samsung un48j5000afxza choppy picture horizontal lines
  • whogan1369
    • Jul 2017
    • 5
    • usa
    Thank you all in advance. I have a samsung un48j5000afxza that has horizontal lines going through it and the picture skips. I can hear a high pitched sound coming from the tcon board that matches the skipping (almost like a consistent beep). It sounds like electrical noise.
    When I unplug the left side of the tcon board it continues, but when I unplug the right side it stops the skipping, and that half of the screen works fine.
    The skipping high pitched sound comes from the tcon board. There are no swollen caps on the main board. Do you think the tcon board is bad, or could this be an lcd driver or panel issue? Any help is appreciated.
    Re: samsung un48j5000afxza choppy picture horizontal lines
    You need to check the resistance of the caps (to see if they show low resistance) on the tab bonding board, the board that has the LCD flexible PCB's attached to the board and where the flat cable from the T-con board attached to.
    • noipi
      samsung Oled 65 Horizontal Lines and Flicker
      by noipi
      I have samsung 65", i bought it last january 2025 2nd hand, and last month got this problem, flickering with horizontal lines. any inputs if this is Motherboard replacement or the LCD tcon, can someone help me what to do, i saw in YT, someone says that to cover the flex connector of the unit. Sorry for my english i am asian. i include the video so someone can help me out. thanks...
      10-14-2025, 02:11 AM
    • Ihandyrepair
      Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
      by Ihandyrepair
      Hi guys
      I just started fixing 4k TV few months ago. so I am still learning a lot
      I got this tv from friend complaint is ghosting or horizontal lines on image.
      never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
      then it started to show the ghosting white image.
      I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
      it has 3 thin small boards at the bottom of the...
      12-05-2022, 04:18 PM
    • Rubenlily
      Samsung QE50Q67TAU - horizontal lines
      by Rubenlily
      First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
      I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
      I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
      I'm no expert but I've done the tape...
      08-16-2023, 01:12 PM
    • x_orange90_x
      Samsung UN46C8000XFXZA vertical bars/horizontal lines
      by x_orange90_x
      I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
      The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
      09-04-2023, 12:09 PM
    • arctor
      samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
      by arctor
      hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
      04-26-2025, 05:22 AM
