LG 42lv42700
  • wazzadj@hotmail.com
    Wazza
    • Nov 2017
    • 57
    LG 42lv42700
    Hi Guys ,
    i have a LG 42inch LED tv 42LS5700 come into the shop
    SYMptoms wont turn on Flashing LED standby light 2 fLASHESS then off Cycles
    NO PIC No SOUND NO BACKLIGHT
    responds to Remote control to turn on From solid red stanby but then 2 red flashes on led light standby
    Ok so i have found the following issues
    Blown output regulators on PSU board - decided all to hard to fix and replaced whole PSU board refurb /secondhand EBAY
    plugged in replacement board Still have same Fault
    so checked following on PSU Main Connector to MB
    Voltages at PSU are as follows\
    all voltages are there except PO/on pin 1. Blue wire in connector Should be seeing 3.5v standby meter on Grnd chasis Postive red probe PIN 1 on PSU connector i get (0v) with set turned on tried pulling up with 3.5v no response
    i have my 12v 24v & 3.5v lines in the rest of plug
    I have 48vdc at TP210 LED +
    seems a little low to me ? i would of thought i would be seeing around 70VDC
    I believe i am not getting a Output from MB IC or i Have a shorted LED circuit pulling down (still have to investigate that)
    Possibly no Signal from MB IC P/on DRV ?
    I have even tried heating up MB main Chip for BG issue ?
    I have Hestitantly ruled out the PSU board cause SUpposably its been tested to Work? lol with fingers crossed !
    I have tried disconnecting LED Cable at top of PSU p210 connector STill no 3.5v on P/on
    Is there a way to force the PSU to turn on say 3.5vdc Pon & BL/on ?
    ANy suggestions where to look help much appreciated
    cheers
    Wayne
    Re: LG 42lv42700
    Can we see good clear straight shot pictures of the power supply board and also the pictures of the power supply board connector that goes to the main board? That way we can easily see the labels for each pin because your pin description is not very clear to me.
      Wazza
      • Nov 2017
      • 57
      Re: LG 42lv42700
      Sure Will do when i get back into shop will upload for you thank you so much for your help
      cheers
      Wayne
        Re: LG 42lv42700
        We also need the pictures of the whole backside of the TV showing all the boards.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Re: LG 42lv42700
          Some power supplies will bring up the backlights when powered up when disconnected from the mainboard.
          Otherwise with the mainboard still disconnected jump standby voltage to BL_ON using a 1K resistor and a second 1K resistor jump standby voltage to Pon.
          Pictures are generally helpful as Budm has suggested not having the set in front of us.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Re: LG 42lv42700
            That sounds like a Main Bd issue. I had a LG showing similar symptom. It was easier for me to replace the Main Bd. Set worked with a new board. I did not investigate the old board to pin point the faulty component as replacement was the more cost effective option for me.
            • Ollyb45
              • Nov 2017
              Re: LG 42lv42700
              Back in the shop and am including pic's of the boards as requested. Have included the pics in segments so visibility will be accessible.
                Wazza
                • Nov 2017
                • 57
                Re: LG 42lv42700
                Model is LG 42 LS5700
                  Wazza
                  • Nov 2017
                  • 57
                  Re: LG42 LS5700
                  Hi Guys , thankyou for your kind assistance as per requested please find attached pictures of the rear of tv and the boards in question
                  please refer to previous posts on issue with Standby power supply circuit not switching on the tv
                  Have checked the Main PSU board connector {P201)
                  have the following voltages on the following pins
                  Note pin 1 is the blue wire bottom to top (pin 12) of connector on back of connector
                  Sorry dont have voltages on bottom of board at this time
                  (48v ) LED +v
                  320v Supply cap
                  1. PO (800mv)
                  2.(24v)
                  3.Gnd
                  4.Gnd
                  5.(3.5v)
                  6.(3.5v)
                  7.Gnd
                  8.Gnd
                  9.(12v)
                  10.(12V)
                  11.(12V)
                  12.pwR dIM (0V)
                  cheers
                  Wayne
                  • attainteddragon
                    • Apr 2013
                    • 764
                    • australia
                    Re: LG 42lv42700
                    when you list voltages, list all pins. in this case the top row is most likely the odd pins and the bottom row the even. you can probe through the connector where the wire enters it. then report the voltages as,
                    pin desc, v in stby, v when power switch is activated.
                    if your 3.5 stby voltage is present, is power on rising above 2v when you press the power button? if not, then your issue is on the main board.
