EU40F6400 startup failure
  • aurelienr
    • Nov 2017
    • 25
    • France
    Hi guys
    I have a a EU40F6400 TV and when I was watching a movie suddenly image became black, but sound was ok. After restart, same problem, and I noticed that the power LED was blinking 5 times at startup before shuting down (but sound still present when I press the remote control).
    Then I have open the TV to look at the PSU, ref BN44-00622B.
    Both fuses are tested ok. Relay is ok.
    No traces of any damage on both board faces.
    All the capacitors seems like new !
    I get the schematics here :
    For the moment, I have checked the voltages on the backlight connector (and directly on the output caps). This is what I measure :
    C9154 : 40V (schematic specify 43V)
    C9254, C9354, C9454 : 95V (schematic specify 85V)
    Same measurements with either the backlight cable connected or not.
    I'm not sure if I should order a new PSU (100 euros) or not. Since caps are ok (voltages measures on all others caps seems valid, approx 5V and 12V respectively), what kind of failure could I suspect ? Would it be possible that the error come frm the backlight ? It should be wired because it seems to have 4 backight power lines, all the sections failing at the same time is unusual...(but I'm not sure of backlight composition).
    Thanks !
    Aurelien
  • CapLeaker
    Leaking Member
    • 8146
    Re: EU40F6400 startup failure
    Plug in the backlights to the PSU and unplug the main board from it. Plug the PSU into mains and the backlights should turn on.
    IF they don't:
    Check the LED voltage on EACH string at the PSU and report the voltages measured. I think you have a backlight problem at the LED's. I am not convinced (yet) that the PSU is at fault. Also upload some high resolution, straight shot pictures, please.
    • aurelienr
      • Nov 2017
      • 25
      • France
      Hello
      Thanks for the advice.
      I made your test and backlight is on, as you can see on pictures.
      However I noticed a small black round on the screen (circled in red on the photo, the other shadows are myself and a lamp), but since this is an edge LED backlight, I don't think it comes from a LED failure ?
      EDIT : maybe the circle shadow come from a small plstic piece that falls under the matal plate (you can see a high light spot where the piece was placed)
      Tell me if you need more pictures.
      Aurelien
      • CapLeaker
        Leaking Member
        • 8146
        Plug in the main board to the PSU and turn the TV on. Measure the DC voltages on each pin of that connector and post it here in a format of pin#, pin name, voltage measured.
        There is somewhere a pin called BLon (comes from the main and tells the backlights to turn on), also DIM etc. Let's see what these voltages are...
        • aurelienr
          • Nov 2017
          • 25
          • France
          So :
          - 5V is present on A5V and B5V pins
          - 12.6V is present onVamp and B13V pins
          - the EPWMx pins are all at 0
          - the PS_On/Off is at 3.3V
          - the OD_On/Off is at 3.3V
          - the BLU_On/Off is at 5V
          Mother board ref is BN41-01958A
          Aurelien
          • aurelienr
            • Nov 2017
            • 25
            • France
            Looks like MB does not handle PWM signals correctly, but why ?
            The signals that come from PSU to MB are only power supplies that are good (5V and 13V). So MB does not generate correctly the PWM.
            It may be either an hardware issue on the PWM generation, or a problem with the source that determine the PWM power. Is there any ambient light sensor somewhere ?
            • CapLeaker
              Leaking Member
              • 8146
              Could you upload a high resolution, straight shot picture of each board?
              • aurelienr
                • Nov 2017
                • 25
                • France
                Here we go...
                https://we.tl/PcDVyCZ1h2
                FYI, the MB<>PSU cable and connectors/contacts are not damaged.
                • aurelienr
                  • Nov 2017
                  • 25
                  • France
                  Should I be able to see a very low image without backlight ?
                  I'm tempted by cutting one of the PWM signals to enable one of the backlights outputs and see what is displayed...if the problem is due to a memory problem I may be able to perform a factory reset ?
                    When you test the power supply/LED driver board by itself and the backlights stay on, the you should look at the PWM control signal to see what it is.
                    • aurelienr
                      • Nov 2017
                      • 25
                      • France
                      According to the schematic, there are pullup that should set them high, but I will check !
                      • aurelienr
                        • Nov 2017
                        • 25
                        • France
                        I made the measurements. When MB disconnected, the PWM signals are at 3.3V level and BLU_On/Off is also high.
