Rca picture in half??
  • parkerc
    • Jun 2014
    • 17
    • usa
    RCA LED55C55R120Q picture is backwards(left side and right side swapped?)otherwise has clear picture. I have attached pics .If you look closely there is a thin line dead center of screen . HELP!!
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Rca picture in half??
    Mainboard issue. Possible eeprom related.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Has it been worked on?
      • budwich
        • Jul 2015
        • 3097
        main board from another size set?
        • parkerc
          • Jun 2014
          • 17
          • usa
          Replaced led strips. swapped all boards ,Is there an eeprom update? Can the screen layers cause a problerm? Thanks for the input!
          • dskall
            • Oct 2016
            • 2905
            • usa
            Are ribbon cables to panel correct?
            • parkerc
              • Jun 2014
              • 17
              • usa
              Seems to be connected properly
              • dskall
                • Oct 2016
                • 2905
                • usa
                Got pictures of back of tv?
                • parkerc
                  • Jun 2014
                  • 17
                  • usa
                  Here they are??
                  • parkerc
                    • Jun 2014
                    • 17
                    • usa
                    Is there a firmware upgrade for this TV??
                    • NeedsMoreFlux
                      • Oct 2017
                      • 121
                      • California
                      Pssh!
                      Its the fricken Zebra cable connecting the very last wire to the LCD panel-The thin cable soldered directly to the glass panel.
                      Try pushing lightly on the plastic bezel under the missing line. Does it get better?
                      Try pushing lightly on the LCD panel. Does it get worse?
                      You'll probably have to actually lay it on its back and remove the bezel around the screen, then push very lightly on the very thin and delicate flat cable connecting the TConn to the LCD. A rubber eraser may be helpful. If it goes away then the solder joints have separated. The only way to fix it is to use a hot air gun or soldering iron to reattach them while pushing down lightly, gently and carefully(basically on the edge of the glass!). Silicon would be helpful here.
                      This sort of job is best left to an experienced professional. the manufacturer uses a long tool that pushes down and heats up the solder.
                      Disclaimer: Don't trust a thing I say-I am frequently wrong!!!
                      I have tons of spare parts, some used, some N.O.S. ham transistors and caps. Message me if you need any parts.
                      Some of the things I've fixed:
                      60" Vizio-bad LED's. iBook G4: Resoldered VCC Plug. Geo Tracker ECU: Swollen / Leaking capacitors. Windows Laptop: Soldered broken LVDS wires. Dryer: Burned contact on temp switch. Oven in R.V.: Bad contacts in relays-Exploded by the looks of them! Samsung Oven: Burned contacts on Relays. MSI Motherboard: BSOD-Swollen capacitors, bad graphics card, Moved SATA Input from SATA 1 to SATA 2 plug
                      • budwich
                        • Jul 2015
                        • 3097
                        Originally posted by parkerc
                        Here they are??
                        I think the "other guy" was asking for pictures of the back of the set WITH the back cover removed.... :-) so he can see what's happening with the cabling.
                        • NeedsMoreFlux
                          • Oct 2017
                          • 121
                          • California
                          Here's an example:
                          https://www.youtube.com/watch?v=UNf81Z-i1FE
                          • NeedsMoreFlux
                            • Oct 2017
                            • 121
                            • California
                            Oh, HAHAHAHA. NEVERMIND! I should have clicked on the photos. I thought it was just a black line!
                            LOL. DON'T LISTEN TO ME!!!
                            • augiedoggy
                              • Aug 2016
                              • 62
                              • united states
                              kinda looks looks like the transmission is set to sbs 3d mode... are you sure the lcd panel tcon cables werent installed backwards somehow?? that or its set to a different panel type in diagnostics.those rca branded sets use the same main baord numbers for many different model tvs with different firmware and sometimes hardware... I had a 50" I repaired give me grief because a seller of the replacement mainboard made and assumption and sold me the wrong board.... you have to be sure the serial number range matches the part number for the board and not just the number printed on the board itself.
                              • augiedoggy
                                • Aug 2016
                                • 62
                                • united states
                                Here they are??
                                Is this a joke? Come on man these pictures are useless.. You didnt even get the model number it the one legible pic...
                                • parkerc
                                  • Jun 2014
                                  • 17
                                  • usa
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    In order to properly diagnose your TV we need clear pictures of each board in the back of the set which means removing the back cover. We need good clear pictures of mainboard LVDS cable, tcon board including cable connections going into the LCD panel itself. This could be a fault with the LVDS cable or the tcon board or the main board sending the output signals into the tcon to the LCD panel
                                    • kca
                                      by kca
                                      Hello all ~
                                      08-31-2025, 06:38 AM
                                    • sigmeyer
                                      43UM7100PLB, no picture but have half picture when i disconnect 1 side of panel
                                      by sigmeyer
                                      Like the title says , this is a very interesting problem , never experienced this before so i thought i'd share and maybe get some help on this. So the problem is as such: TV comes on , some gibberish flashes on screen and the screen remains black , the owner of tv said he heard sound. Now i checked some things cleaned all connections first of all so i dont run in a circle. Then i disconnected one of the cables for the panel , and viola, the left side of screen comes on, then i tried to switch it , with left side disconnected and right connected. Same problem persists. I checked some voltages...
                                      09-09-2021, 10:30 AM
                                    • Tr0ll
                                      by Tr0ll
                                      Original T-con:
                                      First replacement T-con:
                                      10-07-2023, 07:48 PM
                                    • Patrick501
                                      Philips 55PUS6704 no picture, backlight ok
                                      by Patrick501
                                      I'd like to repair a Philips 55PUS6704.
                                      It turns on and you can see the backlight, hear the sound but no picture.
                                      When I disconnect one of the T-con cables, half of the screen turns white.
                                      right cable disconnected= right side white
                                      left cable disconnected= left side white
                                      When I tape like 6 or 7 pins of one cable it looks like the picture attached. I already tried another T-con board without success.
                                      There are no shorts on the the mainbaord and the two lcd panel boards...at leat I couldn't find any.
                                      Also you can notice one single...
                                      11-12-2025, 08:46 AM
                                    • howardc64
                                      Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                      by howardc64
                                      TV was fixed just after removing Samsung's rear snap cover.
                                      This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                      Maybe PSU->backlight connector didn't have a good contact?...
                                      07-23-2025, 12:34 AM