                    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                      Re: LG 42lv42700
                      Per picture,
                      Pin 1 is the PWR-ON PIN, not PO. that is the PS-ON pin.
                      Pin 3 = 24V
                      Pin 5 = GND
                      Pin 7 = GND
                      The exposed pins that you can see from the top side board are ODD number pin, the EVEN number pins, you will have to use probe with skinny tip to probe from the back side of the connector where the wires go in.
                      If you are getting the switched 24V and switched 12V then the PS-ON is working, but at this point we need the Voltages of ALL the pins.
                        Re: LG 42lv42700
                        Where are the pictures requested in post #4?
                          Wazza
                          • Nov 2017
                          • 57
                          Re: LG 42lv42700
                          Ok i tested the {PSU plug today P201 , here is the voltages on the pins as requested please find attached diagram
                          Cheers
                          Wayne
                          • Andrew F. Ali
                            • Jan 2014
                            • 2450
                            • Trinidad & Tobago
                            Re: LG 42lv42700
                            Bear in mind that we do not have your TV in front of us and without the pictures requested we will be unsure regardless of how much information you give us.
                            • attainteddragon
                              • Apr 2013
                              • 764
                              • australia
                              Re: LG 42lv42700
                              this would be my next step.
                              from what you have written, it looks to me like the main is faulty.
                                Wazza
                                • Nov 2017
                                • 57
                                Re: LG 42LV5700
                                Please find attached Photos as requested
                                ON a NOTE i have noticed a discoloured brown area on the top of the back of Panel and all so under the PSU board where it is mounted
                                Could this have been a possible liquid spilled in to it EG COFFEE STAIN view Photo zoom in or is it just Burn hot area from board
                                Ok so did some more test found that PWR-on pin 1 on PSU board connector
                                has no 3.5v getting 0V
                                I am getting all my other voltages 24v 12v 3.5v on connector
                                tried jumping from 3.5v on connector no stndby turn on 0v on meter
                                should it have fired up the supply or is ot being held down in protection due to a detected short in the LED board or the MAIN cPU on the main board?
                                i have not dismantled the front of panel and had a look at LED assy yet
                                wanted to see what you guys think, i dont want to order MAIN BOARD in case the board is being shut down in protection from a faulty LED circuit
                                any suggestions please what to test next ?
                                OH by the way i have 47vDC at TP LED+ on PSU board where the LED panel connects
                                cheers
                                Wayne
                                • attainteddragon
                                  • Apr 2013
                                  • 764
                                  • australia
                                  Re: LG 42lv42700
                                  right now your main is not working properly. no ps/on signal.
                                  to jump the power supply on, you will need to jump pin 1 (ps/on) to one of the 3.5v stby rails and jump pin 18 (drv-on) to a 3.5 stby rail. also disconnect the harness that goes from the ps to the main. if you disconnect it from the main, you can then use the loom to insert your 1k jumping resistors.
                                    Wazza
                                    • Nov 2017
                                    • 57
                                    Re: LG 42lv42700
                                    Thanks attainteddragon
                                    will give it a go and post back results
                                    cheers
                                    Wayne
                                      Wazza
                                      • Nov 2017
                                      • 57
                                      Re: LG 42lv42700
                                      Ok Guys back with the results of testing the PS turning on when jumping
                                      pin 1. (3.5v pw-on) & pin.18 (3.5v Drv-on)
                                      he backlight turns on the PSU fires up ok
                                      so looks like the Main Board is in question is the Fault not outputting the 3.5v from main board processor to PSU
                                      Time to tell customer to hand over more money lol
                                      Hey guys thanks for your help
                                      Cheers
                                      Wayne
                                      • Andrew F. Ali
                                        • Jan 2014
                                        • 2450
                                        • Trinidad & Tobago
                                        Re: LG 42lv42700
                                        Post#6 already earlier advised the Main Bd as the issue.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • k-krzych
                                          Identify board to board connector
                                          by k-krzych
                                          Hello, can you help me with an id of this board to board connector, or the the tiny silicon flat wires for replacement? It is found on GPS unit and connects main board with pushbotton small board....
                                          07-08-2025, 12:32 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
