LG 42LV5400-UB Touch panel buttons not working
  • TubeJunkie
    • Oct 2012
    • 107
    Hello. I have a LG TV model 42LV5400-UB. The touch buttons on the front panel does not work. Didn't get the factory remote with it either. The picture and sound work great. But I can't change inputs, volume, channels, power button, or access the menu. When AC power cord is plugged into AC outlet, the TV starts up. And is on HDMI 1.
    I'm pretty handy with soldering and I've downloaded the service manual, if only someone could point me in the right direction. I can take some voltage readings. Any help will be greatly appreciated. If I fix it, I'll donate to BadCaps.net. Thanks
  • freakaftr8
    • Oct 2012
    • 3743
    Re: LG 42LV5400-UB Touch panel buttons not working
    Sometimes these touch button s can get "touchy". Have a look first at the connector that goes to the button control pad from the mainboard.
    Make sure the button control is receiving 3.5v to 5v. Also make sure that nothing like liquid has been spilled there. People like to wash screens with Windex. A big killer of electronics and circuit boards.
    • mmartell
      • Oct 2013
      • 3189
      If you've already opened it then you will have verified if the board has peeled itself off it's mount or not. The glue is very tacky but who knows... the buttons won't work if they're not mated to the plastic bezel.
      • TubeJunkie
        • Oct 2012
        • 107
        The button board doesn't look like anything has been spilled on it, but you can't tell if Windex has been used on it. And that board is firmly attached. I tried prying it out, but it didn't budge at all. I took some voltage readings from the input/output board that the button board is connected to. Pic included. I get 3.4 vdc on all pins except the following colored wires .From top of pic. No voltage on: Black, blue, white, gray, purple, & green.
        I also got the same readings at the cable end that connects onto the button board.
        • freakaftr8
          • Oct 2012
          • 3743
          What you can do is probe any colored wire while you press on the buttons. If you are a feedback voltage (which I believe this is how it works) it may be a mainboard issue.
          Any LG or vizio remote will turn the set on and off. Wondering if IR works.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            could this set possibly of come from a hotel etc as maybe in hotel mode if thats the case sometimes the touch buttons etc are disabled
            https://www.youtube.com/watch?v=lNW_0D7cykw this video at about 42 seconds in shows what can be disabled
            • TubeJunkie
              • Oct 2012
              • 107
              Hey guys, Thanks for chiming in. I got a Vizio remote, and it does nothing. I tried probing the colored wires with my meter, while hold the power button on the front panel. Nothing there either. I unplugged the connector from the button board while it was powered up, and plugged it back in, and now its stuck on component 1 input, instead of HDMI 1. Now I cant really use it. Dang it. Just my luck. lol... I'm most certain the IR doesn't work. Since the Vizio remote done nothing. Any more ideas fella's? Thanks Again
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                if you have a android device you could try this lg remote app here are what you need, it is very easy, just audio or IR with android
                • R_J
                  • Jun 2012
                  • 9515
                  The vizio remote won't work, you would need an LG remote (different remote codes) turn off the tv, connect the source hdmi device, then power on the tv then the source device and see if the tv finds it.
                  • TubeJunkie
                    • Oct 2012
                    • 107
                    I downloaded the LG Remote app to my Motorola Xoom tablet. The app can’t find the tv. I tried to rescan, but to no avail. My son has an LG tv Remote, that I’ll borrow ASAP. Any other ideas ? Thanks
                    • TubeJunkie
                      • Oct 2012
                      • 107
                      Should there be 3.4 volts on all pins that connect to the button board? There are six pins with no voltage, as I previously stated. I've tried looking at the service manual, but I can't tell if all pins should voltage. I know there's two ground pins that shouldn't have voltage. But, I'm just stumped right now. Someone please guide me in the right direction. Thanks
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        The 6 pins should be outputs and such. What happened with the LG remote? Any luck?
                        3.4v is about right.
                        • TubeJunkie
                          • Oct 2012
                          • 107
                          That’s what I was thinking about the pins with zero voltage. My son can’t find his LG Remote. I’ll have to buy one, I guess. But I seriously doubt any Remote will work. I got this tv from a recycle center. When I opened it up, I noticed someone had cut the speaker wires. Probably because they couldn’t control the volume. I repaired the speaker wires. I’ll definitely try an LG Remote when I get one. I’ve read this is a known problem with this model / series of LG tv’s. I’m not a fan of the Soft Touch button deal! Now, more than ever! Lol
                          • obelix24
                            Macbook Air 2020 (a2179) - touch id not working
                            by obelix24
                            Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
                            I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
                            02-09-2025, 12:57 PM
                          • Gabriel Lucas
                            microsoft surface pro 5 touch screen not working
                            by Gabriel Lucas
                            Hello everyone, I bought a Microsoft Surface Pro 5 and the touch doesn't work. According to what the previous owner said, the screen stopped working after an update. The screen has no physical damage, and the touch works for 1 second when it turns on and then stops working. I've tried updating the drivers, formatting, and returning to factory defaults, but nothing worked. Can you help me?
                            02-18-2025, 09:24 AM
                          • badcappo
                            Thinkpad Yoga X380 Touch and Pen not working, shutdown leaves power indicator and fan on
                            by badcappo
                            Got a Thinkpad X380 Yoga with unknown history for cheap via ebay. Only screen was broken, rest working according to seller. As I had a another working screen from a donor X380 with a broken mainboard, I figured I could make a working Thinkpad from two broken ones. However after the screen swap the Touch and Pen feature still doesn't work, neither on Windows 11 nor in Linux (tested with various distros). Already transferred screen cables and BIOS EEPROMs to ensure it is not an issue with screen cabling or board software. Turning the machine off leaves the dan and power indicator light on, CPU remains...
                            03-01-2024, 06:18 AM
                          • engineerx
                            Help with HP elite X2 1013 G3| Touch screen stop working after windows update !!!
                            by engineerx
                            Hello everyone
                            I have a multiple HP Elite X2 1013 G3, the touch works normally, but after installing Windows 11 and making its updates the touch screen stopped working !!! I think it's related to LCD firmware or bios updates, any suggestions or solutions?
                            thank you...
                            11-15-2024, 04:32 PM
                          • fugo5
                            repair my surface pro 4 because my touch is not working
                            by fugo5
                            i tried the last 3 days to repair my surface pro 4 because my touch is not working.
                            I think i tried all the different possibilities from here. Thanks to all of you.
                            I have a few last questions.
                            1. Is it possible to repair the touch with special bios ?
                            2. How can i get my own bios ?
                            3. I dont find my ime 11.0.11.1006 to download, only for money.
                            4. I put all edited bios on a bootable usb stick and start it, something happend but the problem is the same, no working touch.
                            I will very thankful for an answer.
                            Excuse...
                            04-27-2023, 09:08 AM
