Sony KDL-65W855C blinking 6 times - service manual?
  • Hauke
    • Jan 2017
    • 77
    Hello guys,
    I got this 65 inch TV from eBay.
    At startup the sony logo flashes shortly on the screen, after that the backlight turns off (I still can see the sony logo a short time) and the TV starts blinking 6 times with the standby LED.
    Has anyone the service manual for this TV?
    Thanks!
  • Hauke
    • Jan 2017
    • 77
    Re: Sony KDL-65W855C blinking 6 times - service manual?
    I did some basic measurement now:
    The TV has 2 connectors on the PSU for the LED backlight. They are rated for: 173.6V - 250.3V at 740 mA.
    I measured them with an oscilloscope at the moment of the short backlight flashing. One rised up to 203V and the second rised up to 296V. After that the PSU shuts down.
    So I think one LED strip is damaged. I will check this now.
    • Hauke
      • Jan 2017
      • 77
      I swapped the two pins on the LED Strip connector.
      Now the other channel of the LED Driver rises up to 296V.
      I think now It is clear, that the error is in one LED Strip.
      I will keep you updated, if you want.
      • Cal_G
        • May 2018
        • 4
        • England
        Just registered to say I have exactly the same problem. I've replaced the power board and main board and it's exacty the same.
        Service manual is here:
        https://servicemanuals.us/sony/tv/kd...l-75w855c.html
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          If the led voltages rise identically to the earlier post then you too look as though you have led issues.
          • Cal_G
            • May 2018
            • 4
            • England
            It's all over my head sadly. The set is under 3 years old as well which is annoying.
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              Can you post some clear sharp photo's of your circuit boards and one showing how they interconnect.
              • Cal_G
                • May 2018
                • 4
                • England
                I can post a slightly bad picture with the back panel off that shows the PSU and main board. I'm limited to space and time for clear photo's.
                • Cal_G
                  • May 2018
                  • 4
                  • England
                  https://ibb.co/ig03Ld
                    • 12183
                    • U.S.
                    Like one supertech here said, forgot exactly which one, "it's gonna be bad led/s 92 percent of the time"
                    • bstewara
                      • Jun 2019
                      • 40
                      If the main board part number is A2071514A I would be interested in buying it.
                      I’m looking for a good main board for my Sony.
                      Please text Randy at 816 689 7150
                      • YasaCh
                        Sony kdl 40p5500 red light keeps blinking 3 times
                        by YasaCh
                        Hello...
                        my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                        i opened the back cover no sign of damage on the powery suply or motherboard
                        when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                        another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                        07-07-2025, 11:53 AM
                      • NolesFan
                        Sony kd-85x85j LED blinking red 6 times
                        by NolesFan
                        I know the 6 blinks are a backlighting issue, but when I pulled off the back cover and turn it on, the is a white flash from with the panel then I hear what sounds like a relay trip and the TV goes into the 6 blinking light code. Before I pull all the electronics off and checking the individual strips, there is a on the power board, a harness with 4 wires that run thru the panel, which are what I believe are the LED lines, but Im not a tech so no clue. Wires read OUT 1 + & - and OUT 2 + & - My first inclination was to remove the power board and use my LED tester and go to each + &...
                        03-16-2025, 11:50 AM
                      • ahmarzo
                        Hp 15-cs laptop 5 times dc jack blinking white
                        by ahmarzo
                        I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
                        First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
                        Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
                        But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
                        12-28-2024, 04:46 AM
                      • shahnld
                        Sony kdl 65xg9505 green amber blinking
                        by shahnld
                        Good Day.
                        I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                        i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                        green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                        01-03-2024, 03:05 PM
                      • James007$
                        Sony KDL-70R550A red led blinking 5 times, troubleshooting
                        by James007$
                        Hey mates! my tv keeps blinking 5 time and when I turn on it doesn't show anything on screen and it turns off after a few seconds.
                        I am having the same issue as this guy: https://www.badcaps.net/forum/showthread.php?t=65126 and following his method,
                        I have removed the right bottom ribbon cable and the tv starts but the picture showing but not very clear and good, I attached a pic.
                        Can anyone point me to the next step I should take? thanks!...
                        07-09-2022, 05:03 PM
