Main board substitute for LG
  • mannuoye
    • Dec 2017
    • 9
    I have a faulty main board of LG 55LW6500 TV and LG stopped making them any more and I am unable to buy replacement anywhere. I do have access to LG 55LV5700 TV's main board which visually looks exact copy. Can I use it?
  • jasonr2000
    Advance Tech
    • Nov 2013
    • 209
    Re: Main board substitute for LG
    hi there the simple answer to this question is NO
    as the T-Con will be different to the one that matched your original mainboard.
    Samsung UE46D6530
    Samsung BD-F7500
    Samsung HT-ES6200
    • mannuoye
      • Dec 2017
      • 9
      Thanks for replying, but both main boards output double LVDS (one 51pin and one 41pin) which is similar too. Do you still think there will be a different T con?
      • mannuoye
        • Dec 2017
        • 9
        For anyone who gets into the situation like me, I have found the substitute for the original mainboard.
        LG makes a repair package for LG 55LW6500 TVs which includes a mainboard, a small remote PCB, a magic remote and a regular remote. The part number for this assembly is AGF78482709
        I ordered this today and hope to get it in next 7-10 working days.
        I will update after installing it.
        • tvtimmy
          • Mar 2015
          • 1160
          • usa
          Let us know exactly where you got if from.
            Price?
            • mannuoye
              • Dec 2017
              • 9
              Hi I got it from www.statewideapp.com.au in Adelaide Australia. believe it or not it cost me $248 only and It worked!!!!.
              One thing I would like to mention is I lost one HDMI port so now I have 3 instead of 4 but that does not matter because I use only one and there is no VGA port in this one as well.
              • Spork Schivago
                • Mar 2012
                • 4734
                • United States of America
                only 248$? https://www.statewideapp.com.au/lg-package-assy-253711 doesn't really say anything about what you're getting.
                Kinda seems really high. Do you know what's included?
                Also, I just wanted to add, one time, I had two boards that where supposedly compatible and weren't. They looked identical, came from the same make and model TV, the one replacement I bought worked, just not in this TV. The one difference was some hack someone made a long time ago (maybe the manufacturer, because ShopJimmy _used_ to sell these boards with the same hack). No one could tell me what the hack did.
                Anyway, I noticed all the small EEPROMs on the boards and just swapped them around. New board worked like a charm. Keep in mind though, with this television, there where a few extra boards that I don't normally see on TVs, like some sort of daughter board for the CD-ROM drive (a CD-ROM drive), etc.
                -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
                • Nick's Tvs
                  • Jan 2014
                  • 621
                  For half the price you could get your original board fixed
                  https://www.nickstvs.com/store/p1432/EBT61394305
                  • mannuoye
                    • Dec 2017
                    • 9
                    Unfortunately here in Australia its not cheap to get electronics repaired. I tried two recommended repair places and they opened their wide mouths. $66 to get a quote and $180 to put an new board in the TV. Main board charges extra.
                    All they didn't said to me was to turn around and bend. So I think "only" can go with $248
                    • tw2005
                      • Oct 2011
                      • 6458
                      did you ever try that LV5700 board? Is 55LV5700 a model sold here?
                      • mannuoye
                        • Dec 2017
                        • 9
                        No I didnt tried LV5700 because the one I used was specifically made for my TV
                        • Dani_2024
                          by Dani_2024
                          10-28-2024, 05:06 PM
                        • jb_Bak
                          by jb_Bak
                          CN6401
                          Pin 01 NC
                          Pin 02 NC
                          Pin 03 "BL_ON": 0V
                          Pin 04 "N/C"
                          Pin 05 "STBY 3.3V": 3.5V
                          Pin 06 "GND": N/C
                          Pin 07 "AC_OFF"...
                          09-27-2021, 04:52 PM
                        • JDC
                          by JDC
                          ONN 100012588
                          Long answer:
                          07-15-2022, 07:39 AM
                        • m1ch43lzm
                          by m1ch43lzm
                          05-12-2025, 08:37 PM
                        • cheeky2
                          by cheeky2
                          05-25-2024, 03:27 AM
