LG 60LB5200 will not turn on
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: LG 60LB5200 will not turn on
I joined the site. You cannot download files unless you pay for a premium membership or have a minimum of 250 posts... LOLThere is reference to the power supply diagram (FA 168P-P5L031-W1.pdf) at this site but I'm hesitant to join up.Comment
On the flip side, it looks like some places are beginning to stock the replacement board again. I see it for as low as $66.32 on Amazon https://www.amazon.com/s/ref=nb_sb_n...ds=COV32809701Comment
Hi
I am sorry to bother you but I do have a COV32809701 power supply with the same issue of low voltage on the 12v = 6.95V 24v = 15.64V and Both of the large caps are 163.2 VDC. I did replace d12 and checked other diodes and transistors with no help. it look as if tis is a common issue with the COV32809701 power supply. any suggestion.
thank you and I really appreciate your help.
JoshuaComment
Hi
JoshuaComment
Has anyone successfully repaired the power supply to this TV yet? I just acquired this same model TV with the green standby light flickering.Comment
Yikes! I'll keep checking back here as I still want to repair my broken PSU. I got a good board to work off of but my multimeter crapped out.
by pajdekHello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
by RdeveLabsTo all the members here...
Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But... -
by robante15Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
If I remove the... -
by masoksianHi everyone,
I am dealing with the problem of turning on and off my Dell e7470 notebook.
The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
The system does not turn on, there is no post.
I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
The problem continues in the same way.
I tried to turn on the Fn key, nothing came to the screen.... -
by Ledgurrahello! hope you are all well. i have a macbook pro a1425 and it won't turn on. i took it to the service center and they said it's fine, it turned on 2 times and then it wouldn't turn on. on the power supply there is a yellow dot that is charging and turns green when charging but when i turn it on it doesn't turn on. i opened it and saw on the motherboard that 2 elements are missing, i am attaching the photos for you to understand better.
thank you all6 Photos - Loading...
