TV Philips 42PFL3606H/12 won't turn on
  • Maximilius71
    • Nov 2017
    • 5
    • Belgium
    I've a TV Philips 42PFL3606H/12 (Chassis TPM6.1E) won't turn on; no led, no reaction from remote or keypad.
    I unplugged the PSU (715G4802-P01-H20-003H) from the SSB and made the following actions:
    All fuses are good.
    No diodes are in sort-circuit.
    On the CN903 connector, I only have + 5VSB and no + 12V or + 24V.
    I connected the S / B pin to + 5V to get it out of sleep mode and still not + 12V or + 24V.
    On the primary side, I only have + 325V instead of + 395V measured on C907 ?
    On the other hand, the voltage Vdd-S is only + 5.25V; which is too weak ... I also untied pin 16 of IC801 (UBA2071AT) which could have been the cause of this collapse, but that did not change anything.
    Do you have any suggestions for me?
    Regards,
    Maximilius
  • William1967
    • Nov 2017
    • 215
    • Netherlands
    Re: TV Philips 42PFL3606H/12 won't turn on
    That is normal, the PFC isn't switched on. If there is a 5V available to the mainboard and there is no return signal to the power supply the power supply will stay in a kind of low power mode. You can try to make the power supply work by faking the power on signal from the mainboard.
    If you ask me I think the mainboard is the problem.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8321
      So, the PSU is producing STBY voltage to the main board, but the main board is not doing anything. We need to see high resolution, straight shot pictures, so we can see details.
      If the main board doesn't send PSon and BLon signals to the PSU, then the TV will remain off. You need a look at these signals on the connector that goes from the PSU to the main board first. IF you don't get PSon / BLon while you turning on the TV, the main board is the cause.
      • Maximilius71
        • Nov 2017
        • 5
        • Belgium
        @ William1967, thanks for your reply.
        I have indeed suspected the PFC circuit (IC902 = FAN6961SZ) to not work properly despite the setting to + 5V of the pin S/B. What are the signals (voltages) I need to find on this IC?
        @CapLeaker, thanks for your answer.
        I had also bridged the ENA (= BLON?) Pin from CN903 to + 5V but without success.
        Regards
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8321
          PSon turns on the voltage rails for the main board. BLon are the backlights. Both signals need to be present in order for the PSU to be fully on.
          However: You need to verify the main board gets stby voltage. Then find the PSon and BLon, turn the TV on and measure the DCV on those pins. If there is no PSon sent from the main board, while it does get 5V STBY voltage, then the main board is bad.
          SB is PSon, ENA is BLon you have to tie that through a 1k or so resistor to 5VSB. No main board connected. Plug the TV in, all the voltage rails should be on and the backlight on.
          • Maximilius71
            • Nov 2017
            • 5
            • Belgium
            Dear CapLeaker,
            I followed your suggestion by putting the ENA (BLon) and S/B (PSon) pins at +5V across a 1k resistor (one per pin) and the both voltages (+12V and +24V) are still 0V. The Backlight does not turn on.
            I see my voltage Vdd-S go from +0.35V to +5.2V; that's all...
            Regards,
            Maximilius
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8321
              Check if the PFC is working or not. No PFC = no 12 and 24V. You need close to 400V on the main filter capacitor. IC902 (FAN6961) is the PFC controller IC.
              • JorKsX
                Philips 47pfl6008s wont turn on
                by JorKsX
                Hello. Got my hands on Philips 47pfl6008s/12.
                Problem is that it does not turn on. Last owner said the problem came slowly.
                One day did not respond to remote, had to unplug from AC and then back and it worked. next day had to disconnect 3-4 times before it turned on.
                And then it went into hours of unplugging and replugging until it turned on.
                When I plug AC into tv, it does not respond to "turn on" button or anything else.
                After 10-15minutes the TV starts blinking red LED twice.
                So it blinks twice, then waits 3 seconds, then again twice...
                02-13-2022, 03:36 PM
              • pajdek
                Lenovo Y700-17ISK turn on and off
                by pajdek
                Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                09-20-2023, 02:49 AM
              • ovrax
                Philips 55PUS6804/12 turn on & off (probably backlight issue)
                by ovrax
                First of all, please excuse me as I'm quite new to this field.
                I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
                I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
                The Ambilight works perfectly and stays on.
                No sounds.
                Thanks in advance.
                08-25-2024, 04:33 AM
              • RdeveLabs
                MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                by RdeveLabs
                To all the members here...
                Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                05-05-2025, 04:59 AM
              • robante15
                Acer Aspire 4520 won't turn on after reboot
                by robante15
                Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                If I remove the...
                04-06-2024, 06:50 PM
