LG 42LB5D screen
  • Jwheld
    • Sep 2017
    • 5
    • MN
    LG 42LB5D screen
    The following is the symptom my tv is showing... the bottom 1/4 of the TV flickers in and out. Occasionally it works perfect. I recently replaced the TCon because I fried the old on trying to diagnose, and the defect persists. I've checked all of the power supply outputs and all show correct voltage.
    My thought is that it is either the inverter boards or the display itself. The fact that it's intermittent seems like a possible bad connection but I've checked the all and cleaned with alcohol, made no difference.
    Any input is greatly appreciated. Maybe there is a sticky I can be pointed to.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 42LB5D screen
    Bad panel, all right. I had a Samsung that showed just like yours...
    • Jwheld
      • Sep 2017
      • 5
      • MN
      Is it repairable/replaceable?
      If so, is it worth it?
      • heavymachines
        • Mar 2011
        • 1028
        If it is a bad panel no it is not unless you have a $5,000 tab bonding machine. I suppose you can do some checks to be sure it is bad panel. You might be lucky to be able to remove a bad tab and the ones on other side will take the load but i dunno if it can be done on this tv. Those with experience will have to chime in on that one.
        • Jwheld
          • Sep 2017
          • 5
          • MN
          Thank you for the input. I'll see if others have comments.
          A simple check to be sure it's the panel would be great. As mentioned I've checked the power supply and TCON. Is there a check for the inverter board? This would the the only other thing to eliminate before deeming the panel faulty.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4542
            • Italy - Milan
            Don't waste time and peace of mind, the image tells clearly that backlight is not the problem. When you see the flickering have you got an image distortion? Watching this image i can suppose that maybe you have a failing bottom side tab on the left, i need other 2 images if possible. But only to do a diagnose, i think anyway there's nothing you can do without an oscilloscope. Maybe be you can do a jump between tabs..
            • Jwheld
              • Sep 2017
              • 5
              • MN
              The image does not distort when it flickers. At some times, the whole picture looks perfect.
              What other images would you like? I can surely upload more this evening.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4542
                • Italy - Milan
                An image not black in the problem part. It's the precise separation between normal image and faulty part that says to you it's a lcd panel problem.
                  Bad panel.
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • reformatt
                    by reformatt
                    07-31-2025, 08:37 PM
                  • smic717394
                    by smic717394
                    07-25-2024, 10:16 AM
                  • Chrissygizmo
                    by Chrissygizmo
                    02-10-2025, 12:33 AM
                  • spice_disc
                    Vizio TV M50-C1 reboot cycle and static on screen
                    by spice_disc
                    I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                    The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                    09-08-2024, 02:37 PM
