Accidentally touched multi meter lead to multiple pins on power supply.Vizio E400i-B2
  • S.gilletly
    • Nov 2017
    • 28
    Re: Accidentally touched multi meter lead to multiple pins on power supply.Vizio E400
    nothing
    • S.gilletly
      • Nov 2017
      • 28
      Status update. PROBLEMS SOLVED! after fixing the power supply it turned out to be a bad Tcon board. Tv works !!!v Thanks for all the help
      • jkucukov
        Help with Samsung Microwave Cooling Fan Wiring Pins
        by jkucukov
        I have a Samsung Microwave I'm looking to harvest some parts from, specifically the 120V AC motor that keeps the Magnetron cool.
        From the image below, we see 3 pins on the AC motor, with AC Voltage tester all 3 leads measure 120 V with the microwave plugged in and fan not running. With the fan running only pins 2 & 3 measure 120 V.
        What I'm looking to do is wire this motor up on a Air Compressor to keep the motor cool, but I need to know what is the safe way to wire it, (IE wire in pins 2 & 3 with 120 V only to get it to run?)
        Also, as its wired, when...
        11-24-2025, 05:02 PM
      • corrize
        Where to find a very small fpc connector 0.3mm between 2 pins ?
        by corrize
        Hello, I search this connector (oxydated).
        It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
        I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
        I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
        Do you know how to find this connector please ? What is the exact name for find it ?
        08-06-2024, 05:25 PM
      • langbaobao
        DIY 3D-Printer WSON8 Pogo Pin Adapter
        by langbaobao
        Hi.
        I'm posting this here in part as a memo to self as well as to describe the procedure I used in case anyone else found it useful. I found a lot of the necessary information to make this work on this forum and I figured I would give something back. If this is not the appropriate place to post this, I don't mind it being deleted but I hope it can help other people.
        I got an admin password locked HP Elitebook 840 G5 recently that I wanted to unlock. I'm a relative newcomer to reprogramming and unlocking firmware. The only previous experience I had was unlocking a BIOS...
        01-08-2024, 05:58 PM
      • CG2
        Meaco Arete One / Deye Dehumidifier not working
        by CG2
        I've got a dehumidifier that has stopped working. Plug it in, press the power switch, and it beeps 5 times. Nothing showing in the display (which is just two 7 segment displays) apart from the two decimal points flashing. The model is a MeacoDry Arete One 18L, which seems to be a rebadged Deye (all the boards are marked Deye). Here's what I've got so far (details in case anyone else in future should need them).
        Starting with the power board. Mains power comes in at the red connector top left. The compressor is powered by the orange connector to the right of that and is switched by...
        08-17-2024, 07:47 AM
      • SS454
        vizio e650i-a2 backlight flashes then turns off
        by SS454
        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
        panel: au optronics T650HVN05.4
        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
        https://www.shopjimmy.com/vizio-56-0...-power-supply/
        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
        08-20-2020, 03:57 PM
