Panasonic TX-42A400B
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Panasonic TX-42A400B
    I have not heard of that myself or even read about if im honest, is it possible the t con is a known issue on these sets and you have brought another faulty one? what is the lcd panel number used in this set? is it a panel with a known high failure rate? can you check if the main board is sending signals too the t con im sure i have read you can measure the twisted pairs of wires on the lvds lead.
    • ronhayes
      TV Engineer
      • Mar 2014
      • 458
      Hi Vince
      I have took some picture of the rear of set to show the labels and connections but unfortunately I cant measure for signals as my scope is to old for this type of work?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        It may be worth trying to read as many voltages as possible marked on the TCON. There could be a fault on the interface strip between the panel and the tcon or even the COF chips that is loading or even shorting one of the tcon supplies.
        • ronhayes
          TV Engineer
          • Mar 2014
          • 458
          Hi All
          I have contacted the supplier for the item mentioned kindly by vinceroger69 and they inform me this tester can only be connected to the T-Con board and it only comes with 14 common TV connectors.
          So if you need to test a TV screen it would be difficult unless you know 100% that the T-Con is working.
          But having said that still think it would be a handy item for the work shop.
          If you have no display and you connected this tester to the T-Con and you then have a display you would know that T-Con and screen are ok.
          But if no display then it could either be display or T-Con that were faulty.
          I have now sent for another T-Con for this set as they are not to expensive hoping this will give me some positive results.
          • thoma
            • Sep 2012
            • 268
            http://forum.iwenzo.de/topic.php?t=6...ght=led;tester
            • vinceroger69
              • Mar 2012
              • 6714
              #26
              this pdf link is a training manual for a lg tcon maybe worth a read as does say how to check voltages etc on a tcon board
              file:///C:/Users/LENOVO%20OWNER/Documents/Electronics%20Repairing%20Collection%20Ebooks/TCON%20TRAINING.pdf
              • vinceroger69
                • Mar 2012
                • 6714
                #27
                This is a good link for the back light led tester, the tester we have mentioned in this thread is too test the lcd panel/t con too prove the lcd panel is good as the back lights on this set seem too be working fine.
                • ronhayes
                  TV Engineer
                  • Mar 2014
                  • 458
                  Hi All
                  this may be a stupid request but maybe someone could help !!
                  I have purchased the LCD test tool as recommended by Vinceroger69.
                  Now it has arrived and as you can guess the user instructions are quite vague to say the least.
                  It came with four discs but having trouble using them.
                  I have checked the video's on YouTube and have a good idea on how to use .
                  Now if some one could kindly look at the pictures I have attached to this message maybe they could help !!
                  There are only two connectors that fit the t-con board and as you can see number 1 has the power connectors on the right and number two has the power connectors on the left.
                  now looking at the service manual as kindly supplied by Dick_Barton on page 10 it states lcd screen is 1920x1080
                  And in the service manual there is no info on the t-con board but from when I tested the f1 fuse I got 12v .
                  So I am sure looking at the tester I think I would need to use the lead number one and set the tester to 12v and the display to 51,52or53.
                  If someone has used one of these before and can look at the attached pictures and confirm this for me it would be much appreciated.
                  I am going to print out the instruction when I manage to access the discs.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    #29
                    It would look like lead number 1 because as you say that lines up the fuse on the Tcon with what appears to be the supply wires (Red) of the connector. No 51, 52 and 53 match the screen resolution.
                    • ronhayes
                      TV Engineer
                      • Mar 2014
                      • 458
                      Thank you dick
                      I have now carried out the tests
                      I have done this test with three t-con boards and get the same results with all three no display back lights on but no colour bar displayed.
                      Now according to the test tool if no display t-con faulty if display colour bars then fault with logic board.
                      Now when I first looked at this TV I assumed the fault was the t-con board, So I sent for a replacement t-con board when this failed to give me a display I sent for another but still the same issue. now I find it hard to believe that three t-con boards are faulty so I now think that the LCD display is faulty!! now I know the connections are at the bottom of the TV and someone suggested that it could be water damage? I have looked very closely at the LCD boards at the bottom of TV and can see no signs of water stains at all.
