Sharp LC-60EQ10U 3 long blinks, 1 short blink
  • Thiefcatcher
    • Jun 2017
    • 19
    Hello, I'm looking for some help on fixing my parents-in-law's tv. The tv is a Sharp LC-60EQ10U. They said that the display had dark horizontal bars that were spaced a few inches apart (I don't have pictures of this display issue). The tv would not respond to the remote or tv power buttons and was eventually shut off by pulling the power cord. The tv display would not turn on and an error flashing code started on the front of the tv with 3 long flashes and 1 short flash.
    So far I've tried replacing the main board and a t-con board purchased off of ebay with no change in the tv. I also removed the ribbon cables from the t-con board and the backlight came on. When I removed the left two ribbon cables from the t-con board, the screen showed a white screen on the side with the removed ribbons and a picture on the other half of the screen. When I removed only the far left ribbon cable from the t-con board, the screen showed thin colored vertical lines on the side with the removed ribbon cable and a picture on the other half. I've tried to look at the side tabs, but there is nothing connected to the side tabs on the tv that I've been able to find, only the tabs on the bottom of the lcd panel.
    Any suggestions of what to try next? Any help/suggestions would be greatly appreciated. Thank you.
  • Thiefcatcher
    • Jun 2017
    • 19
    Re: Sharp LC-60EQ10U 3 long blinks, 1 short blink
    Whew! The tv is fixed. I peeled off the tabs on the right side of the tv. I started with the tab on the bottom that appeared scorched. The display was much better in the area where I had removed the tab, but was still poor higher up on the display. I removed the other 4 tabs and the screen looks great. I found some great information in a few other threads. https://www.badcaps.net/forum/showth...arp+lc-60eq10u https://www.badcaps.net/forum/showth...arp+lc-60eq10u
    Thank you to everyone that provides your great expertise on this forum.
    • funkyjamma
      • Oct 2017
      • usa
      This is awesome I was able to fix my tv this way.
      Unfortunately I managed to crack the screen putting the bezel back on
      I was so excited now i need to get a new one.
      • JacobSyd
        • Mar 2018
        I am so impressed by this forum and this thread, I just rescued my Sharp Aquos 60 by using the info I gained from this thread. This must be a fairly common problem, but I do believe it was a power spike during a small thunderstorm that caused the issue with the Component built into on the Tabs. And just in case I am right, I will be running my Aquos and all the devices it connects to on a UPS/battery to protect it better than the surge suppressing power strip I had it on. Many Thanks to all contributors and Badcaps.net.
        • dacflyer
          • Jan 2019
          • 3
          hi guys.. i am having a similar issue.. ( LC-60LE650U )
          Same flash codes ( 3 long 1 short ) from what i read here, mine is not the same issue.
          the screen does not light up at all, and separating the ribbon cables has no effect.
          so i did a bit more research and believe its the PS board. but at this point i have no clue what to look for 1st. without a schematic.
          does anyone have one or know of what to check for as a culprit ?
          thanks..
            • 12331
            • U.S.
            @dacflyer, First things first: Test connector from mainboard to powerboard on powerboard side, sholud be a little legend/map of expected voltages, test with tv plugged in but off then hit power, report both conditions here, give pin number, pin description and condition on and off, demonstration in signature below.
            • Superbee_dad
              Sharp 80” long short flash backlight error - Help
              by Superbee_dad
              Hello Sharp TV experts
              Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
              > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
              > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
              01-24-2025, 11:51 PM
            • Noobwithamultimeter
              Sharp LC60C6400U - 2 long binks, 5 short blinks error code
              by Noobwithamultimeter
              Hi, long time browser - first time poster. I got my hands on a Sharp LC60C6400U and from what I could find on youtube similar models of this set have a 12V power regulator that fails called "KIA378R12PI". So I go ahead and order the part, install it and badda-bing my set worked right away. Only a problem - it failed after about 3 hours. So I re-attempted my solder joints and it was back in business, for a couple of days. Failed again with the same error code. I think to myself no worries I have 4 spares since I bought a 5 pack in case anything went wrong. But now after roasting the solder...
              04-06-2021, 01:31 PM
            • Rotorcraft230
              Sharp LC 80C6500U 1 long 1 short blink
              by Rotorcraft230
              Hello all, I have been here from time to time and now I'm back for some assistance.
              So I have the TV above and its doing the one long and one short "V" blinking. I did the reset on the controls on the side of the TV and while holding down the volume - and the input button, then plugging in the TV the "V" light is solid, then very briefly I see the backlight flash, then the "V" goes back to the 1 long and 1 short blinking. I just want to make sure its the backlights before I get the parts to fix it. Is there anything else I can do to confirm its the lights....
              02-28-2021, 04:14 PM
            • klassic
              Sharp Aquos LC-60LE635E three blinks
              by klassic
              Hi community,
              I will describe my problem with a TV in those short following terms to be the most precise :
              What i have :
              power board DPS-162KP-1
              main logic board QPWBXF733WJN2
              symptoms :
              white led light logo at startup,
              after 2 minutes, blinking 3 times a row, repeating
              no backlight (and apparently no picture, checked panel with flashlight)
              no startup sound
              powerboard investigations :
              1-2 PNL : 0v
              3-4 GND
              5-6-7-8 UR : 13.15v
              9-10-11-12...
              10-24-2023, 01:39 PM
            • Tom_x
              HP Omen 15-dc0001nh capslock blinks 5 long and 3 short
              by Tom_x
              I have HP Omen 15-dc0001nh (DA0G3DMBCE0 rev: E) with blinking capslock 5 long and 3 short. Fans spin constans speed.
              HP worked for 2 months after i repaired (before damaged by thunder via rj45 port) I removed LAN ic and powered on
              Now with blinking capslock:
              All voltage present on big coils, except +VCCGT (i don't know this need for booting)
              I tried re-flash bios with known firmware- same result (now i don't have spare bios chip to test spi flash failure)
              DDR4 ram is ok, tested on other laptop
              WLAN and SSD removed,...
              07-20-2023, 10:10 PM
