Samsung LN55C630K1F
  • m4a2t0t
    • Mar 2013
    • 279
    Samsung LN55C630K1F
    I have this TV where the HDMI ports ripped off the board. There are so many damaged traces and pads I don't think it will last. I also had to use the old ports.
    I cannot find a board with the same part numbers anywhere. Is it possible to use a similar board and swap some chips out to get it working with this TV?
    The board has 2 stickers with numbers
    BN97-04040E
    BN94-02701E
    Board Code BN41-0143B
    Closest I can find is board from a LN40C630K1F
    thanks
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: Samsung LN55C630K1F
    If the connectors all match up, then it should work. Samsung has used an auto LVDS setup on their main boards for quite some time and for the most part, the boards are interchangeable between LCD screen sizes and manufactures. Again, compare the connectors. Sometimes the locations & types vary with TV model even though the board is basically the same.
      I would contact shopjimmy to see what they will say about the substitute board.
      • m4a2t0t
        • Mar 2013
        • 279
        That was they first thing I did. They ignored my question and told me to signup for an alert on when it comes back in stock. I thought they would have helped.
        • m4a2t0t
          • Mar 2013
          • 279
          I will order the board and give it a shot.
          • m4a2t0t
            • Mar 2013
            • 279
            Scratch that one, the board sold and there is nothing similar available now.
            • heavymachines
              • Mar 2011
              • 1028
              BN94-02701D
              BN94-02701R
              BN94-04045A
              BN94-04045B
              BN94-04567A
              BN96-19193A
              BN96-19194
              These are supposed to be sub parts you should be able to find compatible. http://openboxcity.net/samsung-bn94-02701e
              • heavymachines
                • Mar 2011
                • 1028
                BN94-02701K
                BN94-02701C
                BN94-02701D
                BN94-02701B
                BN94-02701G
                BN94-02701H
                BN94-02701J
                BN94-02701L
                BN94-02701M
                BN94-02701P
                BN94-02701R
                BN94-02701S
                BN94-02701T
                BN94-02701W
                BN94-02701X
                BN94-03446C
                BN94-03446E
                BN94-03446F
                BN94-03446G
                BN94-03446J
                BN94-03446K
                BN94-03446L
                BN94-03446M
                BN94-03446N
                BN94-03446P
                BN94-03446Q
                BN94-04045A
                BN94-04045B
                BN94-04045E
                BN94-04561A
                BN94-04562A
                BN94-04564A
                BN94-04567A
                BN94-04570A
                BN94-04571A
                BN94-04573A
                BN94-04610A
                BN96-19187A
                BN96-19188A
                BN96-19190A
                BN96-19191A
                BN96-19193A
                BN96-19194A
                BN96-19195A
                BN96-19196A
                BN96-19197A
                BN96-19198A
                shop jimmy even posts more sub boards so you should be able to find one .
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • ohren
                  by ohren
                  09-08-2023, 05:24 PM
                • C152Heavy
                  by C152Heavy
                  Summary for TL-DR readers:
                  • VCC pin (18) of PFC...
                  01-11-2023, 02:53 PM
                  09-07-2024, 05:50 AM
