Panasonic TX-L32U3B will not power up
  • Bing
    • Nov 2017
    • 17
    • United Kingdom
    I have a 32" panasonic TX-L32U3B LCD tv that i have that i am a bit stuck on,
    when tv is plugged in and turned on all you get is green led on front on, when i first tried it did briefley come only for few seconds, the psu looks ok there is no legend for the rails but voltages are as follows
    0 v
    0 v
    0 v
    0 v
    3.1 v
    0 v
    0 v
    5.8 v
    2.8 v
    0 v
    16.1 v
    16.1 v
    16.1 v
    0 v
    5.8 v
    when i tried to power up tv with the psu output removed i did not even get green light on.
    Any help on this would be great thanks for reading.
  • Bing
    • Nov 2017
    • 17
    • United Kingdom
    Re: Panasonic TX-L32U3B will not power up
    Here are images of main and power pcbs
    • Bing
      • Nov 2017
      • 17
      • United Kingdom
      Better image of main board
        • 12206
        • U.S.
        https://www.youtube.com/watch?v=4v8DcqCNG4A testing power supply.
          • 12206
          • U.S.
          0 v
          0 v
          0 v
          0 v
          3.1 v
          0 v
          0 v
          5.8 v
          2.8 v
          0 v
          16.1 v
          16.1 v
          16.1 v
          0 v
          5.8 v
          By this, do you mean you unplugged powersupply from mainboard?
          • Bing
            • Nov 2017
            • 17
            • United Kingdom
            I got the voltages from the main board being plugged into PSU but after I got readings I then disconnected mainboard after just to see if backlight came on.
              • 12206
              • U.S.
              Thats a tough one, very strange that there are no legends.
                • 12206
                • U.S.
                With a legend its not to hard to figure out how to jumper the powersupply to try to turn on backlights, I have no clue without a legend tho, might need a schematic.
                  • 12206
                  • U.S.
                  Guess its also possible that the backlights shoud have come on with mainboard unplugged but something else is wrong.
                    Can I see the pictures of the whole backside of the TV showing all the boards?
                    I also need the pictures of the TV model number sticker to see if it has chassis number printed on the sticker or not
                    Chassis LA14?
                    • Bing
                      • Nov 2017
                      • 17
                      • United Kingdom
                      Here are the images you asked for thanks for replying
                        OK, the chassis is GLP26, so will have to search ELEKTROTANYA to see if they have service info there or not.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          service manual may not be exact match but same chassis
                          • will62
                            • Dec 2016
                            • 229
                            • usa
                            Also found a schematic for the TNPA5361 board. Note that on the OP's voltage readings, there is 3.1V on the INV_SOS pin. The signal comes from the driver IC's "fail" pin.
                            • Bing
                              • Nov 2017
                              • 17
                              • United Kingdom
                              Ok that's interesting so does that mean that the fault is with the IC or does inv mean inverter circuit? Is so how would I go about troubleshooting this? Thanks for replying
                              • will62
                                • Dec 2016
                                • 229
                                • usa
                                This is from another Panasonic set. The component numbers are probably different, but it gives you an idea of how Panasonic uses the "INV_SOS" signal:
                                "The INV_ON/OFF command (high) of the MPU, IC8001 of the A board,
                                enters the P-Board to turn on the inverter circuit. The inverter circuit
                                produces AC voltages that power the backlight fluorescent lamps . The
                                output of the inverter, approximately 2Kvp-p is provided to the LCD panel
                                via the connectors P5, P6, P7 and P8.
                                To avoid catastrophic failures, when the inverter circuit is defective, the
                                INV_SOS command is output to IC8001 to trigger the shutdown of the TV."
                                The INV_SOS signal is coming from the inverter driver IC, so I would say that you have a problem with the inverter or lamps.
                                I'm trying to locate a datasheet for the IC.
                                  • 12206
                                  • U.S.
                                  Great info will62 and very well explained.
                                  • will62
                                    • Dec 2016
                                    • 229
                                    • usa
                                    Thanks nomoresonys. I couldn't find a datasheet on the BD9247F. I did look at similar chips from the same chip maker, and it appears that they don't follow a consistent pattern with the "fail" pin. On a BD9240, a low signal on fail is an error. On the BD9244, a low signal is normal. So, not sure if low or high indicates an error with this BD9247F.
                                    Read the linked thread. He also had a high signal on the INV_SOS. He did a reset to resolve it:
                                    https://www.badcaps.net/forum/showthread.php?t=67544
                                    • Bing
                                      • Nov 2017
                                      • 17
                                      • United Kingdom
                                      Well I just done a reset same as the they did in the link and TV is now working fine!! Thanks for that much appreciated!
                                      • will62
                                        • Dec 2016
                                        • 229
                                        • usa
                                        Hey, that's great!
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • oldschoolgamer
                                          Panasonic TX-50EX700B Won't Power On
                                          by oldschoolgamer
                                          Hi. I have a Panasonic TX-50EX700B which hadn't been used very often for some time. Recently it started getting used a little more often, until one day it just refused to power on with the red LED blinking 13 times. Upon researching, it turned out it apparently had something to do with the 5v power line, so I assumed it was probably the power supply.
                                          I purchased a power supply for the TV from a seller that claims that it works fine and was just taken from a TV with a broken screen. After fitting the new power supply and trying the TV, I was greeted with the power LED being red for...
                                          10-26-2022, 04:15 PM
