Sony XBR75X850C no picture backlights on
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4461
    • Italy - Milan
    #41
    Re: Sony XBR75X850C no picture backlights on
    Tell me the panel model number so i search the datasheet.
    • freakaftr8
      • Oct 2012
      • 3743
      Model name S750qf59 v0
      Model nunber 96.75S02.201
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4461
        • Italy - Milan
        #43
        Have you ever connected antenna so you can hear channels sound, or another input type?
        The model you write is not correct i think, i find no entries in the search... possible?
        • freakaftr8
          • Oct 2012
          • 3743
          Yes has perfect sound I can hear sounds of menus and options when I press them also I hooked up HDMI through my chromecast in heard a video playing.
          Also remember a while back when I was on my original Tcon, I had half the panel showing I when I heated up one of the voltage regulators. This is when I found the shorted MLCC on the panel board which has been replaced . At that time I only had one side connected but I could not reproduce it after a little while with heat.
          • freakaftr8
            • Oct 2012
            • 3743
            Ok no power here. Is the ICD1 on the right the master voltage regulator? It's dead. I can touch pin 3 to 2 on ICA1 or ICB1 and get roughly either 6.5 or 10.4v depending on which one I cross together. This is essentially bridging the path to the ICD3 to achieve 10.4v at AVDD.
            ICD4 also dead.
            • freakaftr8
              • Oct 2012
              • 3743
              I do have voltage here at all times at ICD2 for the 1.15 VCC
              • freakaftr8
                • Oct 2012
                • 3743
                Also On my original board I did not have any voltages either but when I heated up ICD3 suddenly everything came up but it only happened a few times and I had a picture
                • freakaftr8
                  • Oct 2012
                  • 3743
                  I suppose ICD1 could be the dc converter and gamma all in one. I've heard of this before.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Ok confirmed voltages are not turning on. Like I said before bridging ICA1 or ICB1 will generate a crosshatch flickering pattern because of crosstalk feedback and not a filtered DC bus to the AVDD, only supplying 10v to AVDD this way, where it need a a minimum of 16v I can see an image!
                    So DC regulators are for certain not being turned on. Why?
                    5 tcons later and same thing!
                    Is this the mainboard that has tok do the switching? Of course with this hack I still have no VCOM, VREF, or VGH, so it's not right however looks like the panel is trying to work.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4461
                      • Italy - Milan
                      #50
                      Sorry it's difficult for me, bad pictures, some terms i can't translate... the lack of testpoints.. Need better pictures but anyway without pwm generators datasheet are steps in the dark.. So you say that on ICD1,3,4 you have no 12v? On the last photo CL25 and CL20 which tension has?
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        On ICD1, 3 and 4, I've 5v VCC. On CL20 and CL25, 1.8v.
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          Obviously these 3 regulators are receiving VCC. But trying to find the turn on command pin... Have no idea
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Here's what I get bridging ICA1 or ICB1
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              Ok I backfed a 16v line into AVDD from another tcon. Found that the AVDD runs into CS29 here. Also ICD3 and ICD4 ARE receiving 12v also normally along with 5V on VCC.
                              I also noticed 16v at CG8 of ICD3. Because I'm backfeeding the 16v at AVDD from other tcon..
                              ICD4 thou, seems unaffected as i believe that IC drives VOFF and others it seems.
                              Still no voltage at HAVDD. This would be at point DSB1.. DSA1 is alive with the 16v from the feed off the other tcon.
                              Now in pretty sure that IF I was able to plug all the missing voltages as long as I knew the correct voltages for the panel operation, to the tcon, I bet I would have a perfect picture.
                              This is a major hack though, I'd like to know why I've managed to try 4 different tcons now all with the same result. Like I said earlier, I supplied 10v to AVDD and saw a jumpy misconstrued picture with the Sony menu screen and avaliable inputs.
                              So this leaves me to trying to determine exactly why the regulators are not switching on.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4461
                                • Italy - Milan
                                #55
                                Hey wait a moment! From the last picture i see the burnt mark on ICB1, is that mark made by your shorting sparks? Almost surely them are single mosfets even if them are called "IC" but the burnt is between gate and drain! Not good...
                                You don't know if that 5v is VCC or not, it can be a VREF, an internal LDO...
                                Where is this screen? You don't have taken picture...
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  Those are not burn marks, I touched up the solder pads what you're seeing is flux.
                                  As for the picture, I'll try to take one again tonight but I need to feed more than 10 V into HVDD as it is just not enough to produce stable image
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4461
                                    • Italy - Milan
                                    #57
                                    No i don't think, HVDD=Half VDD=15 or 16 /2= 7,5 - 8 v.
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      Right, well injecting 16v to AVDD, I do not get a half voltage regulation to to the circuit being dead. I could inject 8v at HAVDD and see what kind of a image I have however I still will not have any VOFF, VREF, VGHor VCOM.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4461
                                        • Italy - Milan
                                        #59
                                        No is wasted time without VOFF-VON!
                                        • freakaftr8
                                          • Oct 2012
                                          • 3743
                                          How would one succeffuly force the PWM circuit on in this instance?
                                          • iglitare
                                            Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                            by iglitare
                                            i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                            Backlight seems to work, Sound (Setup menu after reset) works.
                                            If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                            Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                            With my small knowledge i would think at least the cables are good.
                                            Can this happen because of a bad tcon board?
                                            Or is it always a bad/shorted...
                                            09-04-2025, 07:13 AM
                                          • Daren87
                                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                            by Daren87
                                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                            08-13-2023, 03:25 PM
                                          • CyberPhoenix
                                            Issue with picture quality of Sony bravia TV
                                            by CyberPhoenix
                                            Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                            01-22-2024, 02:08 AM
                                          • noisykid
                                            Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                            by noisykid
                                            5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                            12-30-2024, 07:15 PM
                                          • thelankanguy
                                            Sony KD-55X9000F TCON Issue
                                            by thelankanguy
                                            The TV shows a black screen with no image.
                                            TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                            Later both ribbons were disconnected and TCON voltages were tested.
                                            12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                            There is also a short to ground in this circled inductor.
                                            Is this a TCON issue or something else ?...
                                            12-13-2024, 12:27 AM
