Accidentally touched multi meter lead to multiple pins on power supply.Vizio E400i-B2
  • S.gilletly
    • Nov 2017
    • 28
    I am currently attempting to fix my TV and my sisters TV. I recently took voltages from my sisters E400i-B2 vizio power supply. I accidentally touched multiple pins with my lead on CN201. Pins 7-12v and 8 -12v where both reading between 10-10.8vdc when powered on. since I touched multiple pins at once and caused a quick arc the same pins are now reading 3.7dvc when on and off. I'm lost at this point. Any information would be great. thank you
    Re: Accidentally touched multi meter lead to multiple pins on power supply.Vizio E400
    1) We need god clear hi-res pictures so we can what we are dealing with.
    2) We need to know what the TV's are doing or not doing before you start working on them.
    • S.gilletly
      • Nov 2017
      • 28
      Sorry for the late reply. I have attached pictures to my sisters vizio E400i-B2. The readings I'm getting both on and off are listed below. However, prior to touching my multimeter lead to pin 7 and 8 at the same time I was getting 10dvc on all the 12v pins.
      Readings on multi meter on and off
      5-vsb 5v
      5-vsb 5v
      ACDET 3.2v
      PSON 2.9v
      GND zero
      GND zero
      12v 3.7v
      12v 3.7v
      GND zero
      GND zero
      12v 3.7
      12v 3.7
      nc
      nc
      nc
      By the way i'm only looking to replace entire boards for this project maybe that will be easier to narrow down the cause.
      • S.gilletly
        • Nov 2017
        • 28
        Oh I forgot to mention that prior to me testing the TV the reason why I began to troubleshoot was the TV stopped Turning on.
        • vinceroger69
          • Mar 2012
          • 6714
          can you also take a good clear picture of the underside of the power supply so we can see the traces and components on it thanks.
          • jetadm123
            • 2169
            The black connector at the top of your power supply is 24 volts. What are you reading for that?
            • R_J
              • 9627
              Check Q202, located on the back of the board near CN201, it may be open You could also check the voltage on D202 (center pin) and see what that voltage is
              • S.gilletly
                • Nov 2017
                • 28
                Hey once again my apologizes for the delayed response. I was at work. @Jetadm123 the black connector is reading 25.6dvc. @vinceroger69 I have also uploaded a picture of the underside of the power supply. @R_J for Q202 11.85dvc and D202 11.86dvc
                • R_J
                  • 9627
                  Q202 has 3 (2 small plus the tab) legs, I can't read the number on it but if you have close to 12 volts on the small leads and nothing on the tab that goes to the connector, I suspect the transistor/fet is open.
                  • S.gilletly
                    • Nov 2017
                    • 28
                    i have close to 12 volts on the small leads and about 3.66 volts on the tab. When you say you suspect the transistor/fet is open. I actually have no idea what that is. I'm a novice when it comes to all this however, is this somthing that is related to the power supply?
                    • R_J
                      • 9627
                      That black plastic part with the 2 legs and the tab, I suspect it is bad. It has a number on it... what is the number on it?
                      I suspect it is a mosfet
                      • S.gilletly
                        • Nov 2017
                        • 28
                        B16 P04 EG 2520. does this sound about right ?
                        • R_J
                          • 9627
                          Yes it's a fet, the full number would be EMB16P04A
                          12 volts enters the source pin and when the gate gets turned on (which it is) 12 volts will be at the Drain. Its basically a switch
                          I guess its possible something is loading the 12 volt line down but since you shorted that line I would bet on the bad fet
                          • S.gilletly
                            • Nov 2017
                            • 28
                            do you feel this will fix the powering on issue or just fix the voltages on the CN201? as i described before I caused an arc by touching two of the 12v pins which caused the voltages to go from 10volt to 3.7volt?
                            • R_J
                              • 9627
                              Replacing the fet should get you back to where you were before shorting the pins
                              Did the tv try and turn on? ie did the power led come on?
                              Did you have any sound? or backlights?
                              I suspect if you were getting 12 volts (or 10v) and also had +24 volts, the power supply was working and the power supply WAS getting the power on command from the main board
                              The 12 volts being low could be due to poor C228, C229 or C206
                              Being that this is a @$%^ vizio, I might suspect the eeprom
                              • S.gilletly
                                • Nov 2017
                                • 28
                                thank you
                                • S.gilletly
                                  • Nov 2017
                                  • 28
                                  i will update after i'm done.
                                  • S.gilletly
                                    • Nov 2017
                                    • 28
                                    there was no sound and the power led would not light up
                                    • S.gilletly
                                      • Nov 2017
                                      • 28
                                      is vizio known for having faulty eeproms? also what happens when an eeprom goes bad?? like what are the tv symptoms usually ?
                                      • R_J
                                        • 9627
                                        If the eeprom goes bad usually you can't turn on the tv, or maybe the led will come on but thats all. The eeprom contains the proccessor code and if it gets corrupt or cant be read the microprocessor does'nt know what to do.
                                        Did the tv show any signs of life before the short?
                                        • jkucukov
                                          Help with Samsung Microwave Cooling Fan Wiring Pins
                                          by jkucukov
                                          I have a Samsung Microwave I'm looking to harvest some parts from, specifically the 120V AC motor that keeps the Magnetron cool.
                                          From the image below, we see 3 pins on the AC motor, with AC Voltage tester all 3 leads measure 120 V with the microwave plugged in and fan not running. With the fan running only pins 2 & 3 measure 120 V.
                                          What I'm looking to do is wire this motor up on a Air Compressor to keep the motor cool, but I need to know what is the safe way to wire it, (IE wire in pins 2 & 3 with 120 V only to get it to run?)
                                          Also, as its wired, when...
                                          Yesterday, 05:02 PM
                                        • corrize
                                          Where to find a very small fpc connector 0.3mm between 2 pins ?
                                          by corrize
                                          Hello, I search this connector (oxydated).
                                          It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                                          I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                                          I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                                          Do you know how to find this connector please ? What is the exact name for find it ?
                                          08-06-2024, 05:25 PM
                                        • langbaobao
                                          DIY 3D-Printer WSON8 Pogo Pin Adapter
                                          by langbaobao
                                          Hi.
                                          I'm posting this here in part as a memo to self as well as to describe the procedure I used in case anyone else found it useful. I found a lot of the necessary information to make this work on this forum and I figured I would give something back. If this is not the appropriate place to post this, I don't mind it being deleted but I hope it can help other people.
                                          I got an admin password locked HP Elitebook 840 G5 recently that I wanted to unlock. I'm a relative newcomer to reprogramming and unlocking firmware. The only previous experience I had was unlocking a BIOS...
                                          01-08-2024, 05:58 PM
                                        • CG2
                                          Meaco Arete One / Deye Dehumidifier not working
                                          by CG2
                                          I've got a dehumidifier that has stopped working. Plug it in, press the power switch, and it beeps 5 times. Nothing showing in the display (which is just two 7 segment displays) apart from the two decimal points flashing. The model is a MeacoDry Arete One 18L, which seems to be a rebadged Deye (all the boards are marked Deye). Here's what I've got so far (details in case anyone else in future should need them).
                                          Starting with the power board. Mains power comes in at the red connector top left. The compressor is powered by the orange connector to the right of that and is switched by...
                                          08-17-2024, 07:47 AM
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
