Panasonic txl39em5b
  • Norman1
    • Jun 2017
    • 77
    • Uk
    Panasonic txl39em5b
    Hi guys have a Pana with a 14 blink error code, ppl are saying it's either the power board or possibly the A board. Anyone had any luck narrowing it down as there quite expensive boards. Many thanks.
  • Norman1
    • Jun 2017
    • 77
    • Uk
    Re: Panasonic txl39em5b
    Pics
    • dskall
      • Oct 2016
      • 2905
      • usa
      What are symptoms
      • Norman1
        • Jun 2017
        • 77
        • Uk
        Symptoms are a standby light flashing 14 times, no picture or anything else
        • dskall
          • Oct 2016
          • 2905
          • usa
          Not much info to go on
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            Are all the voltages present on the power supply?
            • Norman1
              • Jun 2017
              • 77
              • Uk
              Just an update if anyone's interested, replaced the power board, main board and t con, still giving a 14 blink error code. It's not looking good
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                Can you post the voltages you have on the power supply boards alongside their names as a good starting point for people to offer help.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  as this is a led set may also be worth testing the led strips if you have a tester etc
                  the 14 blink light code maybe referring to plasma not lcd
                  • Andre Gilbert
                    by Andre Gilbert
                    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                    11-20-2024, 08:52 PM
                  • AquaMan Ua
                    by AquaMan Ua
                    05-17-2025, 09:40 AM
                  • stecos
                    Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                    by stecos
                    Hi everyone!
                    For my passion for technology I'm now collecting several...
                    11-28-2022, 11:39 AM
                  • aa10aa10
                    Panasonic Toughbook CF-33 mk1 BIOS repair
                    by aa10aa10
                    Good day,
                    I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                    I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                    01-21-2025, 06:13 AM
                  • Mnawar27
                    Panasonic CF-H2AU24EF3 bios locked
                    by Mnawar27
                    Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
                    I need help to remove it,
                    thankyou all.
                    SN; 2FKCA26876...
                    11-16-2024, 08:00 AM
