Smps (bn 44-000333a)
  • Rusty Brown
    • Nov 2017
    • 3
    Need Help in Learning
    I would like to test the board (BN 44-00333A). I have a few questions regarding reading label on connector CN801 (SMPS to Main board).
    Label
    15V PS-ON
    15V STBY
    5.3V 5.3V
    5.3V RTN
    RTN RTN
    15V RTN
    15V NC
    15V NC
    Question: 1 – The voltages given in the left column. Are these the voltages when the TV is in ON position and the voltages on right column, when the TV is in standby positon or it is something else?
    Would you explain the followings?
    PIN 3 from top: 5.3V 5.3V
    PIN 8 from tip: 15V NC
    Question 2: From my research, the STBY voltage is 5V. However, on (BN 44-00333A) it is 15V. Is it correct?
    Question 3: Self testing SMPS
    It requires the followings modifications on CN 802 (SMPS to Logic Board)
    a) Use jumper cable, connect PS-ON pin with RTN pin.
    b) Similarly, connect pin VS-ON with pin STBY5V. In my case STBY is 15 volts. Do I have to use pin (15 V STBY) or I have to use some other pin with 5 volts.
    c) Read voltages on SMPS.
    Thank you.
  • R_J
    • 9627
    Re: Smps (bn 44-000333a)
    There are two rows of pins on that connector
    IE: pin 17 = 15vamp pin 18 = PS-ON
    pin 15 = 15Vamp pin 16 = STBY
    pin 13 = 5.3V pin 14 = 5.3v
    pin 11 = 5.3v pin 12 = RTN
    etc
    stby would be +5 volts
    NC means No Connection
    RTN return or ground
    If the power supply board has pull up resistors for the pS-ON then unpluging the connector to the main board would turn the power supply on. If it does'nt then with the mainboard plug disconnected, put about a 1K resistor between PS-ON and STBY +5
      The connector CN801 has ODD Column pins which you can see and probe from the tops side of the board, the EVEN Column pins you will have to probe from the back side of the connector where the wires go in or flip the board over to get to the even pins.
      The label for each pins show what their functions are.
      If you look at the print you will see that
      The ODD column pins are:
      Pin 1, 3, 5 are 15V
      Pin 7, 9 =GND return
      Pin 11, 13 = 5.3V
      Pin 17, 15 are for 15V amp
      The EVEN Column pins are as shown on the print, I.E. Pin 18 = PS-ON
      The power supply board will have Standby Voltages, Switched Voltages, the Command Voltages. So you will to learn what the Voltages are on how the board functions.
      Pictures provided by Shopjimmy.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Excellent......So with a 1Kohm resistor connected across the Pin 11: PS-On and Pin 18: 5.3V on CN801. Connect two (2) 120Vac 60Watt house light bulbs in series and connect that across Pin 1: VS and Pin 3: RTN on CN804. Then plug into ac. If the PSU is good the house light bulbs will glow bright and you can measure VA:54-56Vdc on CN804 and Pin 1:15Vdc on CN801 and Pin15:15Vdc on CN804
        • Rusty Brown
          • Nov 2017
          • 3
          Thank you R J, BUDM and Andrew F. Ali for you kind help.
          TV: Samsung Plasma, Model PN50C7000YF
          Please let me know if the following procedure is correct to test SMPS (BN 44-00333A). I want to be sure before doing any testing.
          1. Disconnect all cables from the board.
          2. Connect power and measure STBY (5 V) and PS-ON voltage (2.5 – 5 V) on CN 801.
          3. On connector CN 801 (SMPS to Main Board) short PS-ON pin with ground. Check Va (it should be 55 volts).
          Question: Can I use CN 802 (SMPS to Logic Board) for this purpose.
          4. On CN 802, supply 5V to VS-ON pin. Any 5V pin (from CN801 or CN 802) can be used. Check for Vs voltage (it should be 211 volts).
          If all the conditions are met, then the SMPS is good.
            Most Samsung power supply boards for Plasma TV use ACTIVE LOW 9Ground the PS-ON pin = ON) to turn on the power supply, so run the power supply board by itself and then check the DCV on the PS-ON pin to see if it shows >2V or so and report the reading.
            Found the diagram and it looks like it has pull-up resistor for the PS-ON so it looks to be ACTIVE HIGH. I did not look at the schematic in details yet.
            • Capacitorial
              Powersupply has all the voltages - Monitor still no power
              by Capacitorial
              Hello guys,
              I have a Philips 240B7QPJEB. The monitor seems completely dead.
              I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
              On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
              The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
              The weird thing is, that the Power LED is powered over the TCON board.
              On The TCON...
              12-28-2024, 02:12 PM
            • beetle1303
              Wine Chiller - SMPS issue - fluctuating voltages
              by beetle1303
              My wine chiller, TECNO SW-126LCD, is semi-functional - it powers up, can set temperature, and chilled to the set temperature, and cuts off compressor, etc. It however runs very hot.
              Upon taken out the PSU and did some basic check - 5V output to LCD panel buttons and display is stable, but there is no 12V output to LED lights, and fans.
              Further checks found the secondary side voltage is fluctuating around 8-15V range, but the 7805 regulator seems ok and producing the stable 5V output.
              Checking further on the primary side: Incoming line input to bridge...
              09-04-2023, 10:33 AM
            • Francesc V.
              Computer SMPS has voltages from a moment and then disapear
              by Francesc V.
              Hi:
              I am trying to repair a 1000W cheap power supply, but so far, with no much success.
              The ATX has stable 5V STBY.
              When shortening PsuON to ground, it triggers all voltages for a fraction of a second and then disapear (I see the leds flashing for a moment from the ATX tester)
              - I removed and tested the capacitors. They are OK.
              - Removed and tested the Output rectifiers from the secondary.
              - Removed and tested the Mosfets from the primary.
              - Outputs are not shorted.
              - Overakk review of the solder joins.
              04-15-2025, 01:54 PM
            • dkneyle
              Onkyo DX-V500 Laser Disc Player - weird SMPS fault
              by dkneyle
              This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
              Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
              02-01-2022, 02:08 AM
            • shamsudeen
              Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
              by shamsudeen
              Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
              I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
              i know that in linear power supply the noise will be very low comparing to SMPS supply....
              07-19-2025, 07:14 AM
