lg tv 42lv450 does not start
  • Moddingscreen
    • Dec 2017
    • 65
    • Italia
    #81
    Re: lg tv 42lv450 does not start
    FINALLY!!!! solved I basically swapped all the eprom that were present on the old pcb, et voilá, guys thanks for the support you gave me you were very helpful thanks very much, attached photo of what I swapped
    • freakaftr8
      • Oct 2012
      • 3743
      Good to hear!
      Just curious now that it's working what exactly is DRV on doing when it's running? Should have something like 2.5 to 3.4 V on that pin
      • Moddingscreen
        • Dec 2017
        • 65
        • Italia
        #83
        I reassembled everything, tomorrow I can reopen it and I'll let you know, thanks again for the support
        • freakaftr8
          • Oct 2012
          • 3743
          Don't worry about it.
          • mohsinrizwan
            LG TV 49LW5700 does not power no Standby Voltage(PSU EAX62865401)
            by mohsinrizwan
            I have LG 49LW5700 which is not turning on, when I checked there was no standby (3.5V) can anyone guide how I can trace which component is faulty.
            05-28-2022, 10:35 AM
          • mohsinrizwan
            LG TV 47LW5500 does not power on (PSU EAX62865401/Main board EAX64405501)
            by mohsinrizwan
            My LED died while checking on PS-ON test not seeing any voltage.
            Here is result on PS-ON Pin 1 jump to Ping 9-10-11 or 12 (3.5V)
            23 - N.C -> 0V | 24 - ERROR -> 0V
            21 - 12V -> 0V | 22 - PWM -> 0V
            19 - 12V -> 0V | 20 - N.C -> 0V
            17 - 12V -> 0V | 18 - DRV-ON -> 0V
            15 - GND -> 0V | 16 - VSYNC -> 0V
            13 - GND -> 0V | 14 - GND -> 0V
            11 - 3.5V -> 3.52V | 12 - 3.5V -> 3.52V
            9 - 3.5V -> 3.52V...
            08-02-2020, 01:53 PM
          • desone01
            Changing Dell Asset Tag
            by desone01
            I have dug through my Dell utilities and located an old Dell Engineer's program which changes the Dell Asset Tag. I have used this SUITE of programs in the past to amend the Asset Tag on second hand motherboards I have installed.
            I don't know if it works with the newer Dell laptops. You should use extreme caution in using these programs. As you can see the program is fairly old one.
            Here are the instructions from the README file:
            SVCTAG.EXE
            Dell Internal Use
            09-04-2020, 07:33 PM
          • atari1968
            LG TV 42LW5700 does not power on fully (PSU EAX62865401/Main board EAX64405501)
            by atari1968
            My LG 42LW5700 doesn't power on. when tv plugged on the standby light is
            a very week until I switch power on then the standby light blinking slowly.
            After checking the power supply,
            I measured the output voltage after switch on and everything looks okay
            Please see the attached picture of the voltage test for the output ports.
            So probably the power supply is ok and the problem could be on the mainboard EAX64405501,
            The standby led is always very dim until I switch on and then the led start to blink (high and dim not in the same...
            08-16-2019, 08:20 AM
          • Flasman90
            Macbook Pro A2289 MXK62LL/A (661-14770) - No Startup
            by Flasman90
            Hi everyone - first time poster on here looking to embark on my first repair! Thank you in advance for any help!
            My Macbook only turns on when the charger is plugged in and only the trackpad and fans show signs of life. The display, caps lock light and touchbar do not turn on. There was previous liquid damage to the touchbar but after cleaning and drying the laptop was operational for a year without any issues. There doesn't seem to be any sign of liquid damage to the board, at present.
            What I have done so far:
            - All of the routine diagnostic methods including...
            08-29-2025, 08:38 AM