                      It would seem the this LCD has just give up very strange this is the first I have looked at with this issue.
                      • attainteddragon
                        • Apr 2013
                        • 764
                        • australia
                        #31
                        have you tried applying pressure to the cof chips and connections to see if that alters the picture at all?
                        WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                        • ronhayes
                          TV Engineer
                          • Mar 2014
                          • 458
                          Yes I have applied pressure to all connections along both boards but not even a flicker!
                          I also unclipped boards from their position very carefully I must say as not to damage the connections to see if any water damage with magnifier glasses but all looked fine.
                          That's why I think the Lcd screen has gone down but must admit never had this before ?
                          • attainteddragon
                            • Apr 2013
                            • 764
                            • australia
                            #33
                            i suspect that it is panel, though not all will alter the screen when pressure is applied.
                            you might get lucky and find a shorted ceramic cap on the panel driver board, but that does not happen often.
                            • ronhayes
                              TV Engineer
                              • Mar 2014
                              • 458
                              Yes but there are two driver boards so if that happened you would get half picture on the other board ?
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                #35
                                with your new tester can you connect it up and disconnect one side of the ribbon cables from t con too panel pcb do you get the test patterns on half of the screen?if not try with the other side disconnected, caution though im not sure if your new tester will work like this so try at your own risk is you want too try it out
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  #36
                                  The only other thing I can think of is that the tester has been set to 12V and you can measure this at the LVDS tcon end. The data says the tester can be toggled between 3V3, 5V and 12V supply for the Tcon.
                                  • ronhayes
                                    TV Engineer
                                    • Mar 2014
                                    • 458
                                    I have just tried toggling the tester through 3v3.5v and 12v and nothing on 3v3 nothing on 5v but when it goes to 12v you get a flash of colour at the top left hand side of the screen about 6" long and 2" wide for a brief moment ?
                                    • ronhayes
                                      TV Engineer
                                      • Mar 2014
                                      • 458
                                      I have tested screen with removing connections from panel here are results !
                                      Pict 1 is with R/H connection looking from back of set pict 2 is displayed for a split second then goes to pict 3 with the L/H connection removed as the tester is switched on
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        #39
                                        Sorry Ron but out of idea's other than cycling through options 51, 52 and 53 and see what happens
                                        • ronhayes
                                          TV Engineer
                                          • Mar 2014
                                          • 458
                                          Yes I have tried that but same results I am convinced the LCD panel is shot.
                                          But thanks for all your help much appreciated I will be carrying out that test on the Digihome tomorrow.
                                          • Rictech
                                            Panasonic SA-MAX770PU SMPSU board fault....
                                            by Rictech
                                            Hello everyone. 😀
                                            As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                            Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                            Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                            This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                            There are no devices that have exploded or otherwise show signs...
                                            08-26-2024, 01:05 AM
                                          • x_orange90_x
                                            TCL 50S535 bad tcon or panel issue?
                                            by x_orange90_x
                                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                            03-29-2025, 11:02 PM
                                          • advant
                                            by advant
                                            02-03-2020, 12:25 AM
                                          • eccerr0r
                                            Sell or Shim Solar panels?
                                            by eccerr0r
                                            Well, due to my grid tie inverter not accepting high voltages, and the fact that the lions in my solar panels are 36V (72-cell) I think I need to stick with 72-cell.
                                            However I have a few smaller panels that are 36, 32, and two 30-cell. The 36 and 32 together run at 75% efficiency (and subtract more with additional inefficiencies) when running in parallel with the 72-cell panels. The kicker is that the two 30s... generate 0% power when connected in parallel(!)
                                            So now what to do with these small panels?
                                            I could sell them...
                                            Or I could shim them....
                                            03-29-2025, 01:07 AM
                                          • howardc64
                                            Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                            by howardc64
                                            • Prior owner tried a replacement main board. No difference.
                                            • Samsung 2x red blinking standby LED = panel fault
                                            • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                            • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                            • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                            07-19-2025, 10:54 PM
