LG 60lb5200 LCD TV - No Power - No Standby Light
  • Landon6544
    • Dec 2017
    • 15
    Re: LG 60lb5200 LCD TV - No Power - No Standby Light
    Pin 1 or the Vcc reads 1.02 volts.
      More in-depth troubleshooting will be required by tracing out and draw up the circuits to show where that VCC pin 1 goes to to get its switched VCC to run, that is what I will do if it is my board.
      Are you good at reverse engineering and drawing the circuit?
      • WTRWLKR
        • Dec 2017
        • 24
        From my mistake, make sure you measuring Vcc from pin 1 and Ground from pin 2. Using the ground points of the board results in a bad measurement.
        • AleMonti
          LG 55EG910V - no power and no standby light
          by AleMonti
          I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
          I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
          The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
          After checking the basics I did the following:
          • I measured all voltages and as expected the only active supply is the 3.5V standby. It
          11-04-2024, 05:02 PM
        • SkishyIshy
          Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
          by SkishyIshy
          Hey All,
          I have a Sony 65x900f that I purchased cheap because of a no-power issue.
          I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
          I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
          03-17-2021, 11:44 AM
        • noinimod
          Sony 55X900E no standby light, no power. Replaced mainboard already
          by noinimod
          No standby red light, nothing
          This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
          Disconnected JK3 power board from main board, checked voltages on all the pin outs
          At a few pins I can see the power supply providing 19.5V to the main board
          Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
          LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
          12-22-2021, 12:58 AM
        • stylishconsultant
          un60j620dafxza - Samsung No Display Problem
          by stylishconsultant
          Hi All,
          Need help.
          I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
          So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
          problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
          might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
          09-04-2024, 03:26 AM
        • lapfix
          HP OMEN NO power no light
          by lapfix
          HP OMEN : DAG35DMBAD0
          NO power ,no short ,no corrusion
          Consumption : when charger plg in = 0.004 amp
          Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
          when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
          No light at power button led
          All coils resistances :
          Pl 2001 =3v measured with kohm.
          pl 2004 = 5v measured with kohm
          pl 6001 = 49.7ohm
          pl 4012 = vccsa = 24.4 ohm
          pl 3001 =...
          11-03-2025, 07:48 AM
