Samsung UN55D6003SFXZA TV turns off after 20-30 seconds
  • EvansEssence
    • Feb 2023
    Hey guys! I saved an older Samsung tv from the recycle bin to tinker with as a hobby. Looking for some help as to what else to check/replace.
    The issues it had at first was it would randomly reset its picture settings, this slowly devolved into it rebooting itself and the control board becoming unresponsive. Now it has finally gotten to the point where it no longer turns itself on when plugged in, but when I turn it on with the remote or power button it will boot to a blank input work for 15-20 seconds then turn itself off. I found if I pull up the menu it will actually freeze my control then turn off. The time to turn off is semi-consistent.
    I have tried reflowing the board, and even replaced the NAND flash chip (ic1302) and the same issue still occurs . I tried getting into maintenance mode (Mute - 1 - 8 - 2 - Power On) and the issue occurs in there too. Also tried factory resetting after NAND replacement and bridging the SDA / Reset.
    Any other ideas of what it could possibly be or what I could try? The Power board's capacitors look fine though I haven't tested them all with a multimeter yet.
    Thanks!
  • nomoresonys
    • 12206
    • U.S.
    Re: Samsung UN55D6003SFXZA TV turns off after 20-30 seconds
    with tv unplugged from power which it should be any time connecting cables, unhook one at a time of the wide flat cables and try tv, so youre trying it with one cable unhooked then plug it back in and try it with other cable unhooked.
    • lotas
      • Jan 2016
      • 4634
      • Russia
      There are nuances in this chassis, IC1301 SDIN5D2-2G (eMMC) and IC1302 KFG1GN6W2D (OneNAND) must be the same software version, and eMMC (IC1301) dies in the main.
      • nomoresonys
        • 12206
        • U.S.
        Great info Lotas, sure does seem like a memory issue.
        • EvansEssence
          • Feb 2023
          Ah, so its most likely my eMMC chip then? Anything I can do other than re-balling it and replacing? I think id just consider the board toast if I have to replace the eMMC chip
          • zklgfs
            Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
            by zklgfs
            I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
            08-11-2025, 02:14 PM
            09-07-2024, 05:50 AM
          • twonk9098
            Lenovo Legion 5 high fan spin turns off after 34 seconds
            by twonk9098
            I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
            I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
            I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
            I have tried a few new bios but exactly...
            07-14-2024, 11:19 AM
          • MarkH8729
            Samsung UN46D6050TFXZA turns itself off 30 seconds after start
            by MarkH8729
            The TV turns on fine. TV started turning off on its own about 30 seconds after I power it on a couple of days ago. Ran just fine about 5 hours before this started happening but had been off for those hours. Problem started the first time after that. I have turned it on from the remote and from the front panel and see no difference in behavior.
            I have been able to turn it on multiple times and change channels and volume. The picture is good. The set just doesn't want to stay on.
            Based on info I found online, I have tried a soft reset (unplugged the TV for as much as...
            06-26-2023, 06:50 PM
          • eigma
            Samsung UN40H5003 boot loop every ~8 seconds
            by eigma
            Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
            Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
            SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
            Main board: BN94-07592P / BN97-08922R...
            11-20-2024, 10:31 PM
