sharp aquos lc-52xl2e wont power on
    Re: sharp aquos lc-52xl2e wont power on
    Originally posted by MrJIM
    Do you mean bus5v ? I have 04.98 v dc on that
    Yes, so now it shows 4.98V instead of 'OL' with correct meter setting.
    So based on the reports of other Voltage on the connectors, it looks like your main board is not sending any command signals to turn on the the power supply, etc.
    BTW, if the main board connected, are you still getting a bunch of 0V reading? Especially the PS-ON pin.
    • MrJIM
      • Oct 2017
      • 20
      ok so what should I test now ? I know this must be painful for you but please bare with me I do appreciate all of the help im getting
        Hook all the boards back together and re-test all the Voltages of those pins that you reported earlier just to be sure we are not getting the wrong data.
        • MrJIM
          • Oct 2017
          • 20
          I removed some before because my dmm lead wouldnt fit into the back of the plugs is that ok or should i force the lead in anyway
          • MrJIM
            • Oct 2017
            • 20
            and should i have the meter set to 00.00 or auto ?
            • MrJIM
              • Oct 2017
              • 20
              ok the only changes from earlier are
              pin/ tv on / tv off
              ur12v / 00.51 / 00.00
              ur12v /00.52 /00.00
              bus5v / 04.98 / 00.00
              ac_det / 03.16 /00.00
                One of the most important signal is the PS-ON to turn on the rest of the power supplies, so if PS-ON is staying 0V then the troubleshooting the main board to find out why will be next.
                • MrJIM
                  • Oct 2017
                  • 20
                  I retested this morning and I can confirm there is 0v on ps-on
                  • MrJIM
                    • Oct 2017
                    • 20
                    opened the cover on the main board and found a green light on the main board it flashes for 5 seconds when i plug tv in then stops see picture attached added some other pictures too
                    • MrJIM
                      • Oct 2017
                      • 20
                      I should add the tv does come on briefly 5 seconds when plugged in
                      • budwich
                        • Jul 2015
                        • 3097
                        the ps-on will only be there momentarily during startup (quick), if the set has other issues.
                        • MrJIM
                          • Oct 2017
                          • 20
                          thats right bud PS_ON 02.67 is present when the tv is first plugged in
                          • mahfoudh
                            • May 2020
                            • 6
                            • Tunisia
                            #33
                            hello
                            i have same problem PS_ON present zhen the tv is first plugged in
                            also the 15V then it goes
                            any help plz?
                              • 12201
                              • U.S.
                              #34
                              Is your model the same sharp aquos lc-52xl2e?
                                • 12201
                                • U.S.
                                #35
                                follow post number 6 above, report readings, you do have a multimeter?
                                • mahfoudh
                                  • May 2020
                                  • 6
                                  • Tunisia
                                  #36
                                  PS_ON / 2.69
                                  AC_DET/ 3.2
                                  PNL_POW / 3.2
                                  SGND --------
                                  BUS5V / 5v
                                  SGND -------
                                  UR15V / 15
                                  UR15V / 15
                                  PNL12V/ 12v
                                  SGND----------
                                  UR60V / 60
                                  SGND ----
                                  UR12V /12
                                  UR12V / 12
                                  SGND -------
                                  UR60V / 60
                                  ALL voltage are good for 3 or 4 sec than it goes
                                    • 12201
                                    • U.S.
                                    #37
                                    with tv unplugged unhook cable from powerboard to mainboard, leave it off, plug powercord back into powerboard, retest and see if voltage is steady, will probably only get standby and acdet.
                                    • mahfoudh
                                      • May 2020
                                      • 6
                                      • Tunisia
                                      #38
                                      i will see
                                      • mahfoudh
                                        • May 2020
                                        • 6
                                        • Tunisia
                                        #39
                                        Same problem Sir ��
                                          • 12201
                                          • U.S.
                                          #40
                                          Ok, you have a problem with powerboard, you will need to fix the standby voltage or get a new board.
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                            09-06-2024, 05:59 AM
                                            HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-12-2024, 02:15 PM
                                          • meraklinetx
                                            Asus Z97-a power cycle, no boot no cpu voltage
                                            by meraklinetx
                                            Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                            05-10-2023, 06:08 AM
