Toshiba 42ZV635D not powering on
  • mslr
    • Jan 2015
    • 11
    Hi there,
    got this TV not powering on. Checked PSU, seems to be ok but not turning on the LCD 24V. Red LED in front is not turning green. 5V Standby, 18V, 12V and 24V to the main board is ok. P-Protect and AC-Det is around 3,2V. Do not see P-Sig and P-LCD (zero volts). Do not hear the Relay clicking. I don't have the schematics of the power board but found that 12V LCD and 24V LCD will be activated by P-LCD. Unfortunately the powerboard is not part of the documentation available at elektrotanya.com.
    Before I poke into the mainboard why it does not activate the LCD - anyboady out there with some experience?
    Power Board is SRV2194WW. Main board is V28A000966B1 or PE0693 (not shure what is the right number).
    Any help would be really appreciated.
    Martin
    Re: Toshiba 42ZV635D not powering on
    Can we see good clear pictures of all the boards and how they are connected together?
    It sounds like the main board is not sending the command signals.
    • mslr
      • Jan 2015
      • 11
      Shure, see following pictures. I already checked the capacitors in the main supply lines. All of them seem to be in a normal range. What I also saw: It does not power on the supply for the audio on the main board.
      Got the description from the former owner that the TV could not be switched off for some reasons. After a while it was also not possible to switch it on. There may be a corrupted EEProm which is often mentioned in the forum? Or maybe a power rail on the main board failed.
      • mslr
        • Jan 2015
        • 11
        Any ideas?
        • CapLeaker
          Leaking Member
          • 8321
          Well, first I'd try freezing the EEPROM with a can of air upside down and turn the TV on. Sounds like a main board problem. See what happens...
          PSon and BLon are created on the main board. Could also be that the main IC needs a reflow, or it may be toasted.
          • NeedsMoreFlux
            • Oct 2017
            • 121
            • California
            A can of cold air is one way to test it.
            Another way to test it is with a hot air gun. try heating the caps powering the gpu. or heating the GPU its self with about 220F. this will not be hot enough to 'reflow" the balls under it.but it will be enough to make the wires ans balls hot enough to make the wires touch the balls in the gpu.
            Disclaimer: Don't trust a thing I say-I am frequently wrong!!!
            I have tons of spare parts, some used, some N.O.S. ham transistors and caps. Message me if you need any parts.
            Some of the things I've fixed:
            60" Vizio-bad LED's. iBook G4: Resoldered VCC Plug. Geo Tracker ECU: Swollen / Leaking capacitors. Windows Laptop: Soldered broken LVDS wires. Dryer: Burned contact on temp switch. Oven in R.V.: Bad contacts in relays-Exploded by the looks of them! Samsung Oven: Burned contacts on Relays. MSI Motherboard: BSOD-Swollen capacitors, bad graphics card, Moved SATA Input from SATA 1 to SATA 2 plug
            • NeedsMoreFlux
              • Oct 2017
              • 121
              • California
              If you have no idea what I mean: then do not touch it, and take it to a professional.
              • mslr
                • Jan 2015
                • 11
                Checked the schematics. The microcontroller who does the control is a QFP64 Package. Sorry, no balls to reflow. Checked the power rails on the main board. Two of them are missing. The switching regulators do not geht their enable signal generated by the micro. Freezing the EEProm does not change anything. Found two of them on the board and cooled both down without any change. Maybe the microcontroller is missing a signal to go ahead. Where to go next? Reading the EEProm? Which signals must be present to start powering up?
                • mslr
                  • Jan 2015
                  • 11
                  I do board level repair (Apple Macbook and iPhones) just for fun. So everything is available to do it in a professional way. I can measure what you request to point in the right direction.
                  • R_J
                    • 9588
                    Just a note about freezing the eeprom, freeze it before pluging in the tv.
                    unplug the tv, freeze the eeprom, plug in the tv then try turning it on.
                    • mslr
                      • Jan 2015
                      • 11
                      Did that exactly in that order. Still no change in behaviour.
                      • CapLeaker
                        Leaking Member
                        • 8321
                        that sux... guess you need a new main board then.
                        • mslr
                          • Jan 2015
                          • 11
                          Will not give up that easy. It’s fun to reverse engineer a TV and not to exchange a board.
                          • mslr
                            • Jan 2015
                            • 11
                            Ok found a shorted power rail which is shorted by one of the big BGAs. Not worth to repair. Taking your suggestion and looking for a board. BTW: took out the EEProm and read it frozen and warmed up. Same values. Defenitely it is not the EEProm.
                            • CapLeaker
                              Leaking Member
                              • 8321
                              Usually that's how it always ends after one ruled out the easy stuff.
                              • mslr
                                • Jan 2015
                                • 11
                                Checked all the capacitors by putting them off an after measuring again on in the power rail and ended up that the big BGA is shorted. To repair that I will need a BGA rework station and a known good chip. Got a spare board for about 50$.
                                Do I need the content of the EEProm to adjust the new board?
                                • CapLeaker
                                  Leaking Member
                                  • 8321
                                  nope
                                  • mslr
                                    • Jan 2015
                                    • 11
                                    Ok, after changing mainboard TV is back to live. Will test everything in the next days. Thx for support, appreciate!
                                    • Dani_2024
                                      by Dani_2024
                                      10-28-2024, 05:06 PM
                                    • ygorsan
                                      by ygorsan
                                      🧩 Problem Summary:
                                      • I
                                      07-28-2025, 08:34 AM
                                    • jb_Bak
                                      by jb_Bak
                                      CN6401
                                      Pin 01 NC
                                      Pin 02 NC
                                      Pin 03 "BL_ON": 0V
                                      Pin 04 "N/C"
                                      Pin 05 "STBY 3.3V": 3.5V
                                      Pin 06 "GND": N/C
                                      Pin 07 "AC_OFF"...
                                      09-27-2021, 04:52 PM
                                    • JDC
                                      (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                      by JDC
                                      ONN 100012588
                                      Issue: No Power, Then Rebooting After Main Board Change
                                      Short answer: replace main board and power board
                                      Technical answer: replace main board and Q306 & Q307 on power board.
                                      Long answer:
                                      TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                      07-15-2022, 07:39 AM
                                    • m1ch43lzm
                                      by m1ch43lzm
                                      05-12-2025, 08:37 PM
