Hisense 50k23dg with power issues?
  • punkityn
    • Feb 2018
    • 6
    I replaced the main board on my TV but it's still having the same issue: When you plug it in, the red light doesn't always stay on so you can press power. I have to fidget with the AC power in and get it just right (seems kind of random really) and then the light will stay on and there's a chance the TV will power on when you press it. If not, you have to unplug and replug till you find the sweet spot and the light stays on again.
    Once the TV is on though it powers on and off fine. But once you turn it off for an hour or so and comeback, you would think the TV is totally dead unless you were an obsessively persistent nutter like me.
    Thoughts?
  • R_J
    • Jun 2012
    • 9588
    Re: Hisense 50k23dg with power issues?
    Check for poor solder connections on the a/c input jack on the power supply board, you could also have a bad cap in the standby circuit
    • punkityn
      • Feb 2018
      • 6
      Ok, sorry. That's what I actually replaced then, the power supply board. It turns out it wasn't the exact same model (pulled from the same model TV though) but it functions just like the other one did, with the same problem. I too assumed it must be something loose on the AC in
        We need good clear pictures of the whole backside of the TV showing all the boards so we can see what we are dealing with.
        • punkityn
          • Feb 2018
          • 6
          I'm currently watching it, so I'm unable to take a pic of mine right at the moment... but this is identical:
          I noticed one time that when I it was plugged in, but the right light not on to try to turn it on, that the chromecast I had plugged into it was still getting power.
          • punkityn
            • Feb 2018
            • 6
            Here's the board I replaced. New board is different but has same prob
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              With the TV plugged in, whether you get the red light or not, are you getting Std-By voltage on the PSU?
              • nomoresonys
                • 12274
                • U.S.
                https://www.youtube.com/watch?v=TELvc0thP34 how to video for testing power supply.
                  The pictures of the board is not clear enough to read the pin names.
                  So if you check the Voltages of all the pin of the connector of the power supply that goes to the main board, what DC Voltages do you get on all the pins.
                  When you report the readings you MUST PUT DOWN THE PIN NAME AND FOLLOW BY THE VOLTAGE reading of each pin.
                  It is very important to follow the request and the instructions.
                  Just remember that we do not have the TV or the boards in front of us to look at so the more details you provide the better chance of getting the problems fixed.
                    If you look at time stamp of 2:33, he said to set the meter to DC CURRENT, now if some one is a noob and set the meter to DC current then try to probe the output of the power supply he may see nice smoke coming from the board or the meter. So be very careful when watching the YouTube.
                    • nomoresonys
                      • 12274
                      • U.S.
                      Volts dc is what I use too, never had 1 go up in smoke yet.
                      • nomoresonys
                        • 12274
                        • U.S.
                        Tampatec is a pro, he knows what he's doing.
                        • nomoresonys
                          • 12274
                          • U.S.
                          "The you tube" is a GREAT source, there's people all over the world that have vast knowledge, it's not something to be threatened by, no room for big egos or condescension, box it up. I don't care how much "expertise" someone has, if it comes with insults and sarcasm, you can keep it, and as far as helping me fix it, I re-read my thread, all you really did was insult me, I don't know what kind of trip you are on but that's your problem not mine. I have helped many people on many forums and all without being rude to them, go read some of your posts, maybe nobody's took the time to tell you before but hey I go the extra mile. I wasn't raised to be rude, that's why I don't put up with it.
                            Well, when some one instruct you to out meter in DC AMP to measure the Voltage, do you think that is not a good instruction?
                            Try that yourself and see what will happen! It is ego, it about proper instruction!
                            Listen to what he said!
                            "I re-read my thread, all you really did was insult me," https://www.badcaps.net/forum/showthread.php?t=67776
                            It took 12 posts to get you to set the meter properly.
                            • Andrew F. Ali
                              • Jan 2014
                              • 2450
                              • Trinidad & Tobago
                              well, when some one instruct you to out meter in dc amp to measure the voltage, do you think that is not a good instruction?
                              +100
                              • nomoresonys
                                • 12274
                                • U.S.
                                No bud, had no problem with that, it's you bagging on every post, you even ragged on a pro like tampatec, it's you with the ego and it's you who is rude.
                                • nomoresonys
                                  • 12274
                                  • U.S.
                                  It's volts dc bud, what's your malfunction? you look at "the youtube" all the time, do you really think tampatec doesn't know how to meter a power board???? You're just trying to bag on me, so you can knock it off.
                                    Go back and listen to his instruction at 2:33!
                                    "Put it in DC current" when the Meter shows DC V.
                                    What do you set the meter to when instruction tells to set meter in DC Current, or tell you to set to DC Volt?
                                    • nomoresonys
                                      • 12274
                                      • U.S.
                                      I and everyone I know set it at 20 vdc.
                                        So did you go and listen to the instruction? for the DIY that still learning and listen to the instructor on what to set the meter to can put themselves in worst situation due to improper instruction..
                                        Same instruction as not to touch anything in the deadly hot side of the circuit with your hands or your body, proper instruction is important.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • DoubleBogey817
                                          HISENSE 65H6510G (13 AUG 2020) - POWER ISSUES
                                          by DoubleBogey817
                                          HISENSE 65H6510G (13 AUGUST 2020)
                                          When powered on, initial splash screen (HISENSE ANDROID TV) displays for a few seconds then power shuts off. Tried updating firmware with USB flash drive (can't find 4GB drive but did format larger drive in FAT32) with no luck. Flash drive would be accessed but would never get to the update process. I have ordered a board (RSAG7.820.7911/ROH, PART# 242585) from eBay which will arrive in a few days. Does anyone have any input of whether I am chasing down the right trail or should I be trying something else? I appreciate your time and wish to say thank...
                                          02-16-2024, 10:58 PM
                                        • zlr8r
                                          Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                                          by zlr8r
                                          hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                                          Ill try and give as much info as I can.
                                          Dell Inspiron 17 (7786) Laptop
                                          Service Tag: 5J0NHT2
                                          Bios: 1.9.0
                                          When I received this , it would only flicker on the KB backlight for a second, then off and on.
                                          Then it started getting weirder!
                                          Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                                          12-12-2023, 09:31 PM
                                        • sli4
                                          Original NES power issues
                                          by sli4
                                          I recently turned on my old NES to find the red light won't go on at all. When powered on it shows black bars on the tv and a loud buzz through the tv speakers. Powering it off, the buzz goes away and tv goes back to normal (white snow).
                                          I tested the power supply itself and it is outputting 9V as it should - first two solder joints on the board at the power port show the same.
                                          Here's where it starts getting funky - When powered on, one side of the 7805 voltage regulator is showing 18V and the other is about 8.7V (center 0).
                                          On the big blue connector I get...
                                          11-28-2024, 12:52 PM
