Samsung un65es8000fxza turns off after 15-20 seconds
  • itelite
    • Aug 2016
    • 124
    Working on a un65es8000fxza with an issue i have not seen before.
    Turning on with the power button will turn it on, then after 15 to 20 seconds it will turn off.
    If you watch the standby voltage during this process a relay will click, standby is gone, relay clicks again standby is back for a fraction of a second, relay click, gone.
    If i unplug cable 20 from between the main board power supply the backlit will turn on and run indefinitely.
    Cable 20 has brown discoloration on of the 2 5v standby wires. I flipped cable around to rule out a bad connection (or at least move my bad connection) i also put a ammeter in place of that discolored wire. about half an amp until there isn't.
    Unplugged all cables from the main board as well just to rule out a shorted icon or something. no change
    Have not yet checked ESR on caps or diode function beyond obvious shorts with a DMM.
    I have read of firmware issues with this series, but there is 0 chance it will stay on long enough to perform an update. i do have several eeprom programmers of various type that i can use to flash the chip, but i didn't want to go that deep into it yet on the chance that i missing something already known.
    any ideas?
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Samsung un65es8000fxza turns off after 15-20 seconds
    Does the connector look like this?
      Another poor quality connector failure similar to this bulletin.
      • itelite
        • Aug 2016
        • 124
        yes it looks like that. Not quite as bad though.
        For what it is worth i took the wire in question (the browned 5v) and soldered it directly and confirmed a nearly 0ohm end to end. No change.
        I don't mind soldering all wires directly if it will help.
        Does it make sense that i lose all power rails when this happens? The timing is completely consistent as well. within 20 seconds of hitting power button it will do this.
        Do we know why this is actually happen? Some kind of current sensing safety shutdown or something?
        • itelite
          • Aug 2016
          • 124
          Just an update. I soldered both 5v wires and confirmed nearly ohm connection. Upon further investigation, i do not actually lose 5v standby voltage.
          It truly seems like its working electronically like it is supposed to but for some reason the shutdown signal is being asserted after 20 seconds. I have unplugged power button after hitting it to rule out an issue with the keyboard. no change.
          If watch the transistor on the main board that controls the PS_on signal, i can watch it open/close as i am experiencing the power off. That is to say, it does not seem like an abrupt power loss, but rathe a legitimate state change on the PS_on signal, and then the PSU responds accordingly.
          What is the PS_on expecting to see when on vs off? Is it just a high/low? Im wondering if i can control it manually for the moment an take the mainboard signaling out of the equation.
          I have noticed that their are Ebay and other sellers offering a repair service for this main board, they describe my issue almost exactly. Does anyone know what underlying issue they are fixing?
          https://www.nickstvs.com/store/p1344/BN94-06124Q
          • budwich
            • Jul 2015
            • 3097
            unplug tcon to panel cables (one at a time) and see if it changes anything.
            • itelite
              • Aug 2016
              • 124
              I actually unplugged the entire tcon board as an initial trouble shooting step. Is that not sufficient? I can certainly unplug from the panel as well, but it does require some additional disassembly on this one.
              • budwich
                • Jul 2015
                • 3097
                I guess I didn't read "that" (unplug of the tcon) in your description.... but it could be that the configuration of this tv is "integrated main / tcon".... don't know as you have provided no pictures of the layout. Depending of the design / layout, disconnecting certain portions may help determine the source of your issue.
                  If the PS-ON line is the only one that toggle LOW after 20 seconds, then you can do the experiment by disconnect that PS-ON wire going to the power supply board, I believe that the power supply board has pull-up resistor to keep the PS-ON high for field service troubleshooting and see if the TV will function without shutting down unless it has more than just bad PS-ON command problem or the main board gets an error signals from some where so it goes into shutdown.
                  I do not know if this power supply board has pull-up resistors for all the command signals or not, if it does then if you remove the cable between the power supply and the main board and then apply the AC then you should see the backlights come on and stay on as long as the board has incoming AC.
                  • itelite
                    • Aug 2016
                    • 124
                    Yes with the cable disconnected the main board, the power supply will light the backlight forever
                    Connecting the cable will immediately shut everything off. Well everything except 5v SB
                    Hitting the power button will light the backlight, turn on the 5V, 12v, and other signals. 20 seconds later, back to only 5V standby present.
                    • tvtimmy
                      • Mar 2015
                      • 1160
                      • usa
                      The mainboard is bad. More bad news, none on ebay, only repair service, for$175!!!!!