                        I tried my idea of cutting the PWM4 wire and reconnected MB, the TV starts with the bottom backlight enabled, but nothing is displayed on the screen. However, I can go into the menus, I ear the clic sound of volume up/down, and when I select the "smart hub" function I get the other sound made when I scroll up/down in the selection.
                        Would it be possible that the Tcon board fails, so that the MB disables the backlight that becomes useless ?
                        • aurelienr
                          • Nov 2017
                          • 25
                          • France
                          Picture of the Tcon board. Only two LEDs on, LED1 and LED2. LED3 is off.
                          https://we.tl/jR5XeUJN7Y
                          • CapLeaker
                            Leaking Member
                            • 8146
                            The main board should power up and the backlights on even without the TCon being plugged in. Please upload the pictures using the attachment function to this site, not some offsite, as pictures disappear after a while.
                            • aurelienr
                              • Nov 2017
                              • 25
                              • France
                              So... no idea of the problem origin ?
                              What should I do ?
                              If a buy a motherboard for repairing, should I take care of both the MB model AND the TV model to be sure to have the correct firmware inside ?
                              PS : for photos, my picrtures were too heavy for the forum
                              • CapLeaker
                                Leaking Member
                                • 8146
                                The new main board has to be compatible with your TV. Sometimes there is more than one main board. Sometimes you can "upgrade" a TV by putting in a better board. All depends on what you want to do.
                                As far as the origin of the problem... I guess you need to trace that back on the main board.
                                • aurelienr
                                  • Nov 2017
                                  • 25
                                  • France
                                  Easy to say, without schematics and knowledge of software behavior
                                  I will try to reflow BGA, then go to garbage and try to sell some spare parts...only 4 years old, what a shame !
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4318
                                    • Italy - Milan
                                    Hi, first your model is UE40F6400 (not EU..).. then a bad troubleshooting method has been followed, the first thing to do was to see with a lamp if you see the image without backlight, if you don't then the major clue is tcon bad, second you must read the pin assignment of the PSU<>main connector, if there's not a line called ER-something or the like, then you don't have an error signal that tells the mainb. you have a backlight problem, so it is not possible led blinkings. To troubleshoot tcon first check it's input fuse.
                                    • aurelienr
                                      • Nov 2017
                                      • 25
                                      • France
                                      Already done, no image. Then, as I said before, I cut one of the PWM wire from the mainboard to force one string to light on (through internal pullup on PSU), and still no image visible.
                                      if you don't then the major clue is tcon bad, second you must read the pin assignment of the PSU<>main connector if there's not a line called ER-something or the like, then you don't have an error signal that tells the mainb. you have a backlight problem, so it is not possible led blinkings.
                                      I read the schematics (link in first post) and there is no error/status/feedback signal, so yes the problem comes from the MB or the Tcon...PWM are generated from MB, but if there is no picture I would guess that there is a problem with Tcon only, but someone on the forum told me that if Tcon fails the backlight continues to operate. Is it a wrong statement ?
                                      Fuse is ok, moreover the LEDs are ok on the Tcon board.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4318
                                        • Italy - Milan
                                        "if Tcon fails the backlight continues to operate. Is it a wrong statement ?" No is correct, i have forgot this, so are you sure with all hooked up you have no image - no B.Light? This is the first i have seen..! This carries me to a mainboard problem.
                                        • gaelican
                                          Odyssey G9 Neo backlight partial failure.
                                          by gaelican
                                          I have an Odyssey Neo G9 that I was working on for a separate issue. After removing the motherboard and putting it back a few times I noticed that the lights on the display have stopped turning on altogether. I was able to determine that when the middle section for the backlights is disconnected, then the left and right side turn on, indicating that the fault is obviously in that area.
                                          After closely inspecting the mainboard I noticed that on the back side of it a few capacitors have been partially moved, one fully knocked off. I replaced the missing one with a new cap with the same...
                                          02-27-2025, 02:39 PM
                                        • howardc64
                                          Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                          by howardc64
                                          Problem
                                          Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                          Model & Board Pics
                                          Conflicting Spec
                                          Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                          https://www.shopjimmy.com/vizio-gj-2k1...
                                          10-10-2024, 01:16 PM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • howardc64
                                          Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                                          by howardc64
                                          Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                                          • Backlight on, no image
                                          • Disconnect right buffer board (view from front), left side display comes on
                                          • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                                          • Buffer board is pretty simple
                                          Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                                          07-11-2025, 04:04 PM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
