Panasonic TC-60PS34 Dead As The Proverbial Doornail...
  • Michale32086
    • Nov 2011
    • 1453
    Got in a really nice, clean Panny TC60PS34... Normally, the bigger plasmas I just pass on, but this is too nice not to at least make an effort..
    There is no visible power and the power button felt... "squishy"...
    So, I took a look.. Looks like the power button has seen better days.. So, I get my hopes up and try to turn on with a remote..
    No such luck...
    Turns out that when I say "dead" I mean really dead.. No power clicks, no relay clicks no nothing when plugged in..
    Fuses all check out..
    I am always confused about Panny's designations on the board, so I am hoping someone can walk me thru checking voltages on the Sustain boards..
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Panasonic TC-60PS34 Dead As The Proverbial Doornail...
    Check this blue capacitor highlighted in my pictuure on the main power supply. Is it blown open. Look close.
    • freakaftr8
      • Oct 2012
      • 3743
      The IC underneath the heat sink near that capacitor is known to short circuit blowing this capacitor. If it is blown I would either take that aluminum sync off and look at the IC and replace it along with the capacitor. I never remembered the specs on the capacitor as I didn't write it down at the time I repaired one. This controls the PFC circuit.
      You may also find a power supply on the Internet relatively inexpensive. The sub supply is most likely fine just the main bigger supply is the one you wanna replace
      • jetadm123
        • 2169
        Coppell TV did a YouTube video for a different Pany, but with same power supply as yours:
        www.youtube.com/watch?v=EShySnyZl1E
        He basically saw the same capacitor(c404) burned up as Freak mentioned. And he does check the IC under the heatsink mentioned above and finds it shorted. Also, a diode should be checked (see video) with that IC removed.
        • Michale32086
          • Nov 2011
          • 1453
          Thanx for the replies.. It was poker night tonight..
          I'll check it out first thing in the AM..
          Thanx again...
          • Michale32086
            • Nov 2011
            • 1453
            OK Just got in.. Haven't pulled the board out yet to look at the under side, but this is what it looks like on top..
              looks fine to me
              • Michale32086
                • Nov 2011
                • 1453
                Yep.. According to the video, that cap had an obvious burn out.. This one looks clean..
                Gonna pull the board and look at the underside..
                Just as soon as we get out of the 30s Fahrenheit temp wise...
                • Michale32086
                  • Nov 2011
                  • 1453
                  OK Braved the cold...
                  Here's what the backside looks like.
                  Looks clean...
                  "Light is green.. Trap is clean.."
                  -Ray Stantz, GHOSTBUSTERS
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Do in ohms test and check across that C404 for a short. That light blue spot from that cap looks suspicious. I have seen these short but not show symptoms on the outside when they blew open before.
                    30 degrees in Florida! Damn, the world coming to an end! We had snow in Sacramento last week....
                    • Michale32086
                      • Nov 2011
                      • 1453
                      Will do.. I have a SHARP 52 LED SMART on the bench I am just finishing up on. Give me about 10...
                      I know, right! This has been a brutal cold winter.. Last month we had a week where the highs barely crawled into the 40...
                      Kinda a pain when your work area is outdoors..
                      • Michale32086
                        • Nov 2011
                        • 1453
                        OK, forgive me if this is way off base.. I am a rank amateur when it comes to weilding a volt meter..
                        There is no direct short across the CAP C404...
                        When I use the probes as pictured, I get a reading of 17.4 MU that slowly counts down...
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          Yea you do what you gotta do. That's how it goes
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Check between here and here on ohms test. If it's shorted or reading 0 or making the meter beep, the IC is bad.
                            This area is under C404 and the IC under the heat sync pin 3
                            • Michale32086
                              • Nov 2011
                              • 1453
                              I can order a replacement board for around 50 bucks.. But I hate to pack it up and then unpack it when the board comes in...
                              Plus it would be nice to have it out for the weekend..
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                OK looks like that IC is apparantly good. I would check voltage across the main on the power supply to see if you're idle at 170 V DC around there.
                                Also I'm pretty sure you checked all fuses?
                                • Michale32086
                                  • Nov 2011
                                  • 1453
                                  Yep.. All fuses are good.. One sec for the voltage checks..
                                  • Michale32086
                                    • Nov 2011
                                    • 1453
                                    Pin 6 on the Main Board Connector had 5.07V.. All the rest were either 0v or mV range...
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      Looks like pin6 is standby. Is there a legend on the power supply? Try pulling P34 and or the connector below it. Maybe thus will bypass PS-on.
                                      We need to get readings on the main caps of the power supply to see if HOT side is in standby. Like I said before there should be about a 170 V DC across the main capacitor legs on the power supply in standby
                                      • Michale32086
                                        • Nov 2011
                                        • 1453
                                        Nope.. No legend I can find...
                                        Have to be a little more explicit. I usually don't get into the nitty gritty of this kind of stuff.. Usually just replace the board..
                                        Any specific caps I should be checking?? I mean, which are the main caps??
                                        Thanx for all the help..
                                        • badcappo
                                          Dead Panasonic Viera TX-P65STW50 Plasma TV
                                          by badcappo
                                          Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                                          Diode type G972s6 - D101 with a short
                                          Mosfet 06N90E - Q301 shorted
                                          Fuse T5AH 250V - F103 blown
                                          Diode D301 shorted
                                          Relay DG1U-17VDC II - RL001 blown
                                          I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check πŸ˜€...
                                          11-24-2024, 11:27 AM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                          11-20-2024, 08:52 PM
                                        • Super360
                                          Panasonic TC-P50G10 DEAD
                                          by Super360
                                          Hi everyone I have a plasma here that is absolutely dead no power light. When I press the power button the relays click the fan spins for a second then it's dead and nothing happens on the screen. Anyone have any suggestions?
                                          12-27-2021, 11:40 AM
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • AquaMan Ua
                                          by AquaMan Ua
                                          05-17-2025, 09:40 AM
