JVC Model: JLC37BC3002 - Backlight not working
    Re: JVC Model: JLC37BC3002 - Backlight not working
    At since point since you did test the power supply/inverter board by itself using force on with resistors but still no backlights then you do have power supply board problem.
    VBR missing is the main board problem.
    • kyrinth021883
      • Sep 2013
      • 40
      • US
      Ok, that's what I was wanting to hear from the experts I will search for a new board. Thanks a bunch for the great help! Will update once I get a new one.
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        It certainly looks as Budm says. Out of curiosity what was the Status voltage when you had jumped all three points? From the link in an earlier post given on this thread, when the set was displaying the logo
        VBR_B - 3.22V
        Status - 0.0V
        I suspect that the Status voltage (3.06V) is at fault condition and as a result disabling VBR_B
        • kyrinth021883
          • Sep 2013
          • 40
          • US
          Its was STATUS - 3.31, same as before (also get all 3 12VDCs)
          • Dumah Brazorf
            • Jun 2013
            • 179
            • Italy
            Originally posted by kyrinth021883
            When first turned on, i think I see some faint blue-ish light from the top left corner (looking at the back) through some of the holes in the metal backplate. But this only lasts a second or two. Can't tell if this is the backlighting trying to fire off, or something else.
            Did not notice that in the first post.
            It may be a bad cfl lamp arching.
            • kyrinth021883
              • Sep 2013
              • 40
              • US
              #26
              No, it is definitely blue LED lights. the one under the PS/Inverter board I can actually see the when I look under it. The light in the top corner is the same light and they both light and fade out the same together. Plus if there were arcing and such, i think I would hear it and it would look a lot different lol.
              • nsilvang
                • Mar 2017
                • 26
                • mexico
                #27
                i need the bios dump for this tv jlc37bc3002
