Sony KDL-42W705B green and amber led
  • joosuas
    • Nov 2017
    • Finland
    Hello!
    My Sony KDL-42W705B got a broken tcon and I replaced it. After powering on with new tcon board, led started to flash green and amber/orange. I read that it would like to have a firmware update. Made a USB stick with latest firmware but how do I update my TV when I can't get any picture to it?
    Or is it something else what I need to do than fw update?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sony KDL-42W705B green and amber led
    What symptom were you experiencing that you decided to replace the T-CON Bd. I see you say 'broken'. Does that mean it was in pieces??
    • joosuas
      • Nov 2017
      • Finland
      First I got vertical lines to picture and after few weeks I lost picture completely. Audio was still working and backlight also.
      • chrle
        • Sep 2013
        • 158
        • slovakia
        I have same problem,just downloaded firmware from sony website ,formated usb stick NTFS,copied file on the root of usb stick.
        put usb stick to TV usb port and turn on tv,wait about 15 min till light on tv is white.
        and still no picture just sound .
        • shahnld
          Sony kdl 65xg9505 green amber blinking
          by shahnld
          Good Day.
          I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
          i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
          green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
          01-03-2024, 03:05 PM
        • 0xx
          2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
          by 0xx
          Hi folks,
          My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
          What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
          I assumed that Windows Update was interrupted due to closing...
          09-14-2025, 03:46 PM
        • mrsith
          Sony KDL-55W755C - Dead
          by mrsith
          Hello again lifesavers.
          I have a KDL-55W755c that came in dead - not even standby light going on. Tested the power supply - all correct. Tested the output pins on the Led driver board (in which the power cord plugs in) - all seemed fine.
          I got a service manual for this model and tested the DC/DC converter by checking voltages on selected components. Every voltage was present where it should be. Service manual says that in this case a "Muffin" replacement is needed. This is the moment where I got stuck as I wasn't able to Google my way through it - till this day I...
          11-28-2022, 12:42 PM
        • jimjoe123
          LCD TV Green/Pink screen problem
          by jimjoe123
          I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
          Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
          Then each time...
          02-23-2020, 01:29 AM
        • Nopy
          Sony KDL-55EX500 solid green screen
          by Nopy
          I have a Sony KDL-55EX500 which shows a solid green screen and I haven't been able to diagnose the problem. I was able to find a repair manual online and read a few forums on tv repair which pointed me towards it possibly being an issue with the power board or T-con board. Bad electrolytic capacitors seemed to be a common theme so I tried replacing all of the ones on on the power board, but that didn't fix it.
          My next step was disconnecting all of the cables and reconnecting them. That helped a bit, showing a normal screen most of the time, but still switches back to solid green...
          03-08-2022, 07:48 PM
