RCA LED55C55R120Q picture is backwards(left side and right side swapped?)otherwise has clear picture. I have attached pics .If you look closely there is a thin line dead center of screen . HELP!!
Rca picture in half??
Re: Rca picture in half??
Mainboard issue. Possible eeprom related.Did I leave the soldering iron on? -
Pssh!
Its the fricken Zebra cable connecting the very last wire to the LCD panel-The thin cable soldered directly to the glass panel.
Try pushing lightly on the plastic bezel under the missing line. Does it get better?
Try pushing lightly on the LCD panel. Does it get worse?
You'll probably have to actually lay it on its back and remove the bezel around the screen, then push very lightly on the very thin and delicate flat cable connecting the TConn to the LCD. A rubber eraser may be helpful. If it goes away then the solder joints have separated. The only way to fix it is to use a hot air gun or soldering iron to reattach them while pushing down lightly, gently and carefully(basically on the edge of the glass!). Silicon would be helpful here.
This sort of job is best left to an experienced professional. the manufacturer uses a long tool that pushes down and heats up the solder.Last edited by NeedsMoreFlux; 11-30-2017, 07:13 AM.Disclaimer: Don't trust a thing I say-I am frequently wrong!!!
I have tons of spare parts, some used, some N.O.S. ham transistors and caps. Message me if you need any parts.
Some of the things I've fixed:
60" Vizio-bad LED's. iBook G4: Resoldered VCC Plug. Geo Tracker ECU: Swollen / Leaking capacitors. Windows Laptop: Soldered broken LVDS wires. Dryer: Burned contact on temp switch. Oven in R.V.: Bad contacts in relays-Exploded by the looks of them! Samsung Oven: Burned contacts on Relays. MSI Motherboard: BSOD-Swollen capacitors, bad graphics card, Moved SATA Input from SATA 1 to SATA 2 plugComment
Oh, HAHAHAHA. NEVERMIND! I should have clicked on the photos. I thought it was just a black line!
LOL. DON'T LISTEN TO ME!!!Disclaimer: Don't trust a thing I say-I am frequently wrong!!!
kinda looks looks like the transmission is set to sbs 3d mode... are you sure the lcd panel tcon cables werent installed backwards somehow?? that or its set to a different panel type in diagnostics.those rca branded sets use the same main baord numbers for many different model tvs with different firmware and sometimes hardware... I had a 50" I repaired give me grief because a seller of the replacement mainboard made and assumption and sold me the wrong board.... you have to be sure the serial number range matches the part number for the board and not just the number printed on the board itself.Last edited by augiedoggy; 11-30-2017, 04:12 PM.Comment
In order to properly diagnose your TV we need clear pictures of each board in the back of the set which means removing the back cover. We need good clear pictures of mainboard LVDS cable, tcon board including cable connections going into the LCD panel itself. This could be a fault with the LVDS cable or the tcon board or the main board sending the output signals into the tcon to the LCD panelDid I leave the soldering iron on?Comment
by sigmeyerLike the title says , this is a very interesting problem , never experienced this before so i thought i'd share and maybe get some help on this. So the problem is as such: TV comes on , some gibberish flashes on screen and the screen remains black , the owner of tv said he heard sound. Now i checked some things cleaned all connections first of all so i dont run in a circle. Then i disconnected one of the cables for the panel , and viola, the left side of screen comes on, then i tried to switch it , with left side disconnected and right connected. Same problem persists. I checked some voltages...
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
by howardc64TV was fixed just after removing Samsung's rear snap cover.
This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
Maybe PSU->backlight connector didn't have a good contact?...07-23-2025, 12:34 AM -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by DXseekerMOSo here we go with another screen short TCL. For this exercise left and right will be reference looking at the screen.
The person I got this TV from said the color was bad in a vertical fashion about 1/4 of the way over the left side of the screen. Shortly after the symptoms below started.
Power Supply, main and T-CON board are working.
Symptoms: The TV has backlights but no picture with both FFC's attached to the T-CON and does not respond to the remote or buttons, and the TV appears to continuously re-boot.
Unhook FFC from left side... - Loading...
