Sony XBR75X850C no picture backlights on
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4352
    • Italy - Milan
    #61
    Re: Sony XBR75X850C no picture backlights on
    There can be some secrets as i have seen on my Sony, you know, but it's possible also a failure in the ICs, it's very uncommon that searching for the panel model i don't find anything, searched also S650qf59 OR S550qf59 OR S500qf59 OR S470qf59 but nothing, so i re-ask you is the model number exact? With no datasheets is not possible to proceed i think, as all tcon i have seen started by 12v in, not by a command from mainboard.
    • freakaftr8
      • Oct 2012
      • 3743
      Ok try this. Panel model 14Y_75UDMB3SFR4LV0.0 At least that's what's on one of the source driver boards.
      That probably doesn't do any good I can't find it in a Google search
      • freakaftr8
        • Oct 2012
        • 3743
        I wonder if this system is like the failing ISL9860 other tcons have
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4352
          • Italy - Milan
          #64
          The right part number is usually placed on a white sticker on the panel metal chassis, but unfortunately Sony seems to remove theese one to make the panel like Sony brand but i recongnize it from tcon number and connectors it's much probably Samsung panel. I have an idea, if you have an eeprom programmer (you must have) you can try to read the 2 (or four? Need a good TCON picture!) eeproms near the processor, using the tcon pw.supply and connecting to the programmer only SDA,SCL tespoints near them, inside one of them i think there is the correct model number like i have found in mine..
          • freakaftr8
            • Oct 2012
            • 3743
            Yes this is a Samsung LCD panel.
            Tcon Part number LJ94-32255G
            That part number is definitely Samsung
            It's a good idea about reading in the eeprom.
            I tried feeding 16 from another tcon. Did not get good results most likely because of cross talk.
            But check this out. Similar tcon, same processor IC. For a Samsung un75ju641df uses same everything.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4352
              • Italy - Milan
              #66
              same what? I don't see ic markings...
              • freakaftr8
                • Oct 2012
                • 3743
                Main processor.
                Samsung model.
                Mine is also VTU10A1
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4352
                  • Italy - Milan
                  #68
                  But it don't helps you! :-J
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Here are better hi res photos of my board. Ignore CG9, I took it off and resoldered it in testing, but I didn't do a good job keeping it straight.
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      It may help because I have one in my possession putting out all the proper voltages and it uses the same regulators as the Sony board.
                      LVDS inputs are a different clamp style But outputs are identical to my panel
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4352
                        • Italy - Milan
                        #71
                        ah ok...
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4352
                          • Italy - Milan
                          #72
                          First of all i wanna make sure you are checking the right places, VON it is measured on the cathode of DG51 (left upper area, 2nd photo), VOFF probably on the CG52-3 or CG57-8 (same area), VON and VOFF are repeated on the last photo (same chip type), VON on cathode of DG1, VOFF on CG7-8. AVDD is formed by the power components in parallel (A-B) QS1-2, LSA1-B1, DSA1-B1, CSA7-B7, with the switches ICA1-B1 that feeds VIN12v to those DC-DC boost. AVDD is measured on CSA7-B7. You have to test those points in volt, and if no volt check all the diodes,mosfets,bjts. IF the protection is shutting down at powerup, if you have followed my big Sony journey, you can search for a timing cap, much probably CS36 that is the smaller, it has to be small.. you can cross your fingers and short it for 1-2secs or more at powerup and see if something warms up too much or the tensions come out... good luck..
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Davi.p you rock! Thank you! Ill report my findings
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4352
                              • Italy - Milan
                              #74
                              On CHS1-2 and CSH3-4 you have to find probably 3,3v
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                All those test points are dead except CS36 is the 5v in. I took a gamble and tried shorting that cap anyway. Nothing does far in for some reason this doesn't even have an effect on the bucking regulators for the 1.1v ICD2, This area seems to be unaffected by anything that I do. of course this runs the core voltage for the CPU
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  ChS1 and 2 are bothh dead also. They do come alive when I inject 16v into HVDD But this is backfeeding and not really affecting ICD1 or ICD3.
                                  IcD4 doesn't change and there's no voltage around it except for the 5v in
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4352
                                    • Italy - Milan
                                    #77
                                    have you got a scope with recording function or a meter with max fn? You can test if there are spikes that tells you the tensions are trying to come up
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      I have an oscilloscope however I still need to get my new probes somehow I lost my old probe. It's just a BK precision one. Not too great but it does the job
                                      • will62
                                        • Dec 2016
                                        • 229
                                        • usa
                                        #79
                                        Hey freak, do you have this already?
                                        https://www.manualslib.com/download/...r-55x850c.html
                                        • freakaftr8
                                          • Oct 2012
                                          • 3743
                                          Wow no I didn't! Thank you!
                                          Interesting read here. Wonder how the mainboard mutes the picture when firmware needs upgrade to new tcon/panel?
                                          • Daren87
                                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                            by Daren87
                                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                            08-13-2023, 03:25 PM
                                          • CyberPhoenix
                                            Issue with picture quality of Sony bravia TV
                                            by CyberPhoenix
                                            Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                            01-22-2024, 02:08 AM
                                          • noisykid
                                            Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                            by noisykid
                                            5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                            12-30-2024, 07:15 PM
                                          • thelankanguy
                                            Sony KD-55X9000F TCON Issue
                                            by thelankanguy
                                            The TV shows a black screen with no image.
                                            TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                            Later both ribbons were disconnected and TCON voltages were tested.
                                            12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                            There is also a short to ground in this circled inductor.
                                            Is this a TCON issue or something else ?...
                                            12-13-2024, 12:27 AM
                                          • bbrain
                                            Sony KD-55AG9 TCON?
                                            by bbrain
                                            I have this problem with my Sony 55' AG9.
                                            It flashes 4x.
                                            I have found the service manual, and seems it is the TCON.
                                            Before I buy a TCON can someone check the vid?
                                            Thanks in advance!...
                                            09-19-2024, 10:50 AM
