I picked up a Vizio E65-C3 and was told it lost video and audio was choppy. Went ahead and got a mainboard for it. Installed it and still no video. Well not until I like flexed it from one top corner and video came on. As you see it is not right on the right side of the screen. Could it be the T conn board? Dont know the history of the tv other than what I was told. I sure hope it is not the screen. Please reply if anyone has any thoughts or how I could forsure tell if it was the screen.
Vizio E65-C3
Tags: None
Re: Vizio E65-C3
This unfortunately is the panel (screen). You have a bad connection on one of the ribbons that are fused to the LCD panel. You may be all of the pull off the plastic surround bezel and lightly press on that ribbon to see if the problem goes awayDid I leave the soldering iron on? -
Re: Vizio E65-C3
Finally have time to post update. Took all apart and replaced all boards. Still the same. Bought boards on assumption that one of them had went out. Apparently I was lied to about tv not being dropped or something. Very small piece of actual screen missing near one of the flat cables that is molded to the screen. All of them were fine and did not look damaged but could not do anything to make screen change any at all. So my question is now, Does any one know of any sources maybe to order the actual replacement panel. I know probably big money. Looked all over the net and no lck.Comment
Re: Vizio E65-C3
I think you would be best advised to look for a non-working TV with a good same model screen. Should be some around.Comment
Re: Vizio E65-C3
I dont really understand what you mean. You mean maybe half the screen be good with full picture?Comment
Re: Vizio E65-C3
some sets (quite a few of the large size) have bonded tab ribbon cables on each side of the panel. people here have found that you can remove the ones on the "bad side" and the result is that the panel works basically "like new" with only a very critical eye being able to see any issue. So IF this set has bonded tabs on both side of the panel, you might be successful in getting a fully "functional" set. Lots of posts on this type of "operation" in and around vizio and sharp panels.
It is a "one time operation" so you need to be certain that the side is a problem as once the tabs are removed, they can never be replaced.... so read and research.... it is quite likely you will be successful.
further.... post a picture of your findings about the "chip on the panel missing" so we can understand what you are seeing. If the actual panel is compromised as opposed to the cabling, it might be a "gamble" BUT as I said before, you really have nothing to lose as the panel is basically "broke".Last edited by budwich; 02-24-2018, 09:42 PM.Comment
Re: Vizio E65-C3
I will take it back apart and see what I can see again. Just does not seem possible for the whole screen to work after some tab bonds have been removed.Comment
Re: Vizio E65-C3
I would look for any shorted or low resistance MLCC capacitors along the source driver boards located on the bottom of the LCD panelDid I leave the soldering iron on?Comment
Re: Vizio E65-C3
Getting ready to get back into this TV. My tab bonds are on the bottom of the panel. There is some or looks like them on the sides but they are not connected to anything.Comment
Re: Vizio E65-C3
on this model, that connections to the side tabs is done thru the side of the panel... basically circuit paths run from the end bottom tabs / edge boards to the panel, then along the side of the panel up to the side and then to each side tabs. Ultimately, IF you may have to remove those side tabs on the "bad side".... but as suggested by Freakaftr8, check around the bottom edge boards (near the corner) where there might be issues with the smd capacitors as a result of "one time damage" that you spotted on the side (ie. chip/ crack) which might have caused a problem with the component that may be repairable / replaceable... doubtful but you never know.Last edited by budwich; 02-27-2018, 01:31 PM.Comment
Re: Vizio E65-C3
If it was yours which tabs would you remove to see if it resolved the problem? Side ones or bottom ones? Lets see if I understand, If I remove the tconn connection for the side that has the problem and if it is not the panel then it should be black with no images, right? And then if they are images or whatever then more than likely the panel is no good, Right?Comment
Re: Vizio E65-C3
You CAN'T remove the bottom tabs.... these are source drivers that "run the whole show". Only side tabs can be removed and ONLY ON ONE SIDE.
Further, if you disconnect the tcon to panel cables on one side, that side will normally go WHITE and the remaining connected side should show a "normal picture" for that portion of the display.Comment
Re: Vizio E65-C3
So if I remove any, remove the ones on the side that has the issue, Right? Nothing to lose. It is trash the way it is so why not!Comment
Re: Vizio E65-C3
yes that's right.... BUT don't necessarily give up right then as it is slightly possible that the damage on the side might have cause some issue on the bottom edge boards that may need addressing. Anyways, with luck, you will get a working set with the side removed.Comment
Re: Vizio E65-C3 Amazing Update!!!
Amazing Update!!!! Removed tab bonds from the side that was messed up and now look at the before and after pics. I was just about ready to post it as free for parts and came across the amazing thread about the tab bond removal. Totally amazing. May not last long then again it may last forever, Who knows! Thanks to all for the great great advice. You guys are geniuses!!!!Comment
Re: Vizio E65-C3
Interesting, so gate driver short caused vertical lines as Well! Guess it is possible if loading VCOM or AVDD down.
Nice job!Did I leave the soldering iron on?Comment
Re: Vizio E65-C3
Well the before pic was a few weeks ago. The before pic tonight was like that but without the vertical lines. I had cleaned the ribbon cable that connects the 2 bottom boards together. That may have helped, I dont know. But anyways I said what the heck and removed the side tab bonds and this tv has great picture quality. The tab bonds looked fine though to the eye.Comment
Re: Vizio E65-C3
since you didn't actually post a picture of the "fracture", its hard to say what might have happen... possibly a broken line that provides powering to the side drivers which then "loaded" down the opposite side resulting in the first picture which appeared to show "disconnected side drivers". glad you got it working... happy viewingComment
by spice_discI'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...1 Photo -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by smic717394Hi,
I have a iphone XS that came in for a screen replacement, the screen was badly cracked, and inside missing scues, on the back of the screen still the blue protector, the screen was a LCD. So we replaced the screen and all good, installed the screen and we noticed that pressing the screen with a bit of force but not excessive, the phone dies. After plugging the charger it turns back on, but again if you press it it dies. I open the phone again, and I can't see anything major, with the phone open, if I press on the logic board, battery, charging board, or even putting pressure on... -
by paqmanSo our beloved M60-C3 up and died the other day. I was not there, my wife mentioned that it came on, displayed the logo, then showed the right half of the screen white and fuzzy, with the left half of the screen ok. However when I got around to looking at it, the screen would not come on at all. The indicator LED will come on, then dim a bit. After a while, the LED might blink a bunch of times. I can't get it to be consistent to do that.
So I've got the back off and am checking voltages. The capacitors on the power supply board visually check out. No bulges or anything. They all show... -
by ChrissygizmoHello everyone, I’ve just been given a Samsung UE55JU6800K smart tv as it had white spots on the screen due to the led lenses falling off. After refitting them & putting the tv back together I thought it was a nice easy fix for a free bedroom tv , then I tried it before screwing the back into place. I realised that the right side of the screen was darker than the other side, I removed the screen again as I thought the backlights had failed but they are fine.
I put the screen back in place & turned it back on . The screen seemed to be ok again but different screens on the same... - Loading...
