l42vp01u noisy inverter?
  • Newbie123
    • Oct 2015
    • 58
    Hi all i picked up a Hitachi l42vp01u made by vestel,the inverter was making a whine when i got it so i bought another inverter and swapped it over and it is still making a whine..does anybody have any other ideas,could it be another part in the tv putting pressure on the inverter or do you think ive just picked up another noisy inverter?,thanks in advance!
    Re: l42vp01u noisy inverter?
    Beside the noise you are hearing, do the backlights also flickering?
    Up load good clear pictures so we can see what we are dealing with will help.
    • Newbie123
      • Oct 2015
      • 58
      Hi no the backlights are not flickering and there is even backlight all over the screen,thanks for the reply some good links there to test inverters.
      • Newbie123
        • Oct 2015
        • 58
        Hi this is the tv and the inverter.
        • eccerr0r
          inverter H tree driver imbalance in an AC inverter
          by eccerr0r
          My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
          11-16-2025, 12:34 PM
        • x_orange90_x
          by x_orange90_x
          01-29-2025, 09:24 PM
        • Gentian
          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
          by Gentian
          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
          03-06-2023, 07:07 AM
        • valvashon
          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
          by valvashon
          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
          01-04-2024, 01:44 PM
        • eccerr0r
          A modified sine wave inverter + a grid tie inverter?
          by eccerr0r
          If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
          Next thing is trying to charge the batteries using solar power, but that's another issue ...
          08-31-2023, 09:14 PM
