LCD screen layers...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8709
    Well, I guess I got pranked.
    I was holding an LCD by its base, but someone pulled the screws out unbeknownst to me. The base slipped out of the main cabinet and started to fall to the ground. Yow.
    I quickly tried to grab it before it hit the floor but instead the screen hit the piece of the base that I was still holding, scraping it!
    Now I suppose the scrape is better than the display hitting the floor but it still is a scrape...any suggestions on how to fix this? It seems to be a matte display and got gouged fairly deeply but the liquid doesn't leak out.
    Sounds like I need a whole panel to fix this ? Or can the top layer somehow be replaced?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: LCD screen layers...
    I've seen youtube videos on replacing film. Don't know were you would get polarized film
      It's properly bonded to the glass, I doubt you could replace it, if you could it would be like replacing the touch screen on an AMOLED phone (go very carefully with a hot air gun and peel slowly) but on a massive screen, I would not like to do that!
      • R_J
        • Jun 2012
        • 9623
        Just search for" replacing lcd polarizing film" lots of videos like these examples, like dskall said, finding the film might be tough, check this site http://www.lcdparts.net/Film3D.aspx
        some videos here
        https://www.youtube.com/watch?v=ygPrtXQ2e6U
        https://www.youtube.com/watch?v=a4cnrPMo6_s
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8709
          Ah interesting. Sounds like I'm stuck with the scratch
          Oh well, at least it still works and no crack, though it is very visible *sigh*
          • NeedsMoreFlux
            • Oct 2017
            • 121
            • California
            Can't "buff it out" with some automotive rubbing compound?
            Don't know if I'd even want to try that, lol. but maybe if you tried with a q-tip on a tiny part of the scratch. I'd probably try horizontal and vertical, rather than circles(?)
            Disclaimer!: READ THE DISCLAIMER IN MY SIGNATURE!
            Disclaimer: Don't trust a thing I say-I am frequently wrong!!!
            I have tons of spare parts, some used, some N.O.S. ham transistors and caps. Message me if you need any parts.
            Some of the things I've fixed:
            60" Vizio-bad LED's. iBook G4: Resoldered VCC Plug. Geo Tracker ECU: Swollen / Leaking capacitors. Windows Laptop: Soldered broken LVDS wires. Dryer: Burned contact on temp switch. Oven in R.V.: Bad contacts in relays-Exploded by the looks of them! Samsung Oven: Burned contacts on Relays. MSI Motherboard: BSOD-Swollen capacitors, bad graphics card, Moved SATA Input from SATA 1 to SATA 2 plug
            • attainteddragon
              • Apr 2013
              • 764
              • australia
              i'm currently doing an experiment on a screen that is scratched. i'm sanding the surface and then clear coating it. not sure how it is going to pan out yet.
              WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
              • NeedsMoreFlux
                • Oct 2017
                • 121
                • California
                OOSH! Id start on a small corner that you wont notice. Or maybe on just a tiny part of the scratch.
                I wouldn't want to EFF it up by jumping in feet first and doing the entire thing.
                • attainteddragon
                  • Apr 2013
                  • 764
                  • australia
                  my test unit is one that has a tab bond failure that i can put pressure on to get a clear picture, so it is the perfect candidate.
                  i'm thinking that i'll need to use a matt clear.
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    It's a polarising film, put on for a reason. Matt clear will not deflect the light as the film does.
                    • attainteddragon
                      • Apr 2013
                      • 764
                      • australia
                      that is very true. luckily i would not be removing it. it is the blending over the scratched area that is the only real concern.
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • reformatt
                        by reformatt
                        07-31-2025, 08:37 PM
                      • smic717394
                        by smic717394
                        07-25-2024, 10:16 AM
                      • Chrissygizmo
                        by Chrissygizmo
                        02-10-2025, 12:33 AM
                      • spice_disc
                        Vizio TV M50-C1 reboot cycle and static on screen
                        by spice_disc
                        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                        09-08-2024, 02:37 PM