                      • itelite
                        • Aug 2016
                        • 124
                        Yeah ha i noticed that as well. I hate to scrap the thing if a repair is possible. Obviously it is if they are offering a repair service, but i have a feeling the only way I'm going to find out is to have the repair done and look for what was physically changed on the board. ugg.
                        In further troubleshooting i took the EEPROM off and read it. Although i can't directly translate it to anything meaningful, there is appropriate strings sprinkled throughout. Part number, date, etc. Problem is exactly the same even with the eeprom completely removed from the board. EEPROM has correct voltages on it in circuit.
                        Is there any kind of documentation available as to what the startup procedure may be?
                        Schematic of PSU and Mainboard? If i can get this figured out i am happy to share the secret, ha
                        • tvtimmy
                          • Mar 2015
                          • 1160
                          • usa
                          I hold on to high-end tvs for about a year in hopes I come across another with a busted screen. To date, I have only fixed 9 of the good ones I stored in shrinkwrap in the shed. All of craigslist.com is a good source to find doner tvs all over the usa.
                          • itelite
                            • Aug 2016
                            • 124
                            Well I've got some suspects to look into tomorrow
                            Parts list towards the bottom
                            https://cdn.badcaps-static.com/pdfs/...7a51209e28.pdf
                            Quite a few ICs that may possibly be at fault. If anyone sees anything on the list that jumps out to them as problematic, please let me know.
                            • budwich
                              • Jul 2015
                              • 3097
                              power supervisor... :-)
                              Have you tried entering the service mode to see if it stays on?
                              • itelite
                                • Aug 2016
                                • 124
                                Not sure how to get into service mode on this one. Don't have a remote, and the input is the newerish style control where its almost like a DPad. As well, i only have 16 seconds or so from power button push to do anything.
                                I was told that this was picked from the trash, and then worked for fine about 2 months before doing this. That screams bad connection/solder joint to me.
                                Based on the firmware file it looks like this runs something similar to a set top box style linux, so maybe i can hook into a UART somewhere and get some kind of debug info.
                                This feels like a rabbit hole to hell, but i really don't want to get beat by something apparently fixable. Well tomorrow is a new day i suppose.
                                  So the question is: Is PS-ON the only signal that goes LOW after 20 seconds but the BL-ON signal still staying HIGH?
                                  • itelite
                                    • Aug 2016
                                    • 124
                                    Well, the board is definitely holding down backlight enable. 0ohm to ground at times, 5ohm to ground at times. would think a legit high signal would be in Kohms at least (agree?)
                                    With that wire removed and ps on removed i get some wacky pattern on the screen. Not sure on sound yet.
                                    Backlight is massively flickering suggesting that the PWM is not working correctly either. Im now hopeful that there is a closed diode or cap somewhere on mainboard causing the holding down of the backlight. I suppose its time to trace from blu_on backwards.
                                    Image remains a mystery. Should be attached.
                                      The pictures should be normal if the only problem you have are the control signals.
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        power supervisor ... :-)
                                        • zklgfs
                                          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                          by zklgfs
                                          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                          Today, 02:14 PM
                                          09-07-2024, 05:50 AM
                                        • twonk9098
                                          Lenovo Legion 5 high fan spin turns off after 34 seconds
                                          by twonk9098
                                          I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                                          I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                                          I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                                          I have tried a few new bios but exactly...
                                          07-14-2024, 11:19 AM
                                        • MarkH8729
                                          Samsung UN46D6050TFXZA turns itself off 30 seconds after start
                                          by MarkH8729
                                          The TV turns on fine. TV started turning off on its own about 30 seconds after I power it on a couple of days ago. Ran just fine about 5 hours before this started happening but had been off for those hours. Problem started the first time after that. I have turned it on from the remote and from the front panel and see no difference in behavior.
                                          I have been able to turn it on multiple times and change channels and volume. The picture is good. The set just doesn't want to stay on.
                                          Based on info I found online, I have tried a soft reset (unplugged the TV for as much as...
                                          06-26-2023, 06:50 PM
                                        • EvansEssence
                                          Samsung UN55D6003SFXZA TV turns off after 20-30 seconds
                                          by EvansEssence
                                          Hey guys! I saved an older Samsung tv from the recycle bin to tinker with as a hobby. Looking for some help as to what else to check/replace.
                                          The issues it had at first was it would randomly reset its picture settings, this slowly devolved into it rebooting itself and the control board becoming unresponsive. Now it has finally gotten to the point where it no longer turns itself on when plugged in, but when I turn it on with the remote or power button it will boot to a blank input work for 15-20 seconds then turn itself off. I found if I pull up the menu it will actually freeze my...
                                          02-04-2023, 08:49 AM
