Need schematic for Visio LC420
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: Need schematic for Visio LC420
Sorry I forgot but I confirmed that if PSON is not connected to the 5vstby rail, the 12vdc will disappear along with the signal measured at T703. The supply of the Toshiba power Mosfets has nearly dried up. I have not determined these inventor switchers are bad by diode checking as most of my free time today was removing the shield to gain access. Got any sources for these if I find a bab one. Like replace in pairs. Any discovery on the PWM chip we have both been looking to get the pin outs?
BTW, the Ion/off is connected but did not remove the 5v to see if was any effect on the drive signal.
ThanksComment
At this point it sounds to me that the PWM IC is working and it is driving the Gate drive transformers. BTW, are you working on the original power supply board or the replacement power supply board?Never stop learning
The replacement. I have a few missing parts on the original board that I am replacing from my last Digikey order that has not yet arrived bringing it back to its original condition. I also have the replacement board from SJ I have not yet returned. I will be making the same checks on my original board to see if it is at least on par with the replacement.
I wish I had an isolation transformer so I could use my scope to check the intermediate driver transistors on the secondary side. There isn’t much left her but the final power MOSFETS, it’s just seems quite odd that all three boards would suffer these specific failures.
As you say, the PWM IC seems to be working but that waveform sure contains overshoot artifacts I wouldn’t have expected. Could be my probe trimming as well. I’ll report back on the diode test modes of the driver FETs.Comment
OK, so the switched Transistors are turned on and supplying the Voltages, one end of those two resistors should go to the VCC pin of the PWM IC.
It sounds like the IC is working, you can disconnecting the the BL-ON force on resistor to see if the 45Hz will go away or not, I actually expecting higher frequency than that.
BTW, what is the LCD panel model number?
ThanksComment
50KHz ~80KHz.
45KHz may be OK, at this point we know that we are getting the drive Voltage to drive the Gates of the MOSFETs so the MOSFETs should be switching right now.Never stop learning
Further testing on power MOSFETs show that all four TK4A60DA drivers measure the same using simple power or switching action using diode mode on DVTM. This includes Q701,706,715, 720.
Q801, 802 are both K3569 now replaced by 2Sk3569 measured differently exhibiting source to drain full conduction to a gradual isolation state without discharging the gate. Both devices measured the same.
I did not replace the TK4A60DA devices even though I had new devices on hand but did not have the 2Sk3569 so I was unable to compare the original devices with the new ones. My question at this point would be given the drive level and power of this application, is the diode mode testing completely valid from your experience.
Please advise.
Thanks!!Comment
by ShadowAiHello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,... -
by Gau_sahaSir,
Do anybody have IP4L23D CODE BN44-00297A schematic of samsung monitor ? I need the schematic .Please share with me if anybody have it.
Thanks.
i-
10-04-2023, 04:47 AM -
by diamonI have bought a not complete and defective Dell Latitude 5520 for parts (needed the networkconnector (RJ45) to repair a other board).
Have repaired the other board (Dell Latitude 5540) and I wanted to know if I could find out what is wrong with the 5520 board (SouthPeak15 TGL MB 8L 19819-1) and perhaps repair this one also.
After connecting the USB-C charger (both USB-C ports on the laptop, does not have an other option) and pressing the power button, nothing happens (no lights or fans, no capslock).
Have checked with a thermal camera, and there are a couple of things...3 Photos -
by TinkerTronHey everyone,
I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
Instead, here's what's been bugging me so far:
The schematic...3 Photos-
by atunguydIi wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...-
Channel: Schematics and Boardviews
- Loading...
