l42vp01u noisy inverter?
  • Newbie123
    • Oct 2015
    • 58
    Hi all i picked up a Hitachi l42vp01u made by vestel,the inverter was making a whine when i got it so i bought another inverter and swapped it over and it is still making a whine..does anybody have any other ideas,could it be another part in the tv putting pressure on the inverter or do you think ive just picked up another noisy inverter?,thanks in advance!
    Re: l42vp01u noisy inverter?
    Beside the noise you are hearing, do the backlights also flickering?
    Up load good clear pictures so we can see what we are dealing with will help.
    • Newbie123
      • Oct 2015
      • 58
      Hi no the backlights are not flickering and there is even backlight all over the screen,thanks for the reply some good links there to test inverters.
      • Newbie123
        • Oct 2015
        • 58
        Hi this is the tv and the inverter.
        • x_orange90_x
          by x_orange90_x
          01-29-2025, 09:24 PM
        • Gentian
          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
          by Gentian
          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
          03-06-2023, 07:07 AM
        • valvashon
          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
          by valvashon
          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
          01-04-2024, 01:44 PM
        • eccerr0r
          A modified sine wave inverter + a grid tie inverter?
          by eccerr0r
          If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
          Next thing is trying to charge the batteries using solar power, but that's another issue ...
          08-31-2023, 09:14 PM
        • caseyjay_48
          Sony KDL-46BX450 Inverter Troubleshoot Logic
          by caseyjay_48
          I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
          I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
          09-23-2022, 08:08 PM
