 190 P1 23171 and I have not found the scheme to be able to measure the voltages that come out to the main board. One help please.
  • WildPuppy
    • Mar 2018
    • 61
    • Romania
    Re: PHILIPS 32PF5420710 not power on
    Maybe I don't understand the problem correctly but from what I make of your post, the TV does not even make it to StandBy mode, ie. no LED lights up, nothing. Am I right?
    If yes, did you check the very obvious fuse?
    (the one in the circle)
    • Nawual
      • Jul 2016
      • 65
      • Spain
      Hi,yes, you right-No led lights up and the first things,itΒ΄s check the current cable and that fuse.ItΒ΄s works.
        So do you have any DC Voltage on the connector that goes to the main board? All 0V?
        • Nawual
          • Jul 2016
          • 65
          • Spain
          My problem is that I do not know what voltages and which wires from the connector that goes to the main board have to carry them.
          In other occasions you have the tensions and the name of each cable painting on the board, this time it has nothing and I can not find the scheme of the power supply.
            Right now we just need to know if there are any DC Voltages at all at the connector, so please just report what each pin has, that is what I will do if I have the board in front of me.
            BTW, sometime they print pin names on the bottom side of the board.
              We also need straight shot high res pictures of the whole bottom side of that power supply board so I can trace out the circuits.
              • Nawual
                • Jul 2016
                • 65
                • Spain
                Tomorrow I will see some indication from the back and what tensions are between the pins.
                There are three photos uploaded in high resolution, are not they good?
                I can go up more if the details are not well appreciated
                  Well, I do not see the pictures of the bottom side of the board.
                  • Nawual
                    • Jul 2016
                    • 65
                    • Spain
                    Apologize for my english,its veeeeeeeeeeeeeeeeery poor.
                    I have confused:
                    "abajo" (spanish)= bottom with "detrΓ‘s"(spanish) = back
                    IΒ΄ll take pictures
                      No problem.
                      English is also my second language, I know how it is.
                      • Nawual
                        • Jul 2016
                        • 65
                        • Spain
                        Now I see that you live in S.F bay, there is also a lot of Spanish spoken in those lands.
                        Well, I upload those photos and measurements tomorrow.
                        Thanks for your help
                        • R_J
                          • 9532
                          Here is a partial schematic of the power supply
                          • Nawual
                            • Jul 2016
                            • 65
                            • Spain
                            Oh mate,very interesting,thanks!
                            • Nawual
                              • Jul 2016
                              • 65
                              • Spain
                              Thanks to the pdf of the source uploaded in this post, I have removed the power source from the tv and I have connected on pin 10 a voltage of 3.3v through a 1k resistor. After that I have measured the voltages in the connector and I have obtained these measures:
                              Pin 1:24,7v
                              Pin 2:0v
                              Pin 3:3,3v
                              Pin 4:3,3v
                              Pin 5:0v
                              Pin 6:0v
                              Pin 7:0v
                              Pin 8:11,9v
                              Pin 9:3,3v
                              Pin 10:3,1v in+with external source
                              Pin 11:0v
                              Pin 12:0v
                              Well, I think the problem is on the main board. What do you think?
                              • tmcw
                                • Oct 2010
                                • 382
                                • Ireland
                                Just wondering if you made any progress with your issues?
                                I have a Philips 32PF5331/10, but mine appears to have the same power board as yours.
                                Mine is still working, but from cold, it can take a few times switching the set on/off before it will start up, but it seems to work fine after that.
                                I haven't had it long enough to test it further, but if you need any info or tests that I can carry out that might help, let me know.
                                • PantherDave
                                  by PantherDave
                                  Hi all!
                                  I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. πŸ˜…
                                  05-29-2024, 02:01 PM
                                • GLISIT
                                  by GLISIT
                                  01-16-2025, 02:29 PM
                                  by sam_sam_sam
                                  03-31-2024, 02:12 PM
                                  09-06-2024, 05:59 AM
