ESTAR LEDTV40D2T2 Firmware
    • 12206
    • U.S.
    Re: ESTAR LEDTV40D2T2 Firmware
    Originally posted by antas
    The chip is on the programmer now. Can't check the difference. It should be heated enough because I took it with the airgun from the mainboard.
    Lol, no I meant did you try freezing or heating as suggested in post 11.
      • 12206
      • U.S.
      GD25Q64 datasheet http://www.alldatasheet.com/view.jsp...25Q64&sField=4
      • vinceroger69
        • Mar 2012
        • 6714
        maybe whilst the chip is on the programmer freeze it then read it again and save it reload that onto a replacement ic if needed and re try tv you have nothing too loose, failing that maybe time too look for a main board for your set what lcd screen number is used in your tv
        • antas
          • Jul 2014
          • 148
          • Ireland
          what LCD screen number is used in your tv
          Freezing or heating of the chip makes no difference at all. The chip cannot be erased at all... Will look for the same chip from donors.
          LCD screen number:
          • antas
            • Jul 2014
            • 148
            • Ireland
            suspicions about the unit UA1 beside IR&Key connection. 12v comes to pin 48 but nothing on pin 1
            • diif
              • Feb 2014
              • 6978
              • England
              #26
              What's the markings on that chip ? Have you checked the datasheet ?
              Did you find a replacement EEPROM ? I have some new 25Q64FVSIG here if you need one.
              • antas
                • Jul 2014
                • 148
                • Ireland
                #27
                Thank you, diif. How can I get this chip of you?
                • TheUser
                  Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                  by TheUser
                  Hello to everyone ,
                  This is my first post here, and i would like to share with you a small story in case you can help me.
                  Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                  All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                  I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                  02-10-2024, 02:07 PM
                  Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                  by sam_sam_sam
                  This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                  I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                  I am comparing them to a brand new one that I installed
                  The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                  I going to let it run for several days before I remount back on the wall next to the...
                  09-05-2024, 06:48 PM
                • gurj1979
                  Ubiquiti firmware help. US-8-150W POE
                  by gurj1979
                  Hi guys.
                  I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                  Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                  So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                  Got New chip and writes good.
                  THE PROBLEM...
                  It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                  Does anyone have a Good Firmware I can have?...
                  07-22-2024, 05:13 PM
                  HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                  This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                  09-12-2024, 02:30 PM
                  HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
