Rca led65g55r120q lvds ribbon fubar
  • MagicSmoke
    • Feb 2011
    • 275
    Working on a RCA 65" had a bad LED on one strip. Fixed that, but in the process of re-assembly I FUBARed one of the LVDS ribbon connections that go from T_Con to panel driver board. Its a KaiQun E356155 80 connector ribbon.
    How can I repair this as I am having a difficult time finding a replacement ribbon long enough. Thanks.
  • CapLeaker
    Leaking Member
    • 8352
    Re: Rca led65g55r120q lvds ribbon fubar
    I think you either get a new panel, or you are SOL on that one, unless you have a tab bonding machine.
    • R_J
      • 9631
      What about these? https://www.ebay.com/itm/RCA-LED65G5...cAAOSwz~paTFE-
      After posting this I saw you repaired the cable, good job
      • MagicSmoke
        • Feb 2011
        • 275
        No it wasn't a tab bonded cable, it runs from T-Con to panel driver board. has flip connectors at each end.
        So I searched the internet and found a ham radio site where a guy had done about the same thing as I did, but on a fewer contact ribbon. His was long enough as was mine to cut off the fubared section. Saving the blue connector support, it was held on by heat sensitive adhesive.
        Then ribbon was taped down to a flat metal surface, then the next step was the most time consuming part. I took an exacto knife and scraped away the insulation covering the traces a little bit at a time.
        Took about 25 min because I did not want to scrape too hard, got to where the traces were showing then took 320 grit sand paper and finished polishing traces. Sanding with the direction of the traces not across. Finished trimming sides of cable to fit in connector so tab would close, And WALA it worked.
        Didn't post a before pic but 1/4 of left hand side of screen was black before repair on cable.
        • WardTv
          • May 2014
          I need the same ribbon, where you able to find a part number.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Good Job!!!!
              • 12323
              • U.S.
              Well done magicsmoke, those diy solutions are the best.
                • 12323
                • U.S.
                A couple on that page for 13 bucks, not cheap but I guess it's supply and demand at work: https://www.ebay.com/sch/i.html?_fro...acat=0&_sop=15
                • NolesFan
                  Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                  by NolesFan
                  Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                  10-24-2024, 06:36 PM
                • Scincidae
                  UN70NU6900FXZA Won't Boot Unless I Temporarily Disconnect Right LVDS Ribbon
                  by Scincidae
                  I recently was given a UN70NU6900FXZA that would only boot loop once plugged in (auto powers on when plugged in). I found that disconnecting the lower (right side) LVDS ribbon, then plugging the TV in, followed by reconnecting the lower LVDS ribbon will allow the TV to work 100% normal as far as I can tell (no lines, no discoloration, no dimming or anything like that).
                  I tried the tape method on the lower LVDS ribbon and found that if I cover pins 10 and 11 (counting from the bottom up) allows the TV to boot normal but 25% screen all the way to the right side is discolored. While...
                  04-24-2022, 06:00 PM
                • alfredomfr1
                  HP M32f FDH Monitor: 12v missing after connect the LVDS ribbon cable to the LCD circuit
                  by alfredomfr1
                  12v pin is shorted to ground in the LCD board (1st picture) if the LVDS cable is disconnected, 12v are OK in the Main Board (2nd Picture)
                  06-04-2025, 10:23 AM
                • zesko
                  xps 9520 ribbon cable
                  by zesko
                  I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
                  There is 2 models, idk which one is needed on my laptop.
                  0xkvng
                  00vpr2
                  Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
                  Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
                  thanks...
                  10-23-2025, 05:03 PM
                • Tr0ll
                  by Tr0ll
                  Original T-con:
                  First replacement T-con:
                  10-07-2023, 07:48 PM
