Akai LCT37Z4AD Has very dim backlight
  • TubeJunkie
    replied
    Re: Akai LCT37Z4AD Has very dim backlight
    Here's a picture of that inverter board that's mounted under the power supply board. I didn't see anything marked dimmer or dim. I did notice the copper ground contacts (screw points) we're corroded, so I cleaned them. But didn't make a difference. This inverter board is smaller than the other one. So I'm guessing it's the Slave.
    replied
    I can see the inverter board under the metal shield, there may be pin lable on the inverter connector to tell you which one is the Dim control pin.
  • TubeJunkie
    replied
    Sure. It has the built in DVD player on the left. I have the service manual, but it's too big to upload. Web link to the SM below. You can download the entire manual once you get there. Thanks for taking the time for me. Much appreciated.
    https://www.manualslib.com/manual/10...2.html?page=57
    replied
    OK, this looks like one of those Polaroid/Westinghouse chassis, it does not have the BL-ON or the DIM control passing through the power supply board.
    Can I see the picture of the whole backside of the TV?
  • TubeJunkie
    replied
    I've looked at the Service Manual and can't figure out the location to check the dimmer voltage supply. I've looked at the power supply board also, and can't locate it. I did check the voltages on the cable going from the power board to the Slave inverter board, and only the first red & white wires has voltage. That first red wire has 5.03vdc, and the white wire has 2.95vdc.
    The master inverter board has the power supply board minted directly on top of it , so it's about impossible to check it's voltages. Thanks for your reply budm
    replied
    You should check the Dimming control signal Voltage to see what it is right now.
  • TubeJunkie
    started a topic Akai LCT37Z4AD Has very dim backlight
    Hello. I have an Akai LCT37Z4AD TV that I picked up from the recycle center. When I powered it on, The power light goes from blue to green, but it had no backlight. I opened it up and found bulging caps on the Tuner/input board. I changed those bad caps, and powered it back on. Now I have a very faint backlight. I can faintly see the Akai logo when starting up. I know I need to check voltages on the power supply board next, which I will be doing ASAP. But I don't want to waste my time if I have bad backlight boards. Any advice will be greatly appreciated. Thanks!
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • C152Heavy
    by C152Heavy
    Summary for TL-DR readers:
    • VCC pin (18) of PFC...
    01-11-2023, 02:53 PM
  • lostone
    Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
    by lostone
    Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
    First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
    When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
    05-19-2024, 11:40 AM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
