Re: Akai LCT37Z4AD Has very dim backlight
The last few times I’ve tried powering on the TV I did not see any back lights. Initially I could barely see the Akai logo on startup.
There are some power supplies on ebay one of m is 19 bucks +4 shipping.Leave a comment:
Would this help?Attached FilesLeave a comment:
Yes. The two cables that are unhooked in the 2nd pic. One cable for each inverter board. If you super size the pic you can see several pins (5 per connector) labeled 24v. Since I have no 24vdc going to both inverters, I definitely have a power supply problem. Another problem I've found is someone has previously tried soldering this power board and may have done more harm than good.Leave a comment:
Can you please verify that again?Leave a comment:
Yes, for the Master and the Slave.Leave a comment:
So at this point you do not have 24VDC, 0VDC per you report on the Inverter fuses.
Checking Voltages on the power supply board will be next.
Can I get straight shot pictures of the whole bottom side of the power supply board?
Megmeet MLT586K may be close to your Megmeet MLT586A board.
http://www.shopjimmy.com/megmeet-mlt...er-supply.htm#
As you can see, there are pin labels on the bottom side of the board that we need to check.
You can also disconnect both 24VDC power cables going to both inverters to see if the 24Vdc out on the power supply will be present or not.Leave a comment:
You can also disconnect both 24VDC power cables going to both inverters to see if the 24Vdc out on the power supply will be present or not.Last edited by budm; 02-25-2018, 06:48 PM.Leave a comment:
From the schematic pin8 is BLon, pin7 pwm, pins 1 2 3 v-in with gnds 4 5 6. A 2007 model so good learning project.Leave a comment:
I'm not sure but for 19.34 for that master inverter, I would buy that, if it isn't the problem it doesn't hurt to have a spare and it's an easy way to eliminate the inverter if the one you get is a good one, but if another problem is blowing things on the inverter then that would be bad.Leave a comment:
I checked the fuse on the Slave inverter board and it has continuity. Where should I go from here?Leave a comment:
I have no DC voltage on either end of the fuse of the master inverter board. But it has continuity when tested with power off and meter set to continuity. The only fuse I see on this board is a square ceramic type labeled 60v 6.3A. I can't test the Slave inverter board fuse voltage due to it being mounted under the power supply. But I could remove power supply and check for continuity. Thanks budmLeave a comment:
OK, they look OK.
TP7 looks to be for BL-ON
TP8 looks to be for DIMMING, at 3V the backlights should be quite bright. 5V = Max Brightness, 1V (typ.) = minimum dimming.
So you do have 24Vdc on both ends of the fuse with ref to GND on the MASTER and the SLAVE inverter?Leave a comment:
Hi budm Here's the voltage checks and a pic of the master inverter board. And Yes, that's the same board on ShopJimmy. Is those voltage readings ok? Or does that tell us the master inverter board is the problem? Thanks again for your help.
TP7: 5.0 vdc
TP8: 3.0 vdcLeave a comment:
I've looked at the Service Manual and can't figure out the location to check the dimmer voltage supply. I've looked at the power supply board also, and can't locate it. I did check the voltages on the cable going from the power board to the Slave inverter board, and only the first red & white wires has voltage. That first red wire has 5.03vdc, and the white wire has 2.95vdc.
The master inverter board has the power supply board minted directly on top of it , so it's about impossible to check it's voltages. Thanks for your reply budmLeave a comment:
It looks like you have at least one as far as i can see on the power board under the metal shield
I have never seen bulging caps on tuner boardsLeave a comment:
Look like you need to look at the Master inverter board.
Can we see the pictures of the Master?
Is this the Master Inverter board you have?
http://www.shopjimmy.com/akai-pb-051...t-inverter.htm
If it is, then check the DC Voltage on TP7, TP8 and report what it has.
http://www.shopjimmy.com/catalogsear...Akai+LCT37Z4ADLeave a comment:
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by C152HeavySamsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
Summary for TL-DR readers:
• VCC pin (18) of PFC... -
Assuming...7 Photos -
by lostoneHello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...-
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
- Loading...
