Sony XBR75X850C no picture backlights on
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Sony XBR75X850C no picture backlights on
    Interesting. LVDS cable pin 3 on mainboard to 39 on tcon labeled Panel ON. This is the smaller 41 pin connector.
    Edit: I tried grounding this pin and error pin also and also applied 5v. No change.
    • freakaftr8
      • Oct 2012
      • 3743
      Here is the panel with 12v applied to the HVDD. So now I know I'm getting somewhere with my persistence. Lol.
      • freakaftr8
        • Oct 2012
        • 3743
        Alright. I'm officially stumped guys. The Samsung derivative tcon that I got I thought worked noes not put out voltages. This particular tcon board pushes the same exact panel as the Sony.
        I applied 12v to it and there is a actual 8 pin regulator that does not energize so there is no voltage at all including the 1.3 to the core. I jumped the regulator and now have core voltage and some sporadic 3.3 and 5 V but absolutely nothing running off any of the regulators for the same voltages that I missing on the Sony board.
        • freakaftr8
          • Oct 2012
          • 3743
          Something has got to be either shutting down these regulators or possibly something needs to energize them or be a switch. What do you think
          • Davi.p
            • Sep 2009
            • 4265
            • Italy - Milan
            #85
            What about my post #77?
            • Davi.p
              • Sep 2009
              • 4265
              • Italy - Milan
              #86
              Have you tried shorting CS30 on the right? Right there there are some 0ohm res., have you tested them?
              • freakaftr8
                • Oct 2012
                • 3743
                Yes I tried CS30, One side of that capacitor has 5v coming in I tried shorting I tried powering up with it shorted nothing makes a difference
                • freakaftr8
                  • Oct 2012
                  • 3743
                  I have a scope. The voltages do jump about .02v when 12v is applied.
                  • Davi.p
                    • Sep 2009
                    • 4265
                    • Italy - Milan
                    #89
                    It seems a missing enable signal, at least from the low of my knowledge..
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      IT does to me too. But even with schematics, I donyt see where that would be coming from.
                      Given how many tcons I've tried, I'm really starting to think this turn on signal comes from the mainboard.
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        I'm starting g to think that this area the the PWM generator. The c oil is VCC 1.15v and there's 6v and 4.4v and 3.3v around that IC.
                        • Davi.p
                          • Sep 2009
                          • 4265
                          • Italy - Milan
                          #92
                          What?? I'm curious, what you have fed to the tcon to see image?
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            These areas
                            • Davi.p
                              • Sep 2009
                              • 4265
                              • Italy - Milan
                              #94
                              Sorry, i have understood nothing on post #91...
                              The PWM ic on the photo post#91 RT6932 is by Richtek, Samsung uses them often on LED TVs, on it's website unfortuantely there's no d.sheet for this, but i'm watching an interesting one of the series, found by "RT69" search term, this:
                              As you can see some of theese chips are fu**ing programmable ones so there's a nvm memory inside that stores settings, it's very hard usually to rebuild a lost programming of them, one has to write a program to use with a i2c interface and send the data to it, but you also lack of the data. Sometimes i2c lines are affected by bad mlcc caps on them, so on the tcon or on the mainboard is better to find the i2c line that goes to the 3 chips with missing tensions and replace the caps you find on the line/s, usually by only removing them the line return to work again.
                              • Davi.p
                                • Sep 2009
                                • 4265
                                • Italy - Milan
                                #95
                                Correction: the chip linked is a all in one solution and so it has a memory inside but in your tcon there are 4 chips for the ps section so i think it's difficult them have i2c, watching that d.s. i see that a typical power sequence is VGH>VGL>AVDD, so it's possible every chip communicate to each other by a Powergood signal, let's suppose that one of the 2 VGH-VGL chips are bad, the sequence is interrupted, i would start to search a new tcon (and claim refund for the ones you got) or search a single pin that joins the chips, taking consideration of GND and VCC signals.
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  Each IC is receiving VCC 5v and there is some 3.3 and 12v there too.
                                  Too bad there are no schematic diagrams of these I c's in question. The Samsung tcon for the un75ju641df uses same ICs and it also will not power up.
                                  I am so close but still stuck
                                  Is the RT6932 the main PWM for all regulation ICs? It's always powered and putting put voltages.
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    Back to what you were saying the SDA and SCL of all of these ICs communicate with each other and if one is not happy they all shutdown? Is that correct? Why do I have 1.15 v then? That ic generates 1.15, 1.1 3.3 and 5v. All those seem to work.
                                    • Davi.p
                                      • Sep 2009
                                      • 4265
                                      • Italy - Milan
                                      #98
                                      I don't think all the chips have a serial comm line, but how knows? If you dont find the usual voltage divider connected to the outputs and an input the chip is programmable and have a ser. comm.
                                      I think that the chips are in a chain, the output voltages must appear in a sequence, when a chip is failing all its voltages doesn't appear, the acknowledgement for the next chip in the sequence is not activated so you lack also of all subsequent voltages, so i have said to you maybe i remember, the voltage sequences for a certain all in one so called "PMIC" chip, search back in the posts.
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        FIXED!!! I decided to have another go at this TV before it met the recycle bin, (spring cleanup around the house) and apparently the MLCC capacitor that I replaced on the panel board was not making a good enough connection I resoldered it again and perfect picture!!
                                        So all parties at were intrested, this particular T con board will not allow any power through the tcon board to the panel unless there are no shorts or "no opens" within the panel driver board MLCC capacitors!! Wierd setup!! I had never seen a TCON not attempt to output voltages if not connected to the panel but maybe I'm wrong. The side that had this shorted M LCC had the panel ID IC on it, So even though I was pretty sure the replaced M LCC capacitor was good it obviously was not. That's a 3 month problem finally solved. Now trying to put it back together is the interesting part..
                                        • Davi.p
                                          • Sep 2009
                                          • 4265
                                          • Italy - Milan
                                          #100
                                          • Daren87
                                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                            by Daren87
                                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                            08-13-2023, 03:25 PM
                                          • CyberPhoenix
                                            Issue with picture quality of Sony bravia TV
                                            by CyberPhoenix
                                            Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                            01-22-2024, 02:08 AM
                                          • noisykid
                                            Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                            by noisykid
                                            5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                            12-30-2024, 07:15 PM
                                          • thelankanguy
                                            Sony KD-55X9000F TCON Issue
                                            by thelankanguy
                                            The TV shows a black screen with no image.
                                            TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                            Later both ribbons were disconnected and TCON voltages were tested.
                                            12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                            There is also a short to ground in this circled inductor.
                                            Is this a TCON issue or something else ?...
                                            12-13-2024, 12:27 AM
                                          • bbrain
                                            Sony KD-55AG9 TCON?
                                            by bbrain
                                            I have this problem with my Sony 55' AG9.
                                            It flashes 4x.
                                            I have found the service manual, and seems it is the TCON.
                                            Before I buy a TCON can someone check the vid?
                                            Thanks in advance!...
                                            09-19-2024, 10:50 AM
