samsung LE40N87BDX - power supply tranformer
  • jimmiscom
    • 22
    • greece
    hello. i have the famous samsung clicking on/off problem. no bulging capacitors , no cold joints or any visible problem. i replaced all the capacitors on the cold side, i replaced the eeprom with new one but none of them solve the problem.
    im getting steady 5.2 standby volt but because of the clicking problem i could not measure the other voltages so i disconected the mainboard and i jumber the standby pin with ps_on pin . that trick turned on the psu and i managed to measure all the other lines voltages
    at line of 12v i was getting about 10.5v
    at line of 13v i was geting same.. 10.5v (seems strange to me)
    all other lines 5.4v and 5.2v(standby) was ok.
    After searching why i was getting low voltage i noticed that from the tranformer (TM801S) i was getting no volts from pin 10 and also was shorting with the ground pins. i desoldered the tranformed and checked again pin 10 and still shorting with the ground pins 8,9 .
    Anyone knows if this is normal ? i have attached photo of the transformer and a part of the schematic that shows the tranformer TM801S.
    thank you
  • R_J
    • 9588
    Re: samsung LE40N87BDX - power supply tranformer
    The transformer is fine, you are measuring the dc resistance of the wire in the transformer. What is the BN44- number of the power supply board
      The DC resistance of the transformer windings will be very low, they are normal for DCR to be low, you need ringer to test transformer, I doubt that it is bad. The 12V and the 13v are not regulated, and there is no feedback from those output to be used to regulate those two outputs, the circuit regulate by sensing the 5V output which is used by the main board to run the Logic circuits, the 12v/13V are for audio which is not critical so it doe not need tightly regulated supply. So did you verify that those filter caps for the 12V/13V do not have high ESR and still have correct capacitance.
      • jimmiscom
        • 22
        • greece
        thank you for info and sorry for late reply.
        i thought that maybe was the transfomer but as per your information must be ok.
        Since the low voltage problem is difficult to find myself i though to gave up. So i soldered the transformer back to the psu so i can check that everything was the same as before desoldering the tranformer but when i pluged the cable to the tv.... BOOM..!! one resistor 0.3ohm (RM808) exploded. I replaced it but same again ..exploded. i checked the back side of the psu to see if anything else was burned (while the cable was on the psu) and i saw sparks from smd resistor (RM807).
        So again your help. can you check the attached schematic (page1) and suggest why the two resistors explode ? (RM808 & smd RM807) .
        thanks
        • R_J
          • 9588
          I suspect, Qm801 will be shorted and UM801s could also be bad, I would also check the diodes and resistors in that section, like rm802, dm801,dm802,zm802 etc.
          Did fm802 fuse blow also?
          • jimmiscom
            • 22
            • greece
            all fuses included fm802 is ok. i will check Qm801 , section resistors and diodes but any idea how to check um801s ?
            • R_J
              • 9588
              You can't really check the ic, but if the qm801 is shorted it might have damaged the um801s ic.
              (if drain shorts to gate it can damage drive ic)
              Also if qm801 shorted (or was turned on) and rm808 opened, that would place a high voltage on rm807 and feed it into the ic, that could explain why it burnt up
              If the fet is ok it could be that CM803 shorted, that may be all thats wrong, if it is bad replace it with a 2kv version
              • jimmiscom
                • 22
                • greece
                i think qm801 is shorthed . i desoldered it and test it with multimeter.
                both drain and source is shorted when i touced it with red and black probes and same result when i reverse the probes.
                Drain + gate are not shorting. do you think that the ic um801s is ok?
                and what else you suggest to check.
                • R_J
                  • 9588
                  with qm801 shorted, it is possible the ic is ok, but since rm807 is burnt I would not trust the ic.
                  Also check that cm803 (blue disc) make sure it is not cracked, they are common to go bad on some of these samsung power supplies
                  • jimmiscom
                    • 22
                    • greece
                    cm803 seems ok.
                    I dont have time today to desolder the other components on same section to check them, so i will try tommorow.
                    Do you think that this problem related with the clicking on/off problem that i have? because before i started soldering and desoldering components the psu was just turning on/off, no blowing issues.
                    • jimmiscom
                      • 22
                      • greece
                      i cannot find in my local market mofset qm801 (type 6N80) but i have one JCS7HN65C from another chinese brand tv (not remeber the brand)
                      can you check attached datasheet and tell me if it safe to use it ?
                      • jimmiscom
                        • 22
                        • greece
                        hello
                        can anyone check if i can replace 6N80 mosfet with JCS7HN65C
                        i cannot find 6N80 at my local store
                        • jimmiscom
                          • 22
                          • greece
                          anyway i replaced the shorted mosfet with JCS7HN65C the burnt 0.3ohm resistor with 2 x 1ohm paralel resistor and the burnt RM807 220ohm smd resistor with another 220ohm smaller smd resistor. i pluged again cable but RM807 burnt again. is it possible the ic UM801S to caused the burnt ?
                          • R_J
                            • 9588
                            Yes it is very possible. You could check to see if CM801 is shorted but my money is on a bad ic. also if RM807 burnt it must have had a lot of current flowing through it, did the fet short again and open the RM808 resistor.
                            The Isense line of the ic has an internal 10k followed by a diode but the ic could still be bad as it max voltage on that line is 3 volts
                            • jimmiscom
                              • 22
                              • greece
                              cm801 is not shorted, i measure about 83ohm. it must be the ic, when i measured pins 3,4,5 seems shorted (0 ohm) but i took the measure while on circuit. i dont have time to desolder it now.
                              if i desolder the ic , then replace the burnt components (resistors and mosfet) and plug the cable again do you think that any component will explode again ?
                              and If nothing happens wihout the ic on the circuit do you think that the problem finally is the ic ? what do you think.. can i try it ? or i will make more damage to the board?
                              • R_J
                                • 9588
                                Pull the ic and check the other components, I would not try it without the ic, without the ic to drive the gate of the fet, the fet could be turned on and that would apply the pfc voltage across rm808, result... Boom
                                • jimmiscom
                                  • 22
                                  • greece
                                  i will pull out the ic mayby tomorrow but since i didnt find the ic on my local store i have to order online but it will take long time to have it on my hand.
                                  i will inform you once i get it and replace it.
                                    09-07-2024, 05:50 AM
                                  • cheeky2
                                    Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                    by cheeky2
                                    This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                    I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                    Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                    06-15-2025, 05:12 AM
                                    by sam_sam_sam
                                    03-31-2024, 02:12 PM
                                  • Cookybaby
                                    Samsung UN60ES6500FXZA Power Supply Issue
                                    by Cookybaby
                                    Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                    I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                    Make: Samsung
                                    Model: UN60ES6500FXZA
                                    Power Supply P/N: BN44-00525A
                                    Symptoms: The TV was...
                                    08-20-2023, 12:26 PM
