Seiki 32 led lcd tv backlight stopped working
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    Me again with another free tv
    Tv powers on but backlight wont turn on
    I check voltages to the backlight connector....and on standby the voltage is 48v
    When tv powered on the volatage goes to 58v.....caps visually looks fine on the power supply board and that voltage reading does seem like it could be fine or not?
    Im thinking its another bad led strip issue....very common in led lcd tvs
  • shelby5041
    • Feb 2009
    • 1505
    Re: Seiki 32 led lcd tv backlight stopped working
    Tv does power on with blue indicator light and all ps voltages seem ok and there is an image on the screen...just no backlight
    • shelby5041
      • Feb 2009
      • 1505
      Here is photo of the cheap made all in one board lol
      • shelby5041
        • Feb 2009
        • 1505
        Model is SE322FS
          Picture of the board is low res so I cannot zoom in to look at the board in details especially at the LED connector.
          Are there any labels for the connectors' pins?
          We also need to see how may wires there are on the LED connector.
          • shelby5041
            • Feb 2009
            • 1505
            Hey nevermind....i worked on one of these few years ago and just remembered it was a led strip issue....i looked at an older badcaps thread i made on this tv and 58v going to led connector is a good voltage so im confident to be a bad led strip on this one also....
            • shelby5041
              • Feb 2009
              • 1505
              Its a 2 wire to led strips...
              But i do believe its a led strip issue since i have 58v going to connector similar to a previous repair i did on same model tv...
              • shelby5041
                • Feb 2009
                • 1505
                This pic better?
                • shelby5041
                  • Feb 2009
                  • 1505
                  On my last repair i just removed 1 backlight strip and ran tv with 2,strips not 3....and it looked fine....but i dont have the tv anymore..
                  Would this cause an issue in time since the input voltage to leds are same but im running less leds?
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    LED power supplies are current sources so you will not be running the same voltage with less leds, you will be running less, the power supply will automatically adjust the voltage to keep the same current thru the leds, they should work fine with any number of LEDs up to the maximum they are designed for running, you can remove as many as you like and they will still get driven the same.
                    A working TV? How boring!
                    • shelby5041
                      • Feb 2009
                      • 1505
                      Not sure i understand....does the voltage stay the same and the amps adjust depending on needs?
                      • shelby5041
                        • Feb 2009
                        • 1505
                        Oh voltage does adjust.....ok
                        • shelby5041
                          • Feb 2009
                          • 1505
                          Ok well can u explain this then....when i checked the voltage at led power connector i had the led end disconnected on ps
                          So i checked the voltage without leds connected and i got about 48v on standby and about 58v when tv powered on
                          How can this be with leds disconnected...if umsay the voltage adjusts....why would itbadjust to 58v with nothing drawing current?....
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            EB803 looks as though its started to vent?
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              It is not made to work with the load disconnected thus all such measurements are irrelevant. Try connecting a few strips and then remove one and see what it does.
                                You have input Voltage feeding the Boost converter circuit, when PS-ON is present, the Boost converter will boost the Voltage up to the needed Voltage for the total Vf of the LED string + the Vdrops on the PWM controlled Power MOSFET on the return side of the LED.
                                That MOSFET is the device that maintain the constant current thorough the LED string, so when you have LESS LEDs connected then the Volatge drops on the MOSFET will be increased so that the current will be maintain at constant level but that means the MOSFET will run hotter so you must be really careful about bypassing the LEDs. The boosted Voltage at the LED will be a lot higher if there is no LEDs connected, so to prevent the over Voltage condition, the boost converter will go into shutdown.
                                • shelby5041
                                  • Feb 2009
                                  • 1505
                                  Ok thank you
                                  • shelby5041
                                    • Feb 2009
                                    • 1505
                                    thats not my board photo..it is a stock board from shop jimmy
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      • Romania
                                      Is the current-limiting MOSFET a linear circuit? I'm asking because i haven't really done a lot of backlight circuits.
                                        The MOSFET is PWM controlled and it is on the LOW side of the circuit instead of on the HIGH side of the circuit.
                                        The Anode of the LED string is connected to the Boosted output pin, the Cathode is connected to the Drain pin of the MOSFET, the Source pin is connected to the current sensing resistor, then the other end of the resistor is connected to GND. The Vdrops on the sensing resistor is used as the feedback to feed the LED backlight driver IC, the output of the IC is then drive the Gate of the MOSFET with PWM signal to main tain constant current through the LED string.
                                        • ktmmotocross
                                          Asus G513QE keyboard and backlight not working
                                          by ktmmotocross
                                          Have this Asus G513QE with keyboard, keyboard backlight and Led backlight not working. other works ok.
                                          i measure all voltages ok on keyboard, KB backlight and Led backlight. looks like a kbc error.
                                          but as laptop works i think it cannot be bad. maybe its FW. have anybody some hint for this?
                                          08-08-2025, 06:29 AM
                                        • flat-earther
                                          HP F4180 stopped working please help troubleshoot
                                          by flat-earther
                                          I was doing a large print job with my HP Deskjet F4180, and after about 50 pages the printer stopped in the middle of a page and the black ink light started flashing.
                                          So I went to refill the black ink cartridge with a syringe, but found out it still had a lot of ink.
                                          I tried to print a page again but every time it would print only a bit of the page and immediately stop with the black ink light flashing again.
                                          I tried two other black ink cartridges, and the problem still endured, so I knew this problem had to be with the printer itself.
                                          I ran HP Print and Scan...
                                          05-11-2025, 02:21 AM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • thaphatmaster
                                          Dremel Li-Ion Charger Stopped Working
                                          by thaphatmaster
                                          This is my dremel charger for one of the Dremel / Bosch 10.8v (3s1p) Li-Ion packs. There are many like it, but this one is broken.
                                          It stopped responding the other day. No light when a battery is inserted, no voltage at the output when tested.
                                          The dremel itself and its battery are fine and working.
                                          Looking online, many people just replace this type of charger with an Aliexpress version. However most of the through hole components look straightforward enough to replace if they are broken.
                                          I'll do some basic poking about (continuity checks etc)...
                                          01-29-2025, 10:39 AM
                                        • knoxrebel
                                          TCL 65s425 sound/video working, no backlight
                                          by knoxrebel
                                          Tv shows no issues other than no backlight. Picture was visible with flashlight and menu navigation possible with audible responses.
                                          Polyester film Capacitor c620 27nf (on power supply board had visible brown discoloration, but is not shorted. Replaced with suitable spare and now working properly. (Apparently this is a known issue with this series.)
                                          Backlights tested independently with tester and registered ~140vs on each.
                                          40-L171w4-pwa1g
                                          Mmkp82 1kv 273 J...
                                          01-12-2025, 03:33 PM
