LG 32LN578V PS b/d issue
  • notallbad
    • Oct 2012
    • 1190
    Re: LG 32LN578V PS b/d issue
    yes ordering from china is taking roughly 6 weeks i notice lately not sure if rs etc sells leds? as you know the colour size voltage and amps needed so maybe worth a look
    all i know is that the 3v 1W 3528's keep blowing so shall go for the 6v 2W 3535's.
    trial and error here!
    shall update with my findings, in about 6 weeks time, what a drag having to put it all back together again only to be having to disassemble again. hopefully I wont break the panel on the 3rd attempt.
    • diif
      • Feb 2014
      • 6978
      • England
      Have you got a photo of the back of the LED ? I have quite a few here and could post you a couple if that helps.
      • notallbad
        • Oct 2012
        • 1190
        that would be great if they are the same, 2 pad type
          Per LCD panel spec it shows Vf of the LED string as 111.6V min, 118.8 typ. 127.8 max.
          You have 21 LEDs (per post #13) so 21 LEDs x 6V LED = 126V.
          • vinceroger69
            • Mar 2012
            • 6714
            Thanks for confirming that budm i wasnt sure when i made that post budm in the post the ali express link i posted was they the correct leds? im always confused on what mah reading we should be looking for as some are forward some are reverse etc.
            • vinceroger69
              • Mar 2012
              • 6714
              #26
              is anode the large or small pad? i have some here too but need to check what voltage and pad layout they are
              • diif
                • Feb 2014
                • 6978
                • England
                #27
                I have some of these. https://www.aliexpress.com/item/110P...812353527.html
                • vinceroger69
                  • Mar 2012
                  • 6714
                  #28
                  i have the same ones you have linked these are the 3 volt version 1 watt
                  these are the ones i think he may need but these are 2 watt not sure about the current rating etc
                  https://www.aliexpress.com/item/50pc...StoreLevelAB=3
                  please read the comments as one person has said anode and cathode is wrong the picture is not correct so dont take my word they are the correct ones
                    Tension maximale:6.0-6.8V (250mA)Type
                    LedCourant maximum:500mA
                    250mA should be the max, but LG probably drives them higher than that.
                    That is a lot of power dissipation for one small body LED to handle and uses the same heatsink (the strip) as the single LED (3V).
                    So make sure to run down the backlights as low as you can.
                    They use 6V LED instead of 3V LEDs so they save money on the qty. of the LENSES
                    • notallbad
                      • Oct 2012
                      • 1190
                      anode is small pad
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        #31
                        anode is small pad
                        see post 28 one person says the picture is wrong so maybe the anode is the small pad?
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          #32
                          Actual LED I have, the link I posted was one that looks similar (may or may not be the ones I have 10 of).
                          Negative is the big pad.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            #33
                            diff are yours the 3v version or 6v ones?
                              LED for LG panel has BIG pad as Anode, those are what use so far. You should 100% verify for sure.
                              • notallbad
                                • Oct 2012
                                • 1190
                                You are correct!
                                On the LED Strip the larger solder pad is on the anode side, smaller solder pad is the cathode.
                                Clearly the 3v led's (the wrong ones for this panel) I have are the other way around. And as pointed out, the photo I posted of the underside pad of the led is of the 3v replacements, not the led removed from the panel.
                                • diif
                                  • Feb 2014
                                  • 6978
                                  • England
                                  #36
                                  6v. Tested with my LED tester it showed 5.5v.
                                  Photo I missed from my other post. Taken through a microscope to show the detail.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    #37
                                    sorry wrong thread
                                    • notallbad
                                      • Oct 2012
                                      • 1190
                                      How many could you let me have?
                                      I have ordered some (qty. 50) but 6 weeks is a looooong time! Especially after waiting 6 weeks for the wrong ones 3v, though thats an error on my part.
                                      I need to change 2 leds, 1 on upper strip and 1 on lower strip and not being the greatest at soldering could really do with a couple extra just in case.
                                      I understand if you only have a few and can't spare any out.
                                      Of course I shall send payment or post some back when they arrive if preferred.
                                      Meanwhile I have some 3v leds (qty. 95 remaining) if anyone needs a few in a hurry, just pm me.
                                      • diif
                                        • Feb 2014
                                        • 6978
                                        • England
                                        #39
                                        I have 10, how many would you like ?
                                        I can't see you waiting 6 weeks, stuff is taking about 2 weeks currently. I have one delivery last week that took 7 days.
                                        • notallbad
                                          • Oct 2012
                                          • 1190
                                          Pm'ed you. Thanks
                                          • rounin
                                            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                            by rounin
                                            🛠 Original Issue
                                            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                            04-19-2025, 01:18 AM
                                          • ugamazing
                                            by ugamazing
                                            12-17-2024, 07:05 PM
                                          • shahnld
                                            Lenovo legion 5 pro startup issue
                                            by shahnld
                                            Good day Experts
                                            I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                                            A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                                            And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                                            08-24-2025, 12:31 PM
                                          • ahmarzo
                                            Acer laptop battery draining issue
                                            by ahmarzo
                                            Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                                            Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                                            08-02-2025, 06:39 AM
                                          • elmark
                                            HP 15-cw1002ua strange keyboard issue
                                            by elmark
                                            HP Pavilion 15-CW1002UA
                                            S/N 5CD0251CBC
                                            P/N 7KE54EA
                                            Hello guys!
                                            I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                                            It powers on OK and has no other issues except the following:
                                            • CAPS LOCK does not work at all
                                            • Fn button toggles Flight Mode
                                            • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                                            • (with SHIFT pressed: 't%' and 'y^' respectively)
                                            I initially thought it was a keyboard malfunction (internal short, etc.),
                                            but when I press and hold...
                                            06-27-2025, 01:10 AM
