LG LED 42LW5500-ZE powers on, but no picture or sound
  • Trofazni
    • Dec 2016
    • 71
    • Serbia
    I got this tv few days ago and i'm stuck. Client told me that the picture at first appeared as whitenoise, and then nothing.
    When I plug it in, it has 3v3stb, and reacts to remote controller, and pwr on gets 3v3 high, standby light turns from yellow to white, and relay clicks and now we have all voltages, but no backlight, no sound, no picture...
    Any references? Thanks
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG LED 42LW5500-ZE powers on, but no picture or sound
    Take a look at the T-CON Bd. Look for a fuse where the cables from the Main Bd connects to the T-CON Bd. See if there is continuity across the fuse.
      We are still missing more information such as the BL-ON and Dim control signals
        • 12076
        • U.S.
        What you getting for drv_on pin, with tv plugged in and when you hit power button?
        • Trofazni
          • Dec 2016
          • 71
          • Serbia
          Fuse is ok, but no voltage is present across the filter cap...
          • vinceroger69
            • Mar 2012
            • 6714
            can you do the test as requested in post 3 thanks
            • Trofazni
              • Dec 2016
              • 71
              • Serbia
              I've measured it.. errror 0V, PWM 3V1, DRV on 0v, VSYNC 0V...
              • vinceroger69
                • Mar 2012
                • 6714
                drive on i would guess should go high in voltage so maybe a main board issue i will see if we can find a service manual for this set what is the power supply and main board numbers
                i wonder if the main baord has been replaced before as never seen a original one with green pen marker writing on it
                • Trofazni
                  • Dec 2016
                  • 71
                  • Serbia
                  MB eax64294002
                  PSU eax62865401
                  Thank You!
                  I also suspect on MB, but can not find another in my country, if we can fix it, lets do it
                    • 12076
                    • U.S.
                    Test connector going from powersupply to mainboard for continuity, careful not to spread out the connector ends.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      link too the service manual
                      https://www.manualslib.com/manual/12...-32lw5500.html
                      • Trofazni
                        • Dec 2016
                        • 71
                        • Serbia
                        No, not the problem there...
                        Any other ideas?
                          • 12076
                          • U.S.
                          Looks like the mainboard isn't sending drv_on signal to turn on backlights.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            A lot of lgs were seeing in threads i notice are failing due to bga soldering and a reflow seems to get them working but not sure what ic the drv on signal comes from? is it the eeprom/spi flash or one of the large bga ics?
                              • 12076
                              • U.S.
                              In the manual from manualslib. all the pages from 30 on up don't show any info. not sure why.
                              • WildPuppy
                                • Mar 2018
                                • 61
                                • Romania
                                Here:
                                32lw5500.pdf
                                • Trofazni
                                  • Dec 2016
                                  • 71
                                  • Serbia
                                  Pwr on comes from eeprom, but I really do not know for the drv on signal.. If it comes from bga, I will try to reflow it, but I dont wanna reflow if it does not come from cpu.. Manual is ok, i have downloaded it and its fine..
                                  • Andrew F. Ali
                                    • Jan 2014
                                    • 2450
                                    • Trinidad & Tobago
                                    +10...Yes it is true. A lot of LGs have a BGA issue and reflowing with a hot air station at 350C for ten (10) minutes worked for me on many LGs recently, especially those LW series. Keep the hot air steady on the BGA chip. Of course remove the heatsink and tape from off the IC. Before reinstalling verify none of the components under the chip has been moved or shifted.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      Originally posted by WildPuppy
                                      Here:
                                      [ATTACH]174483[/ATTACH]
                                      Thanks all the pages open fine in this pdf ive added it to my collection
                                      • WildPuppy
                                        • Mar 2018
                                        • 61
                                        • Romania
                                        Happy to be of service.
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
